installing my 505 #122947
09/19/08 05:48 AM
09/19/08 05:48 AM
michigan
bighughey Offline OP
michigan
got my engine today and ineed help with install. should i go with motor plates? or is their a company that makes motor mounts strong enough to hold this engine. if i go with the plates how do i know what position the engine should be. god i need alot of help
Re: installing my 505 [Re: bighughey] #122948
09/19/08 07:10 AM
09/19/08 07:10 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
What kind of car are you going to put it in?
Re: installing my 505 [Re: bighughey] #122949
09/19/08 11:04 AM
09/19/08 11:04 AM
Motor mounts & a torque strap for backup. The plates have been known to leak(but not always) & you want the carb reasonably level & check your pinion angle. God works thru Moparts.
Re: installing my 505 [Re: bobby66] #122950
09/19/08 01:33 PM
09/19/08 01:33 PM
michigan
michigan
its going into an a body valiant.the motor should put out 700 without nos. and more with it. i am told that no motor mount will hold this much power
Re: installing my 505 [Re: bighughey] #122951
09/19/08 02:02 PM
09/19/08 02:02 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Motor plate
Last thing you want or need is tranny problems. Plus you will help stiffen the chassis a little.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: installing my 505 [Re: bighughey] #122952
09/19/08 02:32 PM
09/19/08 02:32 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Set your motor in with the motor mounts, to get it in the position, it belongs. While the motor is sitting there, you can make up the motor plate and tabs for the motor plate. Then it should be in the correct position. When all done remove the motor mounts.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
