Re: what roller rocker do i use for eddy heads
[Re: DaytonaTurbo]
#1229427
05/08/12 01:16 PM
05/08/12 01:16 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
What doesn't fit? Eddy rpm heads are supposed to take stock rockers.
What he said.
What is not fitting and what rockers do you have?
[Re: DaytonaTurbo]
#1229428
05/08/12 04:13 PM
05/08/12 04:13 PM
Posts: 5,904 Athens, Greece
Pyper70
Athens, Greece
Stock rockers aren't adjustable though.
I went through this two weeks ago with my build (RPM heads) the problem was even though my ductiles were shimmed properly to my 906s, the rocker itself was rubbing on the pedestal of the RPM heads. I use shims & spacers, not springs. I spent about 10 hours removing, installing, tightening over and over again until I noticed where the problem was. Went to my spare parts closet and pulled my Harland Sharp Rollers I had set aside (luckily I had them). I got them from Todd at Competition Wedge Racing. Fit like a glove. They do have to be setup for RPM heads though. I didnt have to shim anything....from the package, to the oil bath, to the heads. Put it altogether and dropped a bottle of zinc additive to the oil...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: DirectSubjection]
#1229435
05/08/12 10:16 PM
05/08/12 10:16 PM
Posts: 7,664 IN
ahy
IN
[Re: woody02]
#1229437
05/09/12 10:30 AM
05/09/12 10:30 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Most roller rockers dont fit any of the Edelbrock heads correctly. If you take any of the commercially available roller rockers, you'll see they are way off on the sweep pattern. Most people say " they worked fine for me", but in fact, they havent ever properly checked the roller tip sweep. This also stands true with some of the small block heads out there. Will they " work" ? Sure. Did you check the valve sweep? Probably not. Simply, they will open and close the valve, and for some thats ok. I like to have the geometry better fitted. I have had, used mocked up, ran, broken, diagnosed about every rocker set up out there. They all have their good and bad points. As far as Eddy roller rockers, I had Harland Sharp make rockers that fit the RPM heads correctly. The only ones I havent used are the newer Hughes rockers, so I cant say on theirs. I do a fair share of Eddy combos and I can tell you that most of them need some correction or a rocker that is suited for them. ( to be 100% correct). When Crane went under, I started working with H/S on a new unbushed rocker. I was using BBC blanks, and was correcting both geometry and oiling, to better suit Mopars. During that time, it appears a parts house decided to come out with a non bushed rocker. I decided to not persue it after I find that out. I wasnt going to compete with them on that platform, as they typically want to sell things cheap. I had a better design, but it was going to put my sell price above theirs, and I wasnt interested in fighting for the sales. I think they basically copied Crane, where as I was making changes to make a better piece. I corrected geometry, improved oiling, and went with hi quality shafts. Nuff said. RHS iron SBM heads fall into the same category. Take just about any rocker out there, and you'll see nothing fits them correctly. The bets fitting rocker for them, which is almost perfect is the Indy rocker believe it or not. I deal with these things in circle track applications, so I see what happens on them.SB Eddys are the same. Long story short, check the valve tip roller sweep.You'll find issues most likely, and you'll want a set that fits correctly. For a simple hydraulic cam, you may just end up using stamped steel rockers, which will work typically fine for street use. I use an assortment of shims when using the stamped steel on Eddys to better align them, and tighten them up a bit across the shafts
RIP Monte Smith
[Re: CompWedgeEngines]
#1229438
05/09/12 01:47 PM
05/09/12 01:47 PM
Posts: 344 PA
noplanb
PA
Points well taken. The Hughes 1.5 geometry was close but not quite there on a zero-decked 493. Shims took care of it.
remember when you said honey, some day that car is gonna look so good in front of our house
[Re: woody02]
#1229440
05/09/12 04:54 PM
05/09/12 04:54 PM
Posts: 5,080 organ
maximum entropy
organ
some roller rockers interfere with the rocker shaft towers on eddie heads. harlands for sure, and i had a set of chinese rollers that required some head relief.
[Re: maximum entropy]
#1229441
05/09/12 11:09 PM
05/09/12 11:09 PM
Posts: 1,377 Ohio
Todd
Ohio
Had to trim the mount on the eddy heads to clear the harland sharp rockers. Just on the end mount IIRC
