what roller rocker do i use for eddy heads #1229425
05/08/12 12:45 PM
05/08/12 12:45 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
i went to use the roller rockers off my 906 heads,440 and they dont fit the eddy rpm heasds right.can i get a few options from guys who bought roller rockers,what type they used on there 440?. i have hydrolic flat tappet cam.thanks again guys
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229426
05/08/12 12:53 PM
05/08/12 12:53 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What doesn't fit? Eddy rpm heads are supposed to take stock rockers.
Re: what roller rocker do i use for eddy heads [Re: DaytonaTurbo] #1229427
05/08/12 01:16 PM
05/08/12 01:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said.
What is not fitting and what rockers do you have?
Re: what roller rocker do i use for eddy heads [Re: DaytonaTurbo] #1229428
05/08/12 04:13 PM
05/08/12 04:13 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Stock rockers aren't adjustable though.
I went through this two weeks ago with my build (RPM heads) the problem was even though my ductiles were shimmed properly to my 906s, the rocker itself was rubbing on the pedestal of the RPM heads. I use shims & spacers, not springs. I spent about 10 hours removing, installing, tightening over and over again until I noticed where the problem was. Went to my spare parts closet and pulled my Harland Sharp Rollers I had set aside (luckily I had them). I got them from Todd at Competition Wedge Racing. Fit like a glove. They do have to be setup for RPM heads though. I didnt have to shim anything....from the package, to the oil bath, to the heads. Put it altogether and dropped a bottle of zinc additive to the oil...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: what roller rocker do i use for eddy heads [Re: Pyper70] #1229429
05/08/12 04:58 PM
05/08/12 04:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Harland Sharp 1.6s in mine. No problems.
Re: what roller rocker do i use for eddy heads [Re: topside] #1229430
05/08/12 06:08 PM
05/08/12 06:08 PM
PA
noplanb Offline
noplanb  Offline
PA
Hughes. No issues.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: what roller rocker do i use for eddy heads [Re: noplanb] #1229431
05/08/12 08:48 PM
05/08/12 08:48 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I've got stock stamped steel rockers with the mp484 cam in the challenger with eddy rpms. Been that way for four or five years now....
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229432
05/08/12 09:36 PM
05/08/12 09:36 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Hughes will take your money-just don't bother calling 'em...
Harland-Sharp all the way...
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229433
05/08/12 09:41 PM
05/08/12 09:41 PM
AndyF Offline
AndyF  Offline
With a small hyd cam you could just use the factory stamped rocker arms. If you want roller rockers then stop by Mancini and take a look. They carry about a dozen different brands of rocker arms. Personally I'd only use the Hughes rocker arms, but opinions vary I suppose.
Re: what roller rocker do i use for eddy heads [Re: AndyF] #1229434
05/08/12 09:54 PM
05/08/12 09:54 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
CompCams on mine.
Ride eternal, shiny and chrome
Re: what roller rocker do i use for eddy heads [Re: DirectSubjection] #1229435
05/08/12 10:16 PM
05/08/12 10:16 PM
IN
ahy Offline
ahy  Offline
IN
Com Cam steel on mine.
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229436
05/08/12 11:44 PM
05/08/12 11:44 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Crane Gold Race 1.6 ratio
I bought these for my OOTB Eddy heads 7-8 years ago.
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229437
05/09/12 10:30 AM
05/09/12 10:30 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Most roller rockers dont fit any of the Edelbrock heads correctly. If you take any of the commercially available roller rockers, you'll see they are way off on the sweep pattern. Most people say " they worked fine for me", but in fact, they havent ever properly checked the roller tip sweep. This also stands true with some of the small block heads out there. Will they " work" ? Sure. Did you check the valve sweep? Probably not. Simply, they will open and close the valve, and for some thats ok. I like to have the geometry better fitted. I have had, used mocked up, ran, broken, diagnosed about every rocker set up out there. They all have their good and bad points. As far as Eddy roller rockers, I had Harland Sharp make rockers that fit the RPM heads correctly. The only ones I havent used are the newer Hughes rockers, so I cant say on theirs.
I do a fair share of Eddy combos and I can tell you that most of them need some correction or a rocker that is suited for them. ( to be 100% correct).
When Crane went under, I started working with H/S on a new unbushed rocker. I was using BBC blanks, and was correcting both geometry and oiling, to better suit Mopars. During that time, it appears a parts house decided to come out with a non bushed rocker. I decided to not persue it after I find that out. I wasnt going to compete with them on that platform, as they typically want to sell things cheap. I had a better design, but it was going to put my sell price above theirs, and I wasnt interested in fighting for the sales. I think they basically copied Crane, where as I was making changes to make a better piece. I corrected geometry, improved oiling, and went with hi quality shafts. Nuff said.
RHS iron SBM heads fall into the same category. Take just about any rocker out there, and you'll see nothing fits them correctly. The bets fitting rocker for them, which is almost perfect is the Indy rocker believe it or not. I deal with these things in circle track applications, so I see what happens on them.SB Eddys are the same.
Long story short, check the valve tip roller sweep.You'll find issues most likely, and you'll want a set that fits correctly.
For a simple hydraulic cam, you may just end up using stamped steel rockers, which will work typically fine for street use. I use an assortment of shims when using the stamped steel on Eddys to better align them, and tighten them up a bit across the shafts
RIP Monte Smith
Re: what roller rocker do i use for eddy heads [Re: CompWedgeEngines] #1229438
05/09/12 01:47 PM
05/09/12 01:47 PM
PA
noplanb Offline
noplanb  Offline
PA
Points well taken. The Hughes 1.5 geometry was close but not quite there on a zero-decked 493. Shims took care of it.
Re: what roller rocker do i use for eddy heads [Re: noplanb] #1229439
05/09/12 02:24 PM
05/09/12 02:24 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
well i went with prw.guess well see how they fit
Re: what roller rocker do i use for eddy heads [Re: woody02] #1229440
05/09/12 04:54 PM
05/09/12 04:54 PM
organ
maximum entropy Offline
organ
some roller rockers interfere with the rocker shaft towers on eddie heads. harlands for sure, and i had a set of chinese rollers that required some head relief.
Re: what roller rocker do i use for eddy heads [Re: maximum entropy] #1229441
05/09/12 11:09 PM
05/09/12 11:09 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Had to trim the mount on the eddy heads to clear the harland sharp rockers. Just on the end mount IIRC
Re: what roller rocker do i use for eddy heads [Re: Todd] #1229442
05/10/12 12:20 AM
05/10/12 12:20 AM
IN
ahy Offline
ahy  Offline
IN
I'd just add that the Comp steel rocker had good sweep over the valve tip in my Ed head application. I did have to adjust lateral or sideways position with shims on the rocker shaft.
