MSD E-Curve for Mopar BB???? #1229340
05/08/12 10:56 AM
05/08/12 10:56 AM
Iowa, US
oldsklharo Offline OP
Iowa, US
Is there a way to modify the MSD E-Curve SB dist so it can be used in a BB 383? Is there an adapter or kit of some kind that takes a SB dist to a BB compatable? I know you can use the spacer set up to go from the RB to B's but what about from SB to BB?
I really like that E-Curve dist but they don't make one for the B motors!!
Thanks, Mike
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229341
05/08/12 11:12 AM
05/08/12 11:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Smallblock is very close in size to a 440 distributor but it is designed to spin in the opposite direction so the problem would be wit hthe mechanical advance. I'd have to see one to see if parts could be changed around.
But I agree , they should be making these for BB 's
Re: MSD E-Curve for Mopar BB???? [Re: JohnRR] #1229342
05/08/12 11:42 AM
05/08/12 11:42 AM
Iowa, US
Iowa, US
Damn, sounds like it's to likely to make one work
I spoke to MSD this morning........ I assume they are making them for the race guys that mainly run SB Chrysler.
Are there any other brands that are making a digital dist for the BB?
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229343
05/08/12 01:01 PM
05/08/12 01:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I really like the E-Curve in my 416 small block.
But be warned. Do not use that distributor with the new MSD solid state coils. They do not work together. You have to run a oil filled blaster type coil per MSD as SEMA. Learned that the hard way.
Re: MSD E-Curve for Mopar BB???? [Re: autoxcuda] #1229344
05/08/12 04:14 PM
05/08/12 04:14 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: MSD E-Curve for Mopar BB???? [Re: autoxcuda] #1229345
05/08/12 09:38 PM
05/08/12 09:38 PM
AndyF Offline
AndyF  Offline
We run this setup on Tim's 427 and haven't seen any issues. I really like the e-curve. I don't know why they don't make a big block version. It would out sell the small block version by 5x. I asked MSD why they don't sell a big block version and they just said it was on the list of things to do someday.
Re: MSD E-Curve for Mopar BB???? [Re: AndyF] #1229346
05/09/12 12:04 AM
05/09/12 12:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Per MSD, the early versions like AndyF have worked with the Solid State coil that is pictured above. But the newer version do not. As of the 2011 SEMA show, the SS coils did not work with E-Curves.
Re: MSD E-Curve for Mopar BB???? [Re: autoxcuda] #1229347
05/09/12 12:09 AM
05/09/12 12:09 AM
AndyF Offline
AndyF  Offline
Good to know. I wasn't aware that they changed the distributor. I think these e-curves are the way to go for a street car. If they made a big block one I'd buy it. I like having 100 curves to pick from as well as having a digital vacuum advance. Super cool product.
Re: MSD E-Curve for Mopar BB???? [Re: AndyF] #1229348
05/09/12 06:45 PM
05/09/12 06:45 PM
Iowa, US
Iowa, US
Anyone know what the time frame is with MSD making these for the BB.....if ever?
Also, does anyone else make a similar one with the same features for the BB?
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229349
05/09/12 07:30 PM
05/09/12 07:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
timeframe ... someday ...
If someone made one like it then there would be little need for it and it would only make someday become some year.
Re: MSD E-Curve for Mopar BB???? [Re: JohnRR] #1229350
05/09/12 09:36 PM
05/09/12 09:36 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I think everyone who would buy one needs to contact MSD and tell them. I'd buy one, and I intend on telling them that.
Travis..
EDIT, just tryed to contact them and couldn't find a contact email. I just registered on their forum and will post up a thread about a BB e-curve in their suggestion forum when my acct is activated.
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: MSD E-Curve for Mopar BB???? [Re: phantomx] #1229351
05/10/12 05:57 AM
05/10/12 05:57 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Maybe the Firecore guys will step up?
Re: MSD E-Curve for Mopar BB???? [Re: jbc426] #1229352
05/10/12 12:33 PM
05/10/12 12:33 PM
Iowa, US
Iowa, US
Well I just called MSD again and they told me they have NO plans of making the E-Curve for the BB
Maybe I could get the SB one and have a BB shaft fit or machine one that will work? Whatcha think????
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229353
05/10/12 01:07 PM
05/10/12 01:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it was only that easy .
Buy one and see what is required to make it work spinning in the opposite direction that it's designed for and report back .
Re: MSD E-Curve for Mopar BB???? [Re: JohnRR] #1229354
05/10/12 01:23 PM
05/10/12 01:23 PM
Iowa, US
Iowa, US
I'm thinking about buying the E-Curve and an 8545 and swapping the shafts out somehow.......I'll call them again to see if the spinning in the opposite direction would effect the function of the E first though
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229355
05/10/12 01:24 PM
05/10/12 01:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Someone should do some investigating into Crane's 1000-1802/3 B/RB distributors and see if they'll do what you're looking for.
EDIT: This might help: http://www.enginebuildermag.com/Article/...plications.aspx
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229356
05/10/12 01:31 PM
05/10/12 01:31 PM
Iowa, US
Iowa, US
I just talked to an MSD Tech guy and he says the E-Curve will definitely function properly spinning in the opposite direction of it's intended use. He also have me the P/N for the 8545 ready to run shaft instead of buying an entire dist.
So, I am going to pick up the SB E and the BB shaft and figure out a way to mate them properly
I'll report back once I get it figured out..........
Re: MSD E-Curve for Mopar BB???? [Re: oldsklharo] #1229357
05/10/12 07:36 PM
05/10/12 07:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is the part number for the smallblock E curve distributor ?
Re: MSD E-Curve for Mopar BB???? [Re: autoxcuda] #1229358
05/11/12 01:02 PM
05/11/12 01:02 PM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
Seems like a step in wrong direction?
Re: MSD E-Curve for Mopar BB???? [Re: Charger727] #1229359
05/11/12 01:13 PM
05/11/12 01:13 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I wonder if the E-curve will get all rusty inside like the MSD distributor I already have.
