Page 1 of 3 1 2 3
1st time on track little dissapointed #1229127
05/07/12 10:50 PM
05/07/12 10:50 PM
Queensland,Australia
T-bar Online content OP
T-bar  Online Content OP
Hey all, i had my 70 Cuda out for the first time at an 1/8th mile track on the weekend and was a little disappointed on the results. I know this can be open ended question but can you give me some ideas on what i can do to get the times lower.
The best time was 7.57 at 92.98 mph and 60ft 1.72.
A few of the other runs were close to that area as well.
Now the combo is
496rb
10.5 compression
flat tappet .565" lift on both and .274 deg @ .50
eddy rpm performer heads with light porting (no flow numbers)
440 victor intake
1050 quick fuel carb 4150
converter stalls around 3500 (unsure)
727 full manual
3.91 diff gears
295/65r15 mickey thompson et's
So any thoughts?
Re: 1st time on track little dissapointed [Re: T-bar] #1229128
05/07/12 10:58 PM
05/07/12 10:58 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Needs 4.10 gear or more and about 5000 stall converter. Not ideal for street driving though.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 1st time on track little dissapointed [Re: T-bar] #1229129
05/07/12 11:07 PM
05/07/12 11:07 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Congrat on getting to run your car! The 60ft seems a little slow. What is done to the suspension? What does the car weigh? I'm guessing you're giving up a good amount of time with the wrong torque converter (in the 60ft). Kevin
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: 1st time on track little dissapointed [Re: 69dart] #1229130
05/07/12 11:09 PM
05/07/12 11:09 PM
Thanks for the reply, i don't really want to get lower gears but i was thinking of a 28" tall tyre would that get the gearing down enough? Was also trying to get a higher stall but don't want to buy new just yet because thinking of upgrading the cam.
Re: 1st time on track little dissapointed [Re: T-bar] #1229131
05/07/12 11:13 PM
05/07/12 11:13 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Unless you have alot of glass components....too much cam for a heavy car...
Not enough gear, converter or compression for that cam...
4.10s at a minimum, 5k flash at a minimum and IMO 11.0-11.5 comp.
4.10s and a quality 8inch WILL drive fine and dandy on the street....Although IMO with 500 cubes the gear isnt the deal breaker w 28 inch tire...with 30 inch tires 4.10s-4.30s.
Your combo (when right and if the heads are decent to good) should go 10s...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 1st time on track little dissapointed [Re: T-bar] #1229132
05/07/12 11:14 PM
05/07/12 11:14 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
You might want to go with a little less duration at .050" and a tighter lobe separation, say 265* at .050" and a 106 to 108 lca advanced 4* to really provide some grunt for those gears and converter.
Re: 1st time on track little dissapointed [Re: mopar400] #1229133
05/07/12 11:15 PM
05/07/12 11:15 PM
Hay Kevin, yes it's been two years since i got the car and had a ball racing again as it's been about twenty years between runs. The car weighs 3630 with me in, standard springs that have been reset down, with kyb gas adjustable shocks on rear and standard shocks on the front. It launched fairly even and straight.
Re: 1st time on track little dissapointed [Re: moparmanjames] #1229134
05/07/12 11:26 PM
05/07/12 11:26 PM
I've had thoughts on pulling the heads have some more work done and bumping the compression up and changing to a roller cam in the future. So would a gear and convertor change bring the time down much? in it's current state.
Re: 1st time on track little dissapointed [Re: T-bar] #1229135
05/07/12 11:31 PM
05/07/12 11:31 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
1) 60' is too slow ( gear and converter plus.....)
2) carb is too big
3) I dont think the cam is that big of a problem
( at this point, albeit a 496 could handle more cam, but you dont have a lot of compression, so there is a compromise going on there)
Work on 60' first, then the rest will come around. Your MPH indicates low 11's, but wont get there with that 60'
Make one change at a time. Dont overcam the heads, if they havent really been ported.
What LSA is the cam, and how is it installed?
RIP Monte Smith
Re: 1st time on track little dissapointed [Re: T-bar] #1229136
05/07/12 11:34 PM
05/07/12 11:34 PM
What kind of distributor/ignition and curve do you have in it?
I've seen guys drop loads of money on engine, trans and a gear only to put a stock advance distributor in the hole.
Re: 1st time on track little dissapointed [Re: T-bar] #1229137
05/07/12 11:39 PM
05/07/12 11:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree on the duration being big for you...get the front
loose so it will lift and transfer the weight.. that
will help your 60'(your probably spinning with a 1.72)
Re: 1st time on track little dissapointed [Re: T-bar] #1229138
05/07/12 11:39 PM
05/07/12 11:39 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
yes a gear will be easy and make a huge difference,
have you gotten alot of wheel spin? on that 1.76 launch?
its a heavy car but at the cubes your using...it should go faster for sure..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 1st time on track little dissapointed [Re: CompWedgeEngines] #1229139
05/07/12 11:49 PM
05/07/12 11:49 PM
The info of the internals of the motor are what the bloke i bought it off said it was so i can only go on this but the cam is degreed at
-3.0 and with 114lc thats all i got in that regards. The ignition is an electronic msd unit with 6a box and blaster 2 coil. I did have the car on a chassis dyno before i raced it and the a/f ratio was good but it did only manage 385 rwhp at it's best.
Re: 1st time on track little dissapointed [Re: CompWedgeEngines] #1229140
05/07/12 11:49 PM
05/07/12 11:49 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
2) carb is too big
I was thinking the same thoughts by comparing his times to my car. My car weighs the same and just has a mild 440 with 11:1 comp., iron 452 heads and a 509 purple shaft, 4.30 gears and 29.5 slicks. It would run 7.20's pretty consistant (best 6.99). I would think he would be making a good deal more power. His 1/8 MPH is pretty good. I think he should be doing atleast low 1.6's in the 60ft. I would do some suspension tweaking and maybe some 28" slicks to start.
Re: 1st time on track little dissapointed [Re: cheapstreetdustr] #1229141
05/07/12 11:53 PM
05/07/12 11:53 PM
On the first run i did have a lot wheel spin so dropped the tyres down to 15lb and pretty much fixed the spin. If it did spin it would of being tiny. I haven't raced for so long i was still trying to get my self settled as well.
Re: 1st time on track little dissapointed [Re: T-bar] #1229142
05/08/12 12:11 AM
05/08/12 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With the specs you said, that cam is for a blower engine...
you dont want a 114 LSA cam and with that duration
your cylinder pressure is WAY down... the piston is
up to far in the bore when the intake valve closes
Re: 1st time on track little dissapointed [Re: T-bar] #1229143
05/08/12 12:21 AM
05/08/12 12:21 AM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Wow. With that info I agree with the others! It's time for a cam swap!
Re: 1st time on track little dissapointed [Re: mopar400] #1229144
05/08/12 01:25 AM
05/08/12 01:25 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If that cam is installed 3 degrees retarded from the 114 LSA, it's NEVER gonna run without about a 300 hit of juice at the hit!
92mph in the 1/8th with a 496??? It's SLOW. 3300# a bodies with 450-480hp run in the 95-98 range.
Re: 1st time on track little dissapointed [Re: RobX4406] #1229145
05/08/12 02:24 AM
05/08/12 02:24 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I agree with Mike, you may see a big improvement in bottom end with just re setting the cam straight up or a couple of degree's advanced, it's alot cheaper than a bunch of new parts.
Re: 1st time on track little dissapointed [Re: dartman366] #1229146
05/08/12 04:40 AM
05/08/12 04:40 AM
Well that gives me a good place to start thanks for the replies. I'm gonna get some 28" tall tyres as a start but i think i will do some investigation in the cam area. Again thankyou.
Page 1 of 3 1 2 3
