Re: Fresh 904 Sluggish "slipping" and soft 1-2 shift...
[Re: MoparforLife]
#1229001
05/07/12 06:47 PM
05/07/12 06:47 PM
Posts: 509 Middle River, MD
Mapandjlp
Middle River, MD
KD linkage hooked up?? That is what governs the throttle pressure for proper shifting. If not hooked up and adjusted correctly the shifts will be soft and spungy. Also short transmission life.
Sorry, should have mentioned that the throttle pressure linkage is hooked up and adjusted properly - lever is fully engaged at WOT.
[Re: Mapandjlp]
#1229002
05/08/12 12:02 AM
05/08/12 12:02 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Kinda sounds like you don't have enough line pressure (adjusted on the side of the valve body).
Eric
[Re: Erics5th]
#1229004
05/08/12 08:45 AM
05/08/12 08:45 AM
Mapandjlp
Middle River, MD
That's what I was thinking but I adjusted it (counterclockwise several turns actually) to the level that was suggested by the kit.
I did add an aftermarket trans cooler in line with the rad cooler. Could the extra length be causing a drop in pressure?
[Re: JohnRR]
#1229006
05/08/12 02:13 PM
05/08/12 02:13 PM
Mapandjlp
Middle River, MD
What does a TCI trans scat kit consist of ?
For the 904, it was just a matter of enlarging a couple of holes in the seperator plate, drilling a hole in the valve body (basically joining two passages that weren't joined before), replacing the 1/2 shift governor, installing a smaller plug in the direct drum fluid passage, and cranking up the line pressure. Here's the install manual http://news.compperformance.com/Instructions/220000.pdf
[Re: Mapandjlp]
#1229007
05/08/12 04:41 PM
05/08/12 04:41 PM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
That doesn't always mean its adjusted correctly is this 1 piece or 3 piece linkage
[Re: Mapandjlp]
#1229008
05/08/12 05:01 PM
05/08/12 05:01 PM
Posts: 25,898 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Did you air check the trans prior to installing the VB?
If you're in doubt about the line pressure, hook up a test gauge and check it. If it's good, remove the VB and do an air check.
[Re: JohnRR]
#1229009
05/08/12 05:04 PM
05/08/12 05:04 PM
Mapandjlp
Middle River, MD
It's one piece linkage. It all worked fine before I pulled it for the rebuild (other than the fact that the trans had 140k on it and needed a freshening).
[Re: John_Kunkel]
#1229010
05/08/12 05:05 PM
05/08/12 05:05 PM
Mapandjlp
Middle River, MD
Forgive my ignorance but what's an air check and how do I perform one?
[Re: Mapandjlp]
#1229013
05/10/12 10:33 AM
05/10/12 10:33 AM
JohnRR
U.S.S.A.
With a rubber-tipped blow gun you introduce air into the various passages in the case to apply the bands/clutches and listen for big air leaks.
Thanks, John. The kit I used had me install a plug with a smaller hole in it into the front clutch apply passage in the case. Any idea what the purpose of this was?
Not the john you questioned , but that plug is to slow the apply of the front clutch due to the increase in line pressure making it happen faster without it . It would not cause the sluggish feel or cause your soft 1-2 shift.
[Re: Mapandjlp]
#1229015
05/10/12 08:35 PM
05/10/12 08:35 PM
JohnRR
U.S.S.A.
I spoke with Mr. John Cope of Cope Racing Transmissions today. We discussed several different scenarios and based on our conversation, I decided to pull the valve body and have a look at where I had the line pressure adjustment set. According to the TCI Trans-Scat kit I used, the distance between the spring plate and the valve body was to be 1 3/8". I used this as my guide. According to Mr. Cope, the maximum should be six turns from the point where the spring plate is flush with the bracket. Mr. Cope told me that you can actually have too much pressure on the valve causing the opposite effect.
I adjusted the plate according to the advice from John Cope. I also re-adjusted the low/reverse band. These two changes seem to have fixed my problem.
Thanks to all of you who helped!
Did you readjust the FRONT band ? the low reverse band is only used in reverse and when you have the trans shifted into L ... low, it is not applied if the trans is in D ...drive.
[Re: JohnRR]
#1229016
05/11/12 08:51 AM
05/11/12 08:51 AM
Mapandjlp
Middle River, MD
Yep, that's the first thing I did when I knew it wasn't acting quite right.
