Gears for rear end? #1228938
05/07/12 03:39 PM
05/07/12 03:39 PM
Canada
Flatblack Offline OP
Canada
My dads friend thought he had a set of 3.91 gears for my 72 charger, but he figured they would not go with my 12 bolt. So then he found a set of 3.55 gears in a 14 bolt out of a 73 road runner or satellight?
I am just seeking some clarity to figure out what a good set of gearing ratio would be suitable for my 72 charger. Curious who has used what and what they think of it?
thanks Josh K.
Thankx, just a student trying to save a buck! flatblack68@gmail.com
Re: Gears for rear end? [Re: Flatblack] #1228939
05/07/12 03:41 PM
05/07/12 03:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I like 3:55 for my street cars.
Re: Gears for rear end? [Re: Flatblack] #1228940
05/07/12 03:51 PM
05/07/12 03:51 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
What engine and mods?
Highway or in town?
Don't go too low, (or high numerically.)
thanks Josh K.
Re: Gears for rear end? [Re: fox] #1228941
05/07/12 07:59 PM
05/07/12 07:59 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i think most agree 355 is a good street/strip gear
Re: Gears for rear end? [Re: fox] #1228942
05/07/12 08:03 PM
05/07/12 08:03 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I have 3.55's in my wagon. 440/727. It is a good all around gear for street and some highway. I am turning about 3000rpm at 60 or so mph. 295-50/15 drive tires.
Scott
1969 Super Bee, 383/4 speed
Re: Gears for rear end? [Re: Flatblack] #1228943
05/07/12 08:04 PM
05/07/12 08:04 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
depends on how you're planning on driving it. If you plan on running it at the drag strip frequently, and not doing as much driving around town/highway.. then go for the 3.91's.
If you're looking for a good 'compromise' gear ratio, that will give you a good ratio for around town/highway driving as well as decent off-the-line performance, go with the 3.55's. That's what I've got in mine (not that I've ever driven it, but that's what I've got)
Re: Gears for rear end? [Re: Flatblack] #1228944
05/07/12 08:13 PM
05/07/12 08:13 PM
Canada
Canada
thanks guys!
Re: Gears for rear end? [Re: Flatblack] #1228945
05/07/12 10:27 PM
05/07/12 10:27 PM
IN
ahy Offline
ahy  Offline
IN
I think 3.55 works well with taller tires... 27-28". With tire diameter near original 25" or so 3.23 works better.
Re: Gears for rear end? [Re: Flatblack] #1228946
05/08/12 03:22 AM
05/08/12 03:22 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Automatic trans? Stall speed? Tie size? Cam specs?
Ride eternal, shiny and chrome
