Installing Battery In Trunk Wire Size ?
#1228473
05/07/12 09:54 AM
05/07/12 09:54 AM
Posts: 892 USA
krw71ragtop
USA
What guage wire should I use for the battery mounted in the trunk ? Any other tips would be apppreciated. ![](/ubbthreads/images/graemlins/thumbs.gif) I'll need 15' of wire and it's for an A-body.
Re: Installing Battery In Trunk Wire Size ?
[Re: fullmetaljacket]
#1228475
05/07/12 10:27 AM
05/07/12 10:27 AM
Posts: 892 USA
krw71ragtop
USA
I run the #0 gauge. You can also run #1 gauge. Make sure to make radius bends and attach at every 16 inches with a clamp. Also make sure to use heat shrink wrap at the terminals. You'll have to install a shut off switch if you intend on going to the track to race.
Looks like I need to add a shut off switch and some clamps to my list. Was leaning towards the #0 wire. Thanks for the help. Anyone else ?
[Re: Clanton]
#1228477
05/07/12 10:44 AM
05/07/12 10:44 AM
Posts: 892 USA
krw71ragtop
USA
are you talking the cable to the starter or to the alt?
The cable from the starter to the battery in the trunk. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Crizila]
#1228479
05/07/12 12:07 PM
05/07/12 12:07 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
For a 15' run 1 gauge is plenty. Don't want to carry the extra weight if you don't need to.
how much weight could it be 1.lb# go pee before you get in the car. i have a 0# cable but have more cranking demands.I have a #4 from the alt to the battery and to the power switch for fuel,fan,water... ![](/ubbthreads/images/graemlins/shruggy.gif)
#1228480
05/07/12 01:38 PM
05/07/12 01:38 PM
Posts: 892 USA
krw71ragtop
USA
Where do you mount the shut off switch ?
#1228481
05/07/12 01:38 PM
05/07/12 01:38 PM
Posts: 892 USA
krw71ragtop
USA
[Re: jamesc]
#1228484
05/07/12 02:37 PM
05/07/12 02:37 PM
Posts: 892 USA
krw71ragtop
USA
the switch should be mounted in the back with the battery and it needs to shut the car off so there are implications with the alternator circuit so it doesn't keep the car running.
Would you have a wiring diagram of this whole modification ? Sounds like it's starting to get complicated !
[Re: krw71ragtop]
#1228485
05/07/12 03:55 PM
05/07/12 03:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The simplest way to do this is to run the alt output wire to the back and hook it up to the battery side of the master shut off switch... that will kill it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1228486
05/07/12 04:05 PM
05/07/12 04:05 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I am running a 2 gauge wire for the starter and another 2 guage wire to my distribution panel. Seems to be adequate, I have had zero trouble from either side. I run a ford solenoid in the trunk so the starter wire is only hot when the starter button is pushed.
Between moving the starter solenoid to the trunk and having my relay panel inside the car it really took a bunch of wires out of the engine compartment.
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#1228487
05/07/12 04:29 PM
05/07/12 04:29 PM
Posts: 5,875 communist bloc of new jersey
jamesc
that is the least complicated but it leaves the alternator output line hot at all times. personally i would use a two pole battery switch and use the second pair of small terminals to control the field with a relay assuming it's not a single wire. if it has a field line you can use a relay with a small line from the two pole switch to run the relay. i know it sounds complicated to people not familiar with electrical but it's rather simple. what type of alternator are you using?
here's an example of what type of switch i mentioned
![](http://www.colehersee.com/assets/products/battery_related/M-290-05.jpg)
#1228489
05/07/12 08:19 PM
05/07/12 08:19 PM
Clanton
northern,Ohio,USA
I have my cut off switch installed on the back valance panel near the License plate just below the trunk lid. This is on a early B-Body now. Because of its double agent life as a street/strip car, the switch is mounted discreetly but yet visible for an emergency by track officials or fellow racers that know where to look for it more or less. Remember, that the switch has to have visible ON/OFF markings on the body panel that it is attached to.
it would be funny to have a license plate saying on off and have the switch under it.well funny to me anyways. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Clanton]
#1228492
05/08/12 08:50 AM
05/08/12 08:50 AM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
I agree 1 gauge at minimum.0 gauge is better for bot ground and hot.For the alt bun 10 or 8 gauge.If you have to worry about the little weight from 1 to 0 you need a bigger motor.Rocky
Chrysler Firepower
