Installing Battery In Trunk Wire Size ? #1228473
05/07/12 09:54 AM
05/07/12 09:54 AM
USA
K
krw71ragtop Offline OP
K
USA
What guage wire should I use for the battery mounted in the trunk ? Any other tips would be apppreciated.
I'll need 15' of wire and it's for an A-body.
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228474
05/07/12 10:00 AM
05/07/12 10:00 AM
fullmetaljacket Offline
I run the #0 gauge. You can also run #1 gauge. Make sure to make radius bends and attach at every 16 inches with a clamp. Also make sure to use heat shrink wrap at the terminals.
You'll have to install a shut off switch if you intend on going to the track to race.
Re: Installing Battery In Trunk Wire Size ? [Re: fullmetaljacket] #1228475
05/07/12 10:27 AM
05/07/12 10:27 AM
USA
K
K
USA
Looks like I need to add a shut off switch and some clamps to my list. Was leaning towards the #0 wire. Thanks for the help. Anyone else ?
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228476
05/07/12 10:36 AM
05/07/12 10:36 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
are you talking the cable to the starter or to the alt?
Re: Installing Battery In Trunk Wire Size ? [Re: Clanton] #1228477
05/07/12 10:44 AM
05/07/12 10:44 AM
USA
K
K
USA
The cable from the starter to the battery in the trunk.
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228478
05/07/12 11:36 AM
05/07/12 11:36 AM
Az
Crizila Offline
Crizila  Offline
Az
For a 15' run 1 gauge is plenty. Don't want to carry the extra weight if you don't need to.
Fastest 300
Re: Installing Battery In Trunk Wire Size ? [Re: Crizila] #1228479
05/07/12 12:07 PM
05/07/12 12:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
how much weight could it be 1.lb# go pee before you get in the car. i have a 0# cable but have more cranking demands.I have a #4 from the alt to the battery and to the power switch for fuel,fan,water...
Re: Installing Battery In Trunk Wire Size ? [Re: fullmetaljacket] #1228480
05/07/12 01:38 PM
05/07/12 01:38 PM
USA
K
K
USA
Where do you mount the shut off switch ?
Re: Installing Battery In Trunk Wire Size ? [Re: fullmetaljacket] #1228481
05/07/12 01:38 PM
05/07/12 01:38 PM
USA
K
K
USA
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228482
05/07/12 01:44 PM
05/07/12 01:44 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the switch should be mounted in the back with the battery and it needs to shut the car off so there are implications with the alternator circuit so it doesn't keep the car running.
Re: Installing Battery In Trunk Wire Size ? [Re: jamesc] #1228483
05/07/12 02:01 PM
05/07/12 02:01 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
What he said...
I am running 1 gauge.
383, Hemi 4-Speed, AlterKtion, D60
Re: Installing Battery In Trunk Wire Size ? [Re: jamesc] #1228484
05/07/12 02:37 PM
05/07/12 02:37 PM
USA
K
K
USA
Would you have a wiring diagram of this whole modification ? Sounds like it's starting to get complicated !
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228485
05/07/12 03:55 PM
05/07/12 03:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The simplest way to do this is to run the alt output
wire to the back and hook it up to the battery side
of the master shut off switch... that will kill it
Re: Installing Battery In Trunk Wire Size ? [Re: MR_P_BODY] #1228486
05/07/12 04:05 PM
05/07/12 04:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am running a 2 gauge wire for the starter and another 2 guage wire to my distribution panel. Seems to be adequate, I have had zero trouble from either side. I run a ford solenoid in the trunk so the starter wire is only hot when the starter button is pushed.
Between moving the starter solenoid to the trunk and having my relay panel inside the car it really took a bunch of wires out of the engine compartment.
68 Barracuda Formula S 340
Re: Installing Battery In Trunk Wire Size ? [Re: MR_P_BODY] #1228487
05/07/12 04:29 PM
05/07/12 04:29 PM
jamesc Offline
jamesc  Offline
that is the least complicated but it leaves the alternator output line hot at all times. personally i would use a two pole battery switch and use the second pair of small terminals to control the field with a relay assuming it's not a single wire. if it has a field line you can use a relay with a small line from the two pole switch to run the relay. i know it sounds complicated to people not familiar with electrical but it's rather simple. what type of alternator are you using?
here's an example of what type of switch i mentioned
Re: Installing Battery In Trunk Wire Size ? [Re: jamesc] #1228488
05/07/12 08:04 PM
05/07/12 08:04 PM
I have my cut off switch installed on the back valance panel near the License plate just below the trunk lid. This is on a early B-Body now. Because of its double agent life as a street/strip car, the switch is mounted discreetly but yet visible for an emergency by track officials or fellow racers that know where to look for it more or less.
Remember, that the switch has to have visible ON/OFF markings on the body panel that it is attached to.
Re: Installing Battery In Trunk Wire Size ? [Re: fullmetaljacket] #1228489
05/07/12 08:19 PM
05/07/12 08:19 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
it would be funny to have a license plate saying on off and have the switch under it.well funny to me anyways.
Re: Installing Battery In Trunk Wire Size ? [Re: Clanton] #1228490
05/07/12 10:30 PM
05/07/12 10:30 PM
USA
K
K
USA
Thanks for all the input. This modification is going to be more work and expense than I thought it would. But done the right way I suppose would be worth it. I realize it's for safety reasons, but I'm just trying to lighten the front end up some more. I'm at the point where I have to decide if this is going to be a race car or street car. Race track rules are really slowing me down if you know what I mean ! I could still switch to manual steering, and change the stock alternater too loose a few pounds. Putting a kill switch on the tail panel kind of gives away that granny car look. Thanks again for all the comments from everyone. I've learned a lot from it and now understand what needs to be done when the time comes.
Re: Installing Battery In Trunk Wire Size ? [Re: krw71ragtop] #1228491
05/08/12 12:08 AM
05/08/12 12:08 AM
Take an afternoon to study the rear end facade of the car and invent a sneaky way to install the set up. Lots of guys have installed the set up in a unique way that doesn't give away the look. You would have to look hard to find my install in the scope of things.
Taking weight off or displacing weight like in your case is a benefit your car and wallet will love in the long term.
Weight off a car is better than throwing more cubic power dollars at it.
My friends all steel A-body with a small block is in the 2900 lbs range with a full interior and all. We worked it to a degree and can still go further south in the weight department, but his madness isn't as severe as mine.
Re: Installing Battery In Trunk Wire Size ? [Re: Clanton] #1228492
05/08/12 08:50 AM
05/08/12 08:50 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I agree 1 gauge at minimum.0 gauge is better for bot ground and hot.For the alt bun 10 or 8 gauge.If you have to worry about the little weight from 1 to 0 you need a bigger motor.Rocky
Chrysler Firepower
