mild mannered/dual purpose 540-does it exist? #1228181
05/06/12 10:01 PM
05/06/12 10:01 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
sold my 493 and am considering 540-will have a/c-tube chassis car with weight in 36-3800 lb range-will be mostly street but raced maybe 2 times a month-probable indy 440-1 or ?? heads, camshaft unknown at this time-would like to run f.i.-not completely sold on fast or power-
jection or msd atomic efi.also would like to run e-85.is this possible and still not be a pig on strip?all opinions welcomed at this time-thanks rick
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228182
05/06/12 11:09 PM
05/06/12 11:09 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
There have been crazier combo's built that run well on the street, and lay down startling numbers at the strip. Just look at the Pro Street cars that run in Drag Week. So, to answer your question, yes it is possible. I have to ask you, why the hell would you build such a heavy tube chassis car? To add that much weight, it kind of defeats the purpose of building a tube chassis car. What is your ET goal?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: mild mannered/dual purpose 540-does it exist? [Re: DusterDave] #1228183
05/06/12 11:26 PM
05/06/12 11:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'd think he was thinkin' 26/2800 lbs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: mild mannered/dual purpose 540-does it exist? [Re: hemi-itis] #1228184
05/06/12 11:35 PM
05/06/12 11:35 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
My vote, B-1 Heads.
Re: mild mannered/dual purpose 540-does it exist? [Re: hemi-itis] #1228185
05/06/12 11:39 PM
05/06/12 11:39 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
this is a 65 coronet wagon--floor was rotted,firewall was rotted,spare
tire well rotted,moved firewall back 12 inches,motor back 9 inches, has flaming rivers rack & pinion,complete glass front end,full cage,
dana,ladder bars,18.5 m/t et streets,factory buckets,console,p/w.my
last one so i wanted it different.not sure of weight in full dress but
guy building car says orig small block was 36-3800.hoping for 3400 myself but who knows.will have most chrome and luggage rack w/power tailgate window also.just want to be different.
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228186
05/06/12 11:47 PM
05/06/12 11:47 PM
hemi-itis Offline
hemi-itis  Offline
Sounds like a cool ride All I can tell ya is ya can't beat BOOST!!!!
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228187
05/06/12 11:57 PM
05/06/12 11:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What sort of ET would you be looking for on the track...
makes a big difference on the engine....I'm sure
you mean lighter than what you posted
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228188
05/07/12 12:10 AM
05/07/12 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm finishing up a Dodge Rampage with a moly chassis,
SB 416, 518 OD trans with 5000 stall and a 9" rear
with 4.10 gears and 295/55 tires on the back... pretty
much stock interior.. with all glass working windows
except for the back glass which is lexan because of
the bars going to the back... I expect this to weigh
2800 with me in it.... I dont want A/C... too hard
to work around.. but I expect it can run 9.70s or
so but I just want a 10.0 to 10.2 car so I dont need
to cert it and wont need a NHRA license
Re: mild mannered/dual purpose 540-does it exist? [Re: MR_P_BODY] #1228189
05/07/12 12:14 AM
05/07/12 12:14 AM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
again not sure of weight when done-hoping around 3400 when all done-using as much fiberglass as possible-both frt fenders,hood,frt bumper,scoop-all tied together so can lift off as 1 full part or remove hood and scoop along.doors are gutted,stock door panels,back seat.dont want to be pooch as in 11.00s but still would hope for 10s
somewhere.the intent is to make as unique as possible but still have fun and even power tour it-if it got 10 mpg w/16 gal cell could get almost to indy from home here near st.louis.fun without embarrassment is goal.thanks to all so far for comments.rick
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228190
05/07/12 12:23 AM
05/07/12 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The car I mention above is being built for drag week
and maybe power tour stuff... I will say you should
look into a OD trans... for me the 518 worked out well
being a SB...it bolts right up... I built a 18 gal
fuel tank for cruising... the 4.10 gears for the track
and still have OD for the road... I decided against
going E-85 for this car due to it can be a pain to find
at times
Re: mild mannered/dual purpose 540-does it exist? [Re: rbkt65] #1228191
05/07/12 02:45 AM
05/07/12 02:45 AM
Is this going to be a 4.500 bore with a 4.375 stroke or the oher way around with the stroke being 4.500 with a 4.375 bore? It makes a difference on the cam lobes and LSA Also what type of lifter do you want to use, solid flat tappet, hydraulic flat tappet, solid roller or hydraulic roller?
Re: mild mannered/dual purpose 540-does it exist? [Re: hemi-itis] #1228192
05/07/12 08:22 AM
05/07/12 08:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That's what I was thinking. If you want your cake and eat it too, boost is the only way to go.
Coming soon!!!!
