Another 8 3/4 question....yawn #1228034
05/06/12 03:36 PM
05/06/12 03:36 PM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
But one with a bit of a twist....
I currently have a fully built 8.75 in my Swinger that lived behind a 512 torque monster and propelled it to 9.75 with a 1.35 60' (2900 lbs). The rear is a 742 with strange 30 spline spool and axles, back brace, C/M yoke and M/W caps. I always swap out the ring and pinion after 300 passes and have never had any issues. I am putting a turbo'd 5.7 Hemi with a glide in it over the winter. Target HP is 800 (the 512 had close to 600). My question is, will the 8.75 live? I expect the car to launch abit softer with the turbo and glide. Also I will be switching the gears from 3.91 to 3.23's or less. Are the higher ratio ring and pinions stronger or weaker?
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Another 8 3/4 question....yawn [Re: Dave_S] #1228035
05/06/12 03:46 PM
05/06/12 03:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I THINK I know where this is going............
Re: Another 8 3/4 question....yawn [Re: Dave_S] #1228036
05/06/12 07:06 PM
05/06/12 07:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
MY opinion is that the lower the number the stronger the gears are.
The turbo does in general have a softer hit.
The biggest problem with the 8 3/4 is that there is not pro gears (Soft gears) for it.
Re: Another 8 3/4 question....yawn [Re: Dave_S] #1228037
05/06/12 08:26 PM
05/06/12 08:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
If I was you, and the 30 spline axles are okay, I would try it Nothing like learning first hand
Re: Another 8 3/4 question....yawn [Re: Cab_Burge] #1228038
05/06/12 08:40 PM
05/06/12 08:40 PM
Dave_S Offline OP
Dave_S  Offline OP
Why not.....I guess I'll give it a try!
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Another 8 3/4 question....yawn [Re: Cab_Burge] #1228039
05/06/12 11:07 PM
05/06/12 11:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya Cab but at what expense.........
Re: Another 8 3/4 question....yawn [Re: Dave_S] #1228040
05/07/12 12:19 AM
05/07/12 12:19 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You've done everything you can to make it live.....I can't think of anything else that could improve in it.
The car isn't too heavy.
35 spline might be nice , but I don't think it is the axle that fails in these.
You'll get both arguments , but I wouldn't be afraid to run it.
Re: Another 8 3/4 question....yawn [Re: tubtar] #1228041
05/07/12 12:28 AM
05/07/12 12:28 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t get me wrong here as I`m one of the few who have had good luck w/em and hopefully you will too...................
Re: Another 8 3/4 question....yawn [Re: Dave_S] #1228042
05/07/12 12:36 AM
05/07/12 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With street type gears you are applying more stress
on the gears... its easier to turn a 4.88 than it is
with a 3.23(to get the weight moving)so you MIGHT have
a issue but thats JMO
