Re: smallblock modman intake..
[Re: A57_RT ]
#1227464
05/05/12 09:29 PM
05/05/12 09:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Some reason you are haveing a really hard time understanding what I am saying. If a carb is too small then they run better with big plenums, that is exactly what you are finding out. A big plenum is a great way to make a smallish carb make power, I don't see why that is so hard to understand. Six packs are fine, I don't know why you think I am trying to convince you to get rid of it, if you want to keep it just keep adding plenum, I was just explaining why you keep picking up power. I even agree the mod man would be better for a 6 pack or especially dual 4s than it would be for a single 4 as the outside cylinders would probably get less fuel than the centers.
[Re: A57_RT ]
#1227465
05/05/12 10:47 PM
05/05/12 10:47 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
A57RT, thanks again.the current dual 4 has 4 holes per carb.thanks for the link,i have seen those spacers on ebay in regards my mates 510ci six pack. would that top allow use of holley type carbs on the modman ?? i would think a 1" 4 hole spacer may pick up signal over the open. Dave i see and understand what you mean re spacer/plenum/carb size.i have done similar myself
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1227466
05/05/12 11:48 PM
05/05/12 11:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Mark, that lid for holleys is NICE!!!
what Dave was trying to say is experimenting with plenum spacers would be something worth trying. I think your confusing carb spacer and a plenum spacer in the convertsation. stcking hole spacers to me would just increase signal to the carbs and posibly help atomization before it hits the plenum which i would think would be helpful with a center carb in the middle of the large plenum
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: tex013]
#1227467
05/06/12 12:19 AM
05/06/12 12:19 AM
HotRodDave
Kalispell Mt.
Those carb spacers (even the hole type)are effectively adding to the plenum, I assumed everyone realized that. There may be other benifits from the shapes like atomization or fuel distrubution but the main thing they do is add plenum volume.
[Re: HotRodDave]
#1227468
05/06/12 12:51 AM
05/06/12 12:51 AM
sixpackgut
Charleston
I dont really agree that a hole spacer is adding plenum volume. IMO it would just be adding length to the carb and would in no way make a carb seem larger to the engine as an open spacer would. this is just my opinion, in no way should i be considered an expert
