833 shifter linkage adjustment #1227408
05/04/12 11:18 PM
05/04/12 11:18 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
2 questions: How do I know when shifter is in neutral position? I can get a rod through the shifter housing and 1/2, 3/4 levers but not the reverse lever. This is a factory hurst shifter rebuilt by Hurst (Mr Gasket) in Cleveland a few years ago. Please verify transmission neutral position: top two levers 1/2, 3/4 in middle position and reverse in forward position. Is this correct? Puting everything back together in 69 GTX. All parts are original to car. Thanks
Re: 833 shifter linkage adjustment [Re: frank] #1227409
05/05/12 02:14 AM
05/05/12 02:14 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
1) Rod should go through all three levers and housing
2) It doesn't matter, the rod is the defining variable
Re: 833 shifter linkage adjustment [Re: 6PakBee] #1227410
05/05/12 02:17 AM
05/05/12 02:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
OEM shifters DON'T have the hole through the reverse plate (at least the ones that I have seen). Adjust the forward gears and eyeball the reverse plate to the same position.
Re: 833 shifter linkage adjustment [Re: Jim_Lusk] #1227411
05/05/12 10:40 AM
05/05/12 10:40 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Clarification. I am holding an OEM shifter in my hands. The 1-2 and 3-4 shift levers have a hole through them. The reverse lever goes toward the front and has what appears to be half a hole (notch)on the rear edge of the reverse lever. The adjustment rod goes completely through the shifter and is indexed on both sides of the shifter housing.
Re: 833 shifter linkage adjustment [Re: frank] #1227412
05/05/12 12:19 PM
05/05/12 12:19 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks all. Neutral position for reverse on trans is forward position??
Re: 833 shifter linkage adjustment [Re: frank] #1227413
05/05/12 12:58 PM
05/05/12 12:58 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Yes it is.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 833 shifter linkage adjustment [Re: 6PakBee] #1227414
05/05/12 01:26 PM
05/05/12 01:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What year is your shifter box , prior to 1970 the reverse lever in the OEM factory installed Hurst shifters for Chrysler products did not have a hole thru the reverse lever for the alignment pin. the tool to align the shifter was U shaped , had a pin that went into the notch on the box and into 1/2 and 3/4 , the other part of the tool slide over the outside edge of the notch and over all 3 levers and it had a thumb screw to close the open end of the U .
I don't remember if that changed in 70 or 71 , but this is how 68 and 69 shifters were and are aligned, someone posted a photo of the tool from the FSM within the last 2 weeks in another thread on this subject.
I made one of these tools because I was not able to find one.
Here is a picture of the factory tool i found in another much older thread .
Re: 833 shifter linkage adjustment [Re: JohnRR] #1227415
05/05/12 02:38 PM
05/05/12 02:38 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Mine is a 69. I have two Hurst shifters and neither has any hole in the reverse lever for allignment. I got it working. My error was not having the reverse lever on the trans in the forward position. I eye balled the reverse lever with the 1/2, 3/4 and adjusted the rods accordingly. Statically it shifts through the gears ok now. Thanks for everyones help.
Re: 833 shifter linkage adjustment [Re: JohnRR] #1227416
05/05/12 04:40 PM
05/05/12 04:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
John,
The shifter I have is either a '68 or '69. Read my second post. I clarified that reverse does NOT have a hole but it does have a notch in the edge that clears an alignment rod. I've seen the tool you posted a picture of but frankly I've never seen anyone, including myself, use one. You use about a 5/32" drill bit for an alignment tool, get the levers roughed in, and then do a final adjustment as required to get a smooth transition through the neutral gate. Yes, not using the tool is kind of a pain as the bit has to be held in the notches but again, I've never seen it done any other way.
Re: 833 shifter linkage adjustment [Re: 6PakBee] #1227417
05/05/12 04:50 PM
05/05/12 04:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since all the factory tool does is align the sides of the levers it's easy to use a 1/4" rod to align the 1-2 and 3-4 levers and then just eyeball the Reverse lever to align the sides of it with the other two.
