Re: 833 shifter linkage adjustment
[Re: frank]
#1227409
05/05/12 02:14 AM
05/05/12 02:14 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
1) Rod should go through all three levers and housing 2) It doesn't matter, the rod is the defining variable
[Re: Jim_Lusk]
#1227411
05/05/12 10:40 AM
05/05/12 10:40 AM
6PakBee
North Dakota
Clarification. I am holding an OEM shifter in my hands. The 1-2 and 3-4 shift levers have a hole through them. The reverse lever goes toward the front and has what appears to be half a hole (notch)on the rear edge of the reverse lever. The adjustment rod goes completely through the shifter and is indexed on both sides of the shifter housing.
[Re: JohnRR]
#1227416
05/05/12 04:40 PM
05/05/12 04:40 PM
6PakBee
North Dakota
What year is your shifter box , prior to 1970 the reverse lever in the OEM factory installed Hurst shifters for Chrysler products did not have a hole thru the reverse lever for the alignment pin. the tool to align the shifter was U shaped , had a pin that went into the notch on the box and into 1/2 and 3/4 , the other part of the tool slide over the outside edge of the notch and over all 3 levers and it had a thumb screw to close the open end of the U .
I don't remember if that changed in 70 or 71 , but this is how 68 and 69 shifters were and are aligned, someone posted a photo of the tool from the FSM within the last 2 weeks in another thread on this subject.
I made one of these tools because I was not able to find one.
Here is a picture of the factory tool i found in another much older thread .
John,
The shifter I have is either a '68 or '69. Read my second post. I clarified that reverse does NOT have a hole but it does have a notch in the edge that clears an alignment rod. I've seen the tool you posted a picture of but frankly I've never seen anyone, including myself, use one. You use about a 5/32" drill bit for an alignment tool, get the levers roughed in, and then do a final adjustment as required to get a smooth transition through the neutral gate. Yes, not using the tool is kind of a pain as the bit has to be held in the notches but again, I've never seen it done any other way.
[Re: 6PakBee]
#1227417
05/05/12 04:50 PM
05/05/12 04:50 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since all the factory tool does is align the sides of the levers it's easy to use a 1/4" rod to align the 1-2 and 3-4 levers and then just eyeball the Reverse lever to align the sides of it with the other two.
