holley metering plates #1227404
05/04/12 10:49 PM
05/04/12 10:49 PM
northeast ohio
mkdart Offline OP
mkdart  Offline OP
northeast ohio
Anybody out there drill & tap a standard metering plate's
and make there own I.F.R.'s with brass set screws?
I bought a 02 kit and I'm trying to get dialed in.
I picked up a hand full of metering blocks at a swap meet
and I noticed that the I.F.R,s change from model to model.
So I been swapping plates to start.
Mike
Re: holley metering plates [Re: mkdart] #1227405
05/04/12 11:20 PM
05/04/12 11:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
have you matched the plate # on the holley site to the carb to see what can be used?i have drilled small bleeds and made the bigger but no plate drilling.
Re: holley metering plates [Re: mkdart] #1227406
05/05/12 08:43 AM
05/05/12 08:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Problem you run into is the floats hang up on the jets. I think there is floats that have indents in that you can get now. these were not available back in the day when I tried jetting plates may or may not work.
http://www.summitracing.com/parts/HLY-116-11/
You can drill present jet holes in the bottom out to various sizes even plug with liquid solder and re drill.
best bet is the metering block conversion kits
http://www.summitracing.com/search/?keyword=metering%20block%20conversion%20kits&dds=1
mancini's
http://chucker54.stores.yahoo.net/conversionkits.html
Re: holley metering plates [Re: mkdart] #1227407
05/05/12 01:16 PM
05/05/12 01:16 PM
I had CR Engr. in Whittier,CA modify my original six pak carbs, they epoxy plugged the bottom inlet holes and drill and tapped right above that hole and used a screw in holley air bleed jet It clears the stock floats I have changed them, I bought some .031 air bleeds from Summit(Quick Fuel brand I think)and drilled them as needed for different elevation tracks
