Re-assembling my 8-3/4 rear end #1227320
05/04/12 08:16 PM
05/04/12 08:16 PM
California
moparbroz Offline OP
California
I purchased mostly all seperate components. The axle housing I had powder coated. I have sealed bearings that need to be pressed onto my axles and I have a 489/323 suregrip unit. I have never assembled a rear end. Questions I have are:
1. Do the exle splines simply slide into the suregrip female splines while the backing plates mated to the housing secures everything or do I need grease, silicone, etc?
2. The suregrip unit to the housing gets a gasket, nuts and washers. Anything else like silicone.
3. Once together how much gear oil do I add to the housing? What type of gear oli? Best method for administering the gear oil into the pumpkin?
Anything else I need to know?
Thanks!
Hebrews 11:1
Re: Re-assembling my 8-3/4 rear end [Re: moparbroz] #1227321
05/05/12 12:49 AM
05/05/12 12:49 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I just slide the axles in.
Don't forget to add limited slip additive.
Ride eternal, shiny and chrome
Re: Re-assembling my 8-3/4 rear end [Re: moparbroz] #1227322
05/05/12 03:12 AM
05/05/12 03:12 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Axle shaft retaining nuts-torque to 35 ft./lbs.
Carrier to housing-45 ft./lbs. OE is no washers. I like a gasket-clean/dry.
I like a petroleum-based gear oil. Use an additive. You'll see a provision in the case. Pipe plug. Capacity is 4.4 pints.
'Green' bearings have pro/con. My experience is they don't live on the street. Keep an eye on 'em.
Re: Re-assembling my 8-3/4 rear end [Re: moparbroz] #1227323
05/05/12 03:17 AM
05/05/12 03:17 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Make sure the "buttons" or floating spacer, are removed from center of suregrip unit if they need to be out of there. Sealed bearings sometimes require their removal.
Re: Re-assembling my 8-3/4 rear end [Re: RSNOMO] #1227324
05/05/12 12:38 PM
05/05/12 12:38 PM
California
California
Excellent. Thank you.
Hebrews 11:1
Re: Re-assembling my 8-3/4 rear end [Re: DirectSubjection] #1227325
05/05/12 12:40 PM
05/05/12 12:40 PM
California
California
Is this the stuff?
http://www.jeep4x4center.com/mopar-limited-slip-differential-additive-4318060ab.html
Hebrews 11:1
Re: Re-assembling my 8-3/4 rear end [Re: moparbroz] #1227326
05/05/12 12:49 PM
05/05/12 12:49 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I always used to use the GM stuff (1052358 is the part number)
Comes in a similar sized little bottle.
Re: Re-assembling my 8-3/4 rear end [Re: OzHemi] #1227327
05/05/12 12:54 PM
05/05/12 12:54 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Make sure the axles slide all the way into the center section. Sometimes the side gears aren't aligned.
Re: Re-assembling my 8-3/4 rear end [Re: OzHemi] #1227328
05/05/12 08:46 PM
05/05/12 08:46 PM
California
California
The bottle I bought had 4 oz. I see above that 4.4 pints is recommended. Thoughts?
Hebrews 11:1
Re: Re-assembling my 8-3/4 rear end [Re: moparbroz] #1227329
05/05/12 11:57 PM
05/05/12 11:57 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You just dump the entire bottle of additive in, then just fill the diff the rest of the way with gear oil. Just fill till it starts to dribble out the filler should be fine.
Re: Re-assembling my 8-3/4 rear end [Re: OzHemi] #1227330
05/06/12 11:30 AM
05/06/12 11:30 AM
California
California
Okay. Any particular gear oil better than another? Thanks neighbor!!!
Hebrews 11:1
