Re: 90 degree oil filter adapter gasket kit P5249624
[Re: krw71ragtop]
#1226506
05/03/12 01:23 AM
05/03/12 01:23 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Summit shows an "Estimated Ship Date" of May 11 for part# P5249624. http://www.summitracing.com/parts/DCC-5249624/Just to clarify; Your subject of "90 degree oil filter adapter gasket kit" makes me think you are looking for the gasket kit FOR the adapter, which is # P5249320. The part# P5249624 in the subject line is the angle adapter AND the gaskets needed. However, it may just be me being confused... again!
[Re: jeebis44]
#1226508
05/03/12 10:40 AM
05/03/12 10:40 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
OK Quick question - I just pulled my stock 318 out of my '83 gran fury and when I removed the factory 90* oil filter adapter, there was NO gasket. This thing has never been off before. Is the gasket absolutely necessary between the adapter and the block?
IMO yes. Don't know what you had going on with the 318 but with all the oil that travels through there and having pressure with no gasket would make me
To the OP if you're just looking for the gaskets I stock them. Shoot me a PM
[Re: roadhazard]
#1226509
05/03/12 09:51 PM
05/03/12 09:51 PM
Posts: 892 USA
krw71ragtop
USA
It's been a while since I put this together but I remember there being a groove in the bolt where an o-ring type gasket went. Mine is not in very good shape and I have a constant drip going right on the header. It looked to be more of a flat rubber gasket than a o-ring. Maybe it's just wore down. I also think there might be 2 styles of the 90 degree adapter. One with the o-ring type gasket for the bolt and one without the o-ring. Does the o-ring type gasket come with the kit ?
The part # I posted I think is a mopar part #. The Mancini part # is MOPP5249320. Not sure what the difference is ? Summit's # is DCC-5249320 Do I have an odd ball adapter or what ?
[Re: jeebis44]
#1226511
05/04/12 12:18 PM
05/04/12 12:18 PM
Posts: 13,601 md
mopars4ever
md
[Re: jeebis44]
#1226515
05/27/12 10:32 PM
05/27/12 10:32 PM
Posts: 975 Page AZ
Diplomatt
Rodney Dangerfield Jr.
Page AZ
I just went through the same thing with my diplomat. When I took the adapter off, there was NO gaskets, but now that I put it together again, it leaks badly. Does anybody know the size of the small cork gasket that goes on the bolt? I found the large round one at advance auto in stock already. I would order one, but I'm trying to get the car running ASAP.
