90 degree oil filter adapter gasket kit P5249624 #1226505
05/03/12 12:03 AM
05/03/12 12:03 AM
USA
K
krw71ragtop Offline OP
K
USA
Where can I get this kit ? It has been on back order at Mancini racing since last year !
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: krw71ragtop] #1226506
05/03/12 01:23 AM
05/03/12 01:23 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Summit shows an "Estimated Ship Date" of May 11 for part# P5249624.
http://www.summitracing.com/parts/DCC-5249624/
Just to clarify;
Your subject of "90 degree oil filter adapter gasket kit" makes me think you are looking for the gasket kit FOR the adapter, which is # P5249320. The part# P5249624 in the subject line is the angle adapter AND the gaskets needed.
However, it may just be me being confused... again!
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: moparfan53] #1226507
05/03/12 01:48 AM
05/03/12 01:48 AM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
OK Quick question - I just pulled my stock 318 out of my '83 gran fury and when I removed the factory 90* oil filter adapter, there was NO gasket. This thing has never been off before. Is the gasket absolutely necessary between the adapter and the block?
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: jeebis44] #1226508
05/03/12 10:40 AM
05/03/12 10:40 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
IMO yes. Don't know what you had going on with the 318 but with all the oil that travels through there and having pressure with no gasket would make me
To the OP if you're just looking for the gaskets I stock them. Shoot me a PM
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: roadhazard] #1226509
05/03/12 09:51 PM
05/03/12 09:51 PM
USA
K
K
USA
It's been a while since I put this together but I remember there being a groove in the bolt where an o-ring type gasket went. Mine is not in very good shape and I have a constant drip going right on the header. It looked to be more of a flat rubber gasket than a o-ring. Maybe it's just wore down. I also think there might be 2 styles of the 90 degree adapter. One with the o-ring type gasket for the bolt and one without the o-ring. Does the o-ring type gasket come with the kit ?
The part # I posted I think is a mopar part #. The Mancini part # is MOPP5249320. Not sure what the difference is ? Summit's # is DCC-5249320 Do I have an odd ball adapter or what ?
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: krw71ragtop] #1226510
05/04/12 12:07 AM
05/04/12 12:07 AM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
The adapter I took off my engine had never been off before and never leaked...
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: jeebis44] #1226511
05/04/12 12:18 PM
05/04/12 12:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: mopars4ever] #1226512
05/04/12 12:19 PM
05/04/12 12:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Yes, there is a gasket between the adapter and the block. Most of the adapter`s I have seen look like the one in the above ebay listing. There isn`t any oring or groove from what I remember. Do you really need the adapter? I removed mine and use a short filter with my headers. And also there is no oring in the kit.
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: mopars4ever] #1226513
05/11/12 01:24 PM
05/11/12 01:24 PM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
OK I now have the large gasket that goes between the block and adapter, but where are the other 2 smaller gaskets supposed to go?
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: jeebis44] #1226514
05/11/12 09:03 PM
05/11/12 09:03 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The thinner one under the head of the bolt and the other thicker one goes on the bolt between the adapter and the block.
Re: 90 degree oil filter adapter gasket kit P5249624 [Re: jeebis44] #1226515
05/27/12 10:32 PM
05/27/12 10:32 PM
Page AZ
Diplomatt Offline
Rodney Dangerfield Jr.
Diplomatt  Offline
Page AZ
I just went through the same thing with my diplomat. When I took the adapter off, there was NO gaskets, but now that I put it together again, it leaks badly. Does anybody know the size of the small cork gasket that goes on the bolt? I found the large round one at advance auto in stock already. I would order one, but I'm trying to get the car running ASAP.
