Improving the Ride - 06 Ram 3500 CTD #1226424
05/02/12 11:43 PM
05/02/12 11:43 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
I have an 06 Ram 3500 CTD with a single rear wheel (not a dually). While the ride doesn't bother me, the wife hates riding in it. Its pretty stiff and rough - expected for a 1 ton. But, she REALLY hates it. Given some of the trips we take it would be easier if I could soften the ride up.
I have been looking at possibly converting or supplmenting with air bags so that I could set it on a softer setting when empty and then dial it up when I have a load in it or the like.
But, there may be other things I can look at as well - like different shocks. Anyone have any advice as to what I should be looking at? Vendors? Kits? Articles with advice or recommendations?
I'm just trying to poke around and see what the cost might be. Thanks!
1966 Barracuda 1968 Barracuda convertible 1930 Ford Model A (soon to be hemi equipped) 2006 Dodge 3500 4X4 CTD Quad Cab
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226425
05/04/12 09:28 AM
05/04/12 09:28 AM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
2 days and not a single response??
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226426
05/04/12 10:30 AM
05/04/12 10:30 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Really not much you can do, springs are the key. You can try the bags, they might help slightly, a bit more if it's loaded. Lower the tire pressure. If she thinks it rides rough now I don't think any of that will make enough difference to change her mind.
Maybe you can take her for a ride in a '93 or older one ton? That might change her perspective.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Improving the Ride - 06 Ram 3500 CTD [Re: 3hundred] #1226427
05/04/12 12:29 PM
05/04/12 12:29 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Take a couple of photos of the rear leafs and post the them on here.
I'll try to help you. I have a few suggestions.
Mo' Farts
Moderated by "tbagger".
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Grizzly] #1226428
05/04/12 01:43 PM
05/04/12 01:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Quality shocks all the way around and a link suspension with air bags on the rear wound be the best way to go IMO. or get a 1/4 or 3/8 sheet of steel to carry in the bed.
I am truckless..
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226429
05/04/12 04:40 PM
05/04/12 04:40 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
My Dad has an '07 Ram 3500 dually. He adds about 500 LBS in the bed when he takes it on a trip without his 5th wheel trailer. Makes a HUGE difference.
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Fat_Mike] #1226430
05/04/12 11:24 PM
05/04/12 11:24 PM
IN
ahy Offline
ahy  Offline
IN
If they swap, a set of 3/4 ton springs would ride better. Add air bags to get the load capacity back... although the idea of simply adding weight would be fine also. 500# or so wouldn't impact performance or mileage much.
Re: Improving the Ride - 06 Ram 3500 CTD [Re: ahy] #1226431
05/05/12 01:02 AM
05/05/12 01:02 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
3/4 tons springs are only different in that they don't have helper springs which do nothing to the unloaded ride. In the winter I put a big truck tire and rim in the back of mine for weight, it's just enough to help the ride a bit and the Cummins doesn't even know it's back there. I also suggest 500lbs is the easiest solution.
What air pressure are you running in the back? When my truck's empty I air it down to 28lbs in the back.
Sheldon
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226432
05/05/12 09:01 AM
05/05/12 09:01 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
my suggestion, find an old leaf sprung 1-ton 4x4, take for ride in that, then a ride in '06.
problem solved.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: Improving the Ride - 06 Ram 3500 CTD [Re: ahy] #1226433
05/05/12 11:02 AM
05/05/12 11:02 AM
ky.
K
kenworth_goose Offline
K
ky.
The easiest thing is find her something else to drive! It's a 1 ton truck, it's gonna ride rough without a load in it.
Re: Improving the Ride - 06 Ram 3500 CTD [Re: kenworth_goose] #1226434
05/07/12 10:51 PM
05/07/12 10:51 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
She doesn't drive it. She rides in it with me. And, she hates riding in it. It would be a LOT easier to take the truck on some trips we make than loading down her Maxima. But, she refuses to ride in the truck on a long trip. So, here we are....
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Grizzly] #1226435
05/07/12 10:52 PM
05/07/12 10:52 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
I'll try to get some photos.
It does have the standard leaf stack for a 3/4 plus the helper springs for the 1 ton (which don't come in to play at all unless its loaded).
Re: Improving the Ride - 06 Ram 3500 CTD [Re: RUNCHARGER] #1226436
05/07/12 10:53 PM
05/07/12 10:53 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
Sheldon
Good idea. I will look at adding some weight somehow. I need to check on the air pressure.
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226437
05/07/12 11:19 PM
05/07/12 11:19 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Buy her an air seat...............
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226438
05/08/12 08:31 AM
05/08/12 08:31 AM
Lehigh Acres, Florida
rickstershemi Offline
BUY A GMC
Rickster
Re: Improving the Ride - 06 Ram 3500 CTD [Re: rickstershemi] #1226439
05/08/12 11:27 AM
05/08/12 11:27 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Buying a GMC is a good idea as cars do ride better. If you want a truck though you should stick with the Dodge.
Sheldon
Re: Improving the Ride - 06 Ram 3500 CTD [Re: RUNCHARGER] #1226440
05/08/12 09:53 PM
05/08/12 09:53 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
When I bought my 04 dodge dually new on trip home I thought , what did I just buy? a lumber wagon? it rode hard. The next day went to Home Depot and loaded up 2 pallets of wet sod. Drove around with that in the back for a week. That took care of the stiff ride. Rides nice now. Wife would rather ride in it than her linclon. As a matter of fact this morning we had to go out of town , about 150 mile trip, asked car or truck , she said she'd rather ride that far in the truck. But she also say's that the driver seat is more comfortable than the passenger seat. Maybe let your wife drive
Re: Improving the Ride - 06 Ram 3500 CTD [Re: RUNCHARGER] #1226441
05/08/12 11:00 PM
05/08/12 11:00 PM
Sheldon
Sheldon do you see a car in this pic......
I have been a Mopar Guy for more years than I care to admit....tested 07's before I bought the GMC
Rickster
Re: Improving the Ride - 06 Ram 3500 CTD [Re: rickstershemi] #1226442
05/09/12 09:29 PM
05/09/12 09:29 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That is cute all right. Actually I'm sort of okay with GM trucks, I think Ford is a pretty good truck as well but with a poor engine.
If size matters though when I got my International 9900 stuck after putting a 53' into a very difficult spot on Monday it was a Dodge that got me out. After dollying off the trailer and pulling forward so I could back out beside the trailer I had just dropped off, my front wheels went slightly over the bank on top of a cliff and my 3way lockers in the back weren't enough. The customer hooked his 05 Cummins up and after about the 3rd jerk with me spinning 6 tires and the Dodge spinning all four, she came out. I wouldn't have let him try it if he didn't have a solid axle in both ends. Anyone can parade around on smooth pavement with no hills though.
Sheldon
Re: Improving the Ride - 06 Ram 3500 CTD [Re: Joatha] #1226443
05/09/12 10:23 PM
05/09/12 10:23 PM
ky.
K
K
ky.
You could always leave her at home and find a women that will ride in it! Just an idea.
