Page 3 of 4 1 2 3 4
Re: Running hot and running out of ideas 67 Belvedere [Re: feets] #1226299
05/04/12 02:05 AM
05/04/12 02:05 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Before you start changing parts, grab the temp gun and check things out.
Putting a little distance between the trans cooler and radiator may help a wee bit.
I'm not a fan of attaching things to the radiator core.
I agree. Check with the IR gun. They really come in handy. But they don't read very well of shiny surfaces. Like a polished aluminum radiator or chrome headers.
Sure optimum is the fan blades 1/2 inside the shroud edge. But I don't think 1/3 in would cause all the problems you are having.
Re: Running hot and running out of ideas 67 Belvedere [Re: ThermoQuad] #1226300
05/04/12 03:04 AM
05/04/12 03:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
"Antifreeze" does not cool as well as water or water with additive.
"Antifreeze" has many properties. Many of those properties are accomplished by the additives blended with the Ethelyne Glycol (the part that resists freezing). The property of resistance to freezing in "Antifreeze" is not a needed by Belvedere1 and those few who live in his same climate. Now those living in colder climates (most), you do need resistance to freezing in winter from antifreeze. No need to debate that.
Now, those few who don’t need the resistance to freezing in their car still need the additives in their cooling systems for protection.
The Justice Brothers Radiator Super Cooler (RC/22P) has an additive package formulated to include properties for: water pump lubrication, anti corrosives, Supplemental Coolant Additives (SCA's), surfactants, stop rust, resisting acid formation, anti foaming to name a few.
Here's a fairly thorough conducted test of cooling additives in regards to temperature: http://www.turbomagazine.com/feature...s/viewall.html
From test:
Justice Brothers' Radiator Cooler gave us the lowest temperature during our testing - 177 F - and provided the lowest average temperatures overall when mixed with water alone.
In the case of Belvedere1 , I personally would like to recommend also adding a bottle of Cooling System Protector (CSP/1P) when running straight distilled water and a large system. It has additional SCA's, water pump lubrication, corrosion inhibitors and acid neutralizers. It also contains special metal deviators that act as a ground strap between dissimilar metals like the many aluminum to cast iron to brass to rubber transitions. That gives extra electrolysis and anti rust protection as additives get depleted over time over a large area.
Check electrolysis with a digital voltmeter. Attach the ground to the radiator body. Then float the positive lead in the radiator fluid mixture. You should not have more than about .3 volts.
We all run sealed ZZ4 crate motors per class rules in the circle track car I crew on. I have seen guys that use Redline water wetter spit brownish water on a hot day. The track approved engine rebuilder stated our motor's coolant passages using Justice Brothers additive had no corrosion whereas the Redline users didn't look as clean.
Steve Wall
Regional Sales Representative
Justice Brothers High Point Distributing
www.justicebrothers.com
stevewall68@gmail.com
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226301
05/04/12 08:43 AM
05/04/12 08:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks for the info there. I just went to go over some of the suggestions and I would say that only about 25-30% of the fan blade is in the shroud so now I am thinking I may need to search for a clutch fan spacer to sink the fan in a little further. I still have some room to be safe with clearance between the rad and the fan clutch.
Also, the trans cooler is mounted directly to the radiator with the zip ties from the cooler kit. I never really liked that setup but thought it would be ok but now I am not sure that is ideal for allowing the radiator to fully do its job. I will do some further investigating this weekend.
Thanks all.
I've run the cheap Summit plastic 18.5" fan in the last few 440's. I think w/ a 1.5" spacer... they work great car runs cool and the weight a few ounces PLUS you won't cut your fingers to heck working around them.
Coming soon!!!!
Re: Running hot and running out of ideas 67 Belvedere [Re: autoxcuda] #1226302
05/04/12 12:58 PM
05/04/12 12:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
With all due respect, I doubt seriously what's in his radiator is the root cause.
Maybe something will run 10 degrees cooler than something else but he should see a larger drop.
- Stu Harmon
Re: Running hot and running out of ideas 67 Belvedere [Re: feets] #1226303
05/04/12 01:54 PM
05/04/12 01:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
on the root cause.
Either a combination of small stuff, radiator blockage, or a tuning issue.
Wonder if cam duration 254 @.050 with 3.75 stroke, 9.5 converter, rear gear factor in here???
Re: Running hot and running out of ideas 67 Belvedere [Re: autoxcuda] #1226304
05/04/12 07:36 PM
05/04/12 07:36 PM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Is your radiator aluminum? If it is try shining a flashlight through the front of it. If you can't see any light coming through the other side, you need a new radiator. Those aluminum ones will go bad if they get too hot just one time. I'm on my 3rd one in one of my cars. Took forever to figure it out.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: Running hot and running out of ideas 67 Belvedere [Re: MoparPosterChild] #1226305
05/04/12 09:34 PM
05/04/12 09:34 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
No aluminum, just a factory type replacement.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226306
05/05/12 12:32 AM
05/05/12 12:32 AM
Phoenix, AZ
Phoenix, AZ
Took some temp measurements on the radiator. At the top near the upper hose I measured 192 degrees and at the lower hose I got 158 degrees. So that should prove the radiator is flowing well. I started it @ 6:39 with the outside air temp of 96 deg and after 21 minutues of idling and slow 20 mph cruise for about 2 block in the neighborhood and back to the driveway for more idling it finally reached 195 deg on the temp guage. This is pretty much the scenario but it would have climbed to 220 had I let it sit running a little longer. The problem is that it just does not cool itself and hold a steady temp. If I were idling in stop and go traffic and then a run down the freeway and back to stop and go traffic it just will not hold a good temp. I cool it down by parking it and let it sit. The search continues as I will be trying some of the other things you guy have mentioned in this thread.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226307
05/05/12 12:41 AM
05/05/12 12:41 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Can you turn the clutch fan by hand with the engine hot? There should be ALOT of resistance.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Running hot and running out of ideas 67 Belvedere [Re: DARTH V8Я] #1226308
05/05/12 01:11 AM
05/05/12 01:11 AM
Phoenix, AZ
Phoenix, AZ
I have not tried that test. I will give it a try the next its warmed up.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226309
05/05/12 01:50 AM
05/05/12 01:50 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It looks like the radiator is doing a fair job. 34 degrees is good. I'd like to see a bigger drop but wouldn't we all?
Did you check for any cold spots in the core?
- Stu Harmon
Re: Running hot and running out of ideas 67 Belvedere [Re: feets] #1226310
05/05/12 02:02 AM
05/05/12 02:02 AM
Phoenix, AZ
Phoenix, AZ
Nothing to speak of really maybe 2-3 degrees of variation moving across the core in a row type pattern. I am thinking I need to sink the fan in a little closer to rad after looking more closey at things.
I would also like to get the trans cooler mounted independent of the rad core, I cant help but think that would help.
Also looked into different pulley diameters but I am not seeing anything out there in a stamped steel, stock type water pump pulley other than what was on all big blocks of that era. I need to research that more.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226311
05/05/12 02:06 AM
05/05/12 02:06 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Reading through this post reminds me of the time I fought an overheating problem with a '72 400 in a Newport. After going through all the usual details and coming up short, it turned out to be a glazed fan belt. Fan and pump never came up to speed. You never know.
Re: Running hot and running out of ideas 67 Belvedere [Re: 6PakBee] #1226312
05/05/12 02:08 AM
05/05/12 02:08 AM
Phoenix, AZ
Phoenix, AZ
I will look into that situation as well, thanks for tip!
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226313
05/05/12 08:57 AM
05/05/12 08:57 AM
IN
ahy Offline
ahy  Offline
IN
On the drive ratios, as original there was a "with AC" setup that provided overdrive and used a "with AC" WP and a standard setup without the overdrive and matching WP. The overdrive "with AC" was significant. Something like 20-25% from memory.
I wound up with about 7% WP overdrive using repop steel pulleys from Bouchillon on the accessories and a 6" aluminum 4 groove crank pulley from March. The standard steel crank pulley is 7" or 71/4" on most models. I used the smaller crank pullley to slow things down a little on my faster than stock spinning engine.
Reading the update on your testing... it sounds like it gets hot at idle and will not cool off on a roll. You have both "hot at speed" and "hot at idle". Temps on the radiator are pretty consistant so it doesn't have any obvious signs of blockage.
On a roll over 40 MPH, the fan basically doesn't matter. Since you have "hot at speed" there is something going on with the radiator, WP or engine itself. It sounds like the engine block was well cleaned so rule that out. Tuneup with mechanical advance OK. Vacuum advance would help. The high stall convertor and big cooler required adds to the heat load. Mounting the trans cooler independantly would take some stress off the radiator. It may help cooling a little but not a big impact.
How about some more specifics on the WP and radiator? Type and brand of WP and thickness and age and brand of the radiator? Did it always run hot or did it happen over time or after a change? I'm thinking your setup and location just has very high cooling requirements and you need a really high capacity radiator and WP to keep up.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226314
05/05/12 09:19 AM
05/05/12 09:19 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Was the cam degreed correctly during install?
As adviced, I would also suggest to hook up the vacuum advance. But hook it up to direct intake vacuum, otherwise it won't do anything when idling.
If you want to do a quick check upfront to see if the motor likes more advance at idle, just put in some timing. If you're going to drive it, just cruise around, don't hammer it or it might ping perhaps.
Re: Running hot and running out of ideas 67 Belvedere [Re: DARTH V8Я] #1226315
05/05/12 10:42 AM
05/05/12 10:42 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is a very real possibilty, it happened to me. New fan clutch and it was back to normal.
Good luck with it.
I'm betting it a at least a couple factors, not just one.
Re: Running hot and running out of ideas 67 Belvedere [Re: Belvedere1] #1226316
05/05/12 01:04 PM
05/05/12 01:04 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I have been following this thread with interest. This probably isn’t what you are wanting to here but here goes. I had the same problem with my 69 Bee only difference is I have air and had a three core aluminum radiator in it. The radiator was from a n online bargain dealer. I can’t even find him on line now. Since the radiator was new I figured it wasn’t the problem so I started changing things, pump, fans, thermostats, timing, carb tuning, chasing the problem. Nothing helped. Then one day I put a bigger diameter fan on it to see if that would help. Well it helped aright when the fan flexed forward at high rpm and took out the radiator. I ordered a four core radiator from Champion and got a Chrysler 300C electric fan off Ebag for $90. The difference in the core structure between the no name radiator and the Champion was mind boggling. I installed the new parts and the cooling problem is fixed. I drove the car this week in 90 degree temps with the AC on in traffic in town an out on the open high way. It never went above 180 degrees. This is with a 512 wedge.
Re: Running hot and running out of ideas 67 Belvedere [Re: Dabee] #1226317
05/05/12 02:22 PM
05/05/12 02:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
He verified that his radiator is doing it's job. There's no need to look at replacing it.
He needs to find the source of the heat.
A loose converter dumping trans heat into the radiator or blown head gasket would easily cause that problem.
- Stu Harmon
Re: Running hot and running out of ideas 67 Belvedere [Re: Dabee] #1226318
05/05/12 02:28 PM
05/05/12 02:28 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I guess Iam very lucky, my 440 on a warm day will get up to 190 or so if the car is sitting in traffic for awhile but as soon as the car starts moving it cools back down to 175. One thing I have in both of my cars is a Ron Davis radiator.
My combo
.030 over 440
11to1 compression
indy SR heads
.248-.254 solid roller cam
FBO dist
8 inch convertor
3.55 gear
3750 lbs with me in it.
Pro systems carb
Page 3 of 4 1 2 3 4
