Performer vs DP4B Height? #1226205
05/02/12 08:22 PM
05/02/12 08:22 PM
dart1962_440 Offline OP
Does anyone know if the Edelbrock dual plane Performer intake is the same height as the Edelbrock DP4B? In other words, will my carb be at the same height if I switch between these manifolds so my Air Grabber still functions?
Re: Performer vs DP4B Height? [Re: dart1962_440] #1226206
05/02/12 10:21 PM
05/02/12 10:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Performer or performer RPM ??? a regular performer would be a DOWNGRADE from the DP4B , and a DP$4 fits under the stock air grabber , ran one on my 69 bee with N96.
If it's the RPM , not it's TALLER.
Re: Performer vs DP4B Height? [Re: JohnRR] #1226207
05/02/12 10:27 PM
05/02/12 10:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The 383 performer that I have is the same manifold as the DP4B that I have, only flipped front to back in the runner configuration and of course is spreadbore compatible. Runner length, shape and cross sectional area is the same.
Re: Performer vs DP4B Height? [Re: BSB67] #1226208
05/03/12 06:33 PM
05/03/12 06:33 PM
BSB67,
Can you get some type of measurement to see if the height of the manifold/carb mounting flange height is the same?
Re: Performer vs DP4B Height? [Re: dart1962_440] #1226209
05/03/12 10:15 PM
05/03/12 10:15 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Manifold Height Is Listed
Edelbrock Dp4b
Surprise! The oldest design produced the best average power of the dual-planes-of course we're only talking 1-3 numbers better, and that can be testing variance, but still, this thing wasn't at all bad. It's the first of the Mopar aftermarket dual-planes but has not been sold in many years. The DP4B designation means Dodge-Plymouth 4-Barrel, and the C4B (Chrysler 4-Barrel) is for 440s. This intake is most like the stock design, with the smaller of the two planes on the right side and feeding cylinders 2, 3, 5, and 8. The coil bracket is not in the stock location, but even so, many people who want an OE look use this manifold.
Price: Ours was $104.39 on eBay, but maybe the price will jump now.
Manifold height: front 311/44, rear 411/48
Peak torque: 456 lb-ft @ 3,800
Peak horsepower: 445 hp @ 5,900
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Performer vs DP4B Height? [Re: dart1962_440] #1226210
05/03/12 10:15 PM
05/03/12 10:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
One is on the car, and am not sure if I can get you the answer with the precision that I think you are looking for. Also, my Performer is probably 20 years old. I don't believe that the new Performer has changed as mine looks like what is in the current catalog.
Re: Performer vs DP4B Height? [Re: bee1971] #1226211
05/03/12 10:16 PM
05/03/12 10:16 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Edelbrock Performer 383
The Performer is the world's most ubiquitous intake manifold; you can order one from virtually any auto-parts chain. The Performer 383 (PN 2186) is a stock replacement part that's emissions legal for many OE four-barrel applications, and it has provisions for an EGR valve. Its carb pad will accept square-bore or spread-bore carbs. The Edelbrock Performer Package recommended for this intake includes a cam with just 204/214 at 0.050, demonstrating that our 237/242 solid cam is a little too big to match the ideal operating range of this and other low-rise dual-planes in this test.
Price: The satin PN 2186 intake is $189.98 at Summit Racing; a polished version, PN 21861, is $359.88
Manifold height: front 331/48, rear 411/44
Peak torque: 455 lb-ft @ 3,800
Peak horsepower: 439 hp @ 5,900
Siberian Huskies
Re: Performer vs DP4B Height? [Re: bee1971] #1226212
05/03/12 10:22 PM
05/03/12 10:22 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Performer 383
Installation Notes: Recommended intake gasket: #7225. Manifold height: A-3.65", B-4.35", measured to engine block, see A/B Measurements. Port exit dimensions: 1.14" x 2.12".
Siberian Huskies
Re: Performer vs DP4B Height? [Re: bee1971] #1226213
05/04/12 04:37 PM
05/04/12 04:37 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I have one of each manifold that are not installed on an engine. I can compare the heights. I need a few hours....
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: Performer vs DP4B Height? [Re: bschargerse] #1226214
05/05/12 08:58 AM
05/05/12 08:58 AM
bee1971,
Can you clarify the manifold height measurements? 311/44, 411/48 = ???
Re: Performer vs DP4B Height? [Re: BSB67] #1226215
05/05/12 08:58 AM
05/05/12 08:58 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
May look the same but performance wise there IS a difference.
Re: Performer vs DP4B Height? [Re: MoparforLife] #1226216
05/05/12 01:55 PM
05/05/12 01:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've run them back to back on a 13.0/108 mph street car. No difference. I think that there is an article comparing theses manifolds too, if you're one to believe in what you read in magazine articles.
Re: Performer vs DP4B Height? [Re: BSB67] #1226217
05/05/12 05:41 PM
05/05/12 05:41 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I laid the 2 manifolds on the carb mounting face, and the DB4B is about 1/8" taller.
Re: Performer vs DP4B Height? [Re: bschargerse] #1226218
05/05/12 10:17 PM
05/05/12 10:17 PM
bsakal,
Thank you!!
