Re: Performer vs DP4B Height?
[Re: dart1962_440]
#1226209
05/03/12 10:15 PM
05/03/12 10:15 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Manifold Height Is Listed
Edelbrock Dp4b Surprise! The oldest design produced the best average power of the dual-planes-of course we're only talking 1-3 numbers better, and that can be testing variance, but still, this thing wasn't at all bad. It's the first of the Mopar aftermarket dual-planes but has not been sold in many years. The DP4B designation means Dodge-Plymouth 4-Barrel, and the C4B (Chrysler 4-Barrel) is for 440s. This intake is most like the stock design, with the smaller of the two planes on the right side and feeding cylinders 2, 3, 5, and 8. The coil bracket is not in the stock location, but even so, many people who want an OE look use this manifold.
Price: Ours was $104.39 on eBay, but maybe the price will jump now.
Manifold height: front 311/44, rear 411/48 Peak torque: 456 lb-ft @ 3,800 Peak horsepower: 445 hp @ 5,900
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#1226211
05/03/12 10:16 PM
05/03/12 10:16 PM
bee1971
Sobieski Wi
Edelbrock Performer 383 The Performer is the world's most ubiquitous intake manifold; you can order one from virtually any auto-parts chain. The Performer 383 (PN 2186) is a stock replacement part that's emissions legal for many OE four-barrel applications, and it has provisions for an EGR valve. Its carb pad will accept square-bore or spread-bore carbs. The Edelbrock Performer Package recommended for this intake includes a cam with just 204/214 at 0.050, demonstrating that our 237/242 solid cam is a little too big to match the ideal operating range of this and other low-rise dual-planes in this test.
Price: The satin PN 2186 intake is $189.98 at Summit Racing; a polished version, PN 21861, is $359.88
Manifold height: front 331/48, rear 411/44 Peak torque: 455 lb-ft @ 3,800 Peak horsepower: 439 hp @ 5,900
[Re: bee1971]
#1226212
05/03/12 10:22 PM
05/03/12 10:22 PM
bee1971
Sobieski Wi
Performer 383
Installation Notes: Recommended intake gasket: #7225. Manifold height: A-3.65", B-4.35", measured to engine block, see A/B Measurements. Port exit dimensions: 1.14" x 2.12".
[Re: bee1971]
#1226213
05/04/12 04:37 PM
05/04/12 04:37 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
I have one of each manifold that are not installed on an engine. I can compare the heights. I need a few hours....
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
[Re: BSB67]
#1226215
05/05/12 08:58 AM
05/05/12 08:58 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The 383 performer that I have is the same manifold as the DP4B that I have, only flipped front to back in the runner configuration and of course is spreadbore compatible. Runner length, shape and cross sectional area is the same.
May look the same but performance wise there IS a difference.
[Re: BSB67]
#1226217
05/05/12 05:41 PM
05/05/12 05:41 PM
bschargerse
Royersford, PA
I laid the 2 manifolds on the carb mounting face, and the DB4B is about 1/8" taller.
