Hemi crankshaft - rear flange #1226111
05/02/12 06:38 PM
05/02/12 06:38 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
I am looking at buying this (new) crankshaft.
I've checked the spec-sheet etc from the seller and I am comfortable with it.
As I don't have a reference part to check against (it's in the US and I am in Australia), I need to check if the flywheel flange will work for my combo or I can make it work.
These are my only concerns & hopefully you guys can set me straight:
1. it doesn't have a step-register for flywheel .?.
2. doesn't have locating dowels for flywheel ? the bolts carry the entire locating load as well as clamping load is that ok?
Sorry about pic quality. if anyone has pictures of std Hemi forged crank flywheel flange it'd be appreciated. otherwise i may have to go down a custom flywheel route to suit this crank.
cheers, Darren
Darren Beale
Keith Black Racing Engines®
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226112
05/02/12 06:50 PM
05/02/12 06:50 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
That is a fueler crank flange and it uses a flywheel like an earlier Hemi, they had a flywheel that was located by the OD of the flange.
I'm pretty sure KB sells an insert to give you a converter/flywheel register in the center or you could just make one when you get the crank .
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226113
05/02/12 07:01 PM
05/02/12 07:01 PM
AndyF Offline
AndyF  Offline
Those cranks are usually not a good idea. Besides the flat flange, they often use a different keyway up front, and are usually super heavy. There was a post recently from a guy trying to figure out how to get a special damper made so it would fit the crank that he got a good deal on.
Re: Hemi crankshaft - rear flange [Re: AndyF] #1226114
05/02/12 07:58 PM
05/02/12 07:58 PM
QLD Australia
QLD Australia
Thx Andy. the seller has indicated bobweight 2450g .. is that heavy? it's EN30B crower. it's the right stroke that I am after (4.5) but has larger 2.375 journals.
I would need to be able to run Milodon gear drive and ATI balancer. it has 2 x 1/4 keyways which is ok as I am running blower pulley.
here's a pic of the snout:
Darren Beale
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226115
05/02/12 08:08 PM
05/02/12 08:08 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The register on your ATI is 2.25 and the register on the blower pullies are 2.00.You will need to open the the ID of the spacer deep enough for the spacer to be flat on the damper.
The crank needs the insert for the register.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi crankshaft - rear flange [Re: AndyF] #1226116
05/02/12 08:11 PM
05/02/12 08:11 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i have one in my engine i think my bobweight is 2385. the flange is thicker than a normal crank. so you have to either cut down the flange or the lugs on the conveter. i dont know what to tell you about a flywheel,in the end i dont have a problem using fueler cranks.
Re: Hemi crankshaft - rear flange [Re: ro23car] #1226117
05/02/12 08:43 PM
05/02/12 08:43 PM
QLD Australia
QLD Australia
the asking price for this crank is about the same as a new forged 4340 crank from crower. it isa great looking crank but is looking like hard work.
so I am tossing up whether the strength difference is worth the effort for the things i will have to accommodate, like:
-weight difference ??
-rear flywheel flange machining and/or custom flywheel etc
-special balancer
-any extra work required as a result of dealing with the above
crank will need to be strong enough to handle infrequent use at 1,500hp & 1,200 ft/lbs.
?? &the 4340 may bolt straight in.
Darren Beale
Re: Hemi crankshaft - rear flange [Re: ro23car] #1226118
05/02/12 08:45 PM
05/02/12 08:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would get a K1 or Callies, the K1 is around 600.00 USD, the Callies is about double that if you are lucky to find one for that price. Tim
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226119
05/02/12 08:55 PM
05/02/12 08:55 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
-special balancer
no issues with my ati balancer. jus have the flange cut down. i have 1 in my engine and 1 spare.
Re: Hemi crankshaft - rear flange [Re: astjp2] #1226120
05/02/12 09:00 PM
05/02/12 09:00 PM
QLD Australia
QLD Australia
...Serious?
..a $600 crank in a $30k engine just doesn't "feel" right!
I may be wrong, any feedback on these cranks?
Darren Beale
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226121
05/02/12 10:02 PM
05/02/12 10:02 PM
hemi-itis Offline
hemi-itis  Offline
By the time you get done with the bells & whistles,your better off with a billit crank and have no doubt
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226122
05/02/12 10:21 PM
05/02/12 10:21 PM
Delray beach, Florida
P
Performance Only Offline
P
...Serious?
I handle the K-1 and Callies brands, as well as a few others, but before i could make a recommendation on a crankshaft, i'd want to know which power adder you'll be using to make 1500 HP and how much of it is the power adder vs. N/A ?
machine shop owner and engine builder
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226123
05/02/12 10:52 PM
05/02/12 10:52 PM
Buy the new 426 type Crower forged steel crank and have it made the way you want it I use to buy used Top fueler cranks like those, a lot of guys did in SO CA and use them in wedge motors, it takes some work and modifications to make them fit and work. That was before the cheaper Chinese imported cranks where available. I buy and use the forged 4340 Ohio brand stroker cranks now, they have the Hemi 8 bolt flange on them BTW, Ohio Crankshaft CO is offering billet steel cranks now also
Re: Hemi crankshaft - rear flange [Re: astjp2] #1226124
05/02/12 10:57 PM
05/02/12 10:57 PM
U.S.S.A.
U.S.S.A.
I would get Callies, the K1 is around 830.00 USD, the Callies is about double that if you are lucky to find one for that price. Tim
Fixed
The K1 of today is no longer the K1 of yesterday, the K1 is now completely an offshore part including finish machining.
Wayne Brewer has a NEW 4.5" Callies for sale in the race parts section
Re: Hemi crankshaft - rear flange [Re: hemi-itis] #1226125
05/02/12 11:47 PM
05/02/12 11:47 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i believe he is talking about a billet crank.
Re: Hemi crankshaft - rear flange [Re: ro23car] #1226126
05/03/12 01:29 AM
05/03/12 01:29 AM
QLD Australia
QLD Australia
Do you mean the rear flange? this is the spec:
rear flange is 4.8125 diameter with a 2.0504 diameter x .140 deep counter bore and a .907 diameter x 1.125 deep pilot bearing hole
Do you know if the front /snout dimensions are standard on one of these cranks ?
Is it heavy at 2,450g?
My calculations for this scenario depending on my rod choice, dictate that the pistons + rings + pins + locks + oil with a compression height of between 1.375-1.575 and 35cc dome would weigh in at circa 935g to 1,025g.
Does this range sound about right ,or would the crank be too heavy?
thanks of your help
Darren Beale
Re: Hemi crankshaft - rear flange [Re: JohnRR] #1226127
05/03/12 02:34 AM
05/03/12 02:34 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Sounds like what you need is
I bought mine from Keith Black.
That would be me, the damper is supposed to arrive sometime today (Thursday).
The problem was that the crank (a Keith Black Billet) had 2, 1/4 inch key-ways cut in it (one at 90 degrees and at 270 degrees).
My engine builder said if I wanted to build it right, just order the custom made damper and be done with it.
Most people said broach a key-way at 0 degrees and silicone or epoxy the extra key-ways and use an off the shelf harmonic balancer.
He said, "No, it will leak oil from there!"
Since he's the expert building it, not me, I order the balancer.
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226128
05/03/12 08:22 AM
05/03/12 08:22 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
thanks of your help
what you have to do is measure the thickness of the the rear flange,then have it cut to atch that of a regular crank. i have a automatic trans i made up the difference by cutting the lugs down on the converter.
Re: Hemi crankshaft - rear flange [Re: Keith Black®] #1226129
05/03/12 02:34 PM
05/03/12 02:34 PM
The depth of the backside(transmission side) of the crankshaft flange to the back of the block is different(longer) on the old top fuler cranks than the stock later model(1962 and up) cranks are Several solutions as already mentioned, one not mention is a thin spacer plate between the trans and block to move the trans back from the crank flange
Re: Hemi crankshaft - rear flange [Re: Cab_Burge] #1226130
05/03/12 07:48 PM
05/03/12 07:48 PM
QLD Australia
QLD Australia
any idea of what the difference is ..? maybe i could machine the flange thinner leaving a step register.
Darren Beale
