Dart drive shaft length #1225858
05/02/12 06:27 AM
05/02/12 06:27 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Any body know the stock center to center distance on a Dart with a 727 and a 8 3/4 ? I have a friend who needs a shaft for a street project. A used shaft will do.
Thanks Doug
Re: Dart drive shaft length [Re: dvw] #1225859
05/02/12 01:05 PM
05/02/12 01:05 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
should be right at 48" u-joint center to center
Re: Dart drive shaft length [Re: dvw] #1225860
05/02/12 01:12 PM
05/02/12 01:12 PM
Get a 727 trans yoke and slide it in the trans. all the way and then pull it out 3/4 to one inch and measure from the center of the U joint hole to the center of the pinion yoke hole on the car yyour wanting the driveshaft for Thats the length you need. Make sure the car is on jackstands under the rear end so the weight is like it would be with the tires on the ground like it is when ready to drive
Re: Dart drive shaft length [Re: Cab_Burge] #1225861
05/02/12 08:51 PM
05/02/12 08:51 PM
BDW Offline
BDW  Offline
Re: Dart drive shaft length [Re: BDW] #1225862
05/02/12 08:52 PM
05/02/12 08:52 PM
BDW Offline
BDW  Offline
Re: Dart drive shaft length [Re: BDW] #1225863
05/03/12 07:03 PM
05/03/12 07:03 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thanks guys. i know how to measure for it. This is a basically stock build. He is looking for junkyard/swap meet shafts. The car is apart. 48' will do nicely.
Doug
Re: Dart drive shaft length [Re: dvw] #1225864
05/08/12 11:08 PM
05/08/12 11:08 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Geoff said you could have his stock shaft out of his dart. Is this for Danny's buddy?
Remind me next time I see you...
