Another guess my HP post #1225833
05/02/12 01:30 AM
05/02/12 01:30 AM
Las Vegas NV
moparmanjames Offline OP
Las Vegas NV
Ok I dynoed my 526 wedge today, it's a fairly common setup here so I expect some close guesses, here are the specs:
440 hard blocked, 4.375 bore x 4.375 stroke
Indy SR heads, ok port job, flow 325 @ .700", 1.6 rockers,Comp roller cam 283* at .050" .704" lift 108 lca.
12.2:1 compression, 1050 Dominator,Indy intake
7.1 rods, ross pistons, main girdle, wet sump with stock oil pump external lines.
What did she make?
Re: Another guess my HP post [Re: moparmanjames] #1225834
05/02/12 01:36 AM
05/02/12 01:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
750 or so!
Re: Another guess my HP post [Re: Sport440] #1225835
05/02/12 01:39 AM
05/02/12 01:39 AM
houston texas
gremlinsteve Offline
houston texas
747
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Another guess my HP post [Re: gremlinsteve] #1225836
05/02/12 01:26 PM
05/02/12 01:26 PM
Las Vegas NV
Las Vegas NV
You guys are too kind, it only made 722 hp at 6200 rpm and 680 tq at 4500, I'll try and get some video up later
Re: Another guess my HP post [Re: moparmanjames] #1225837
05/02/12 09:57 PM
05/02/12 09:57 PM
Las Vegas NV
Las Vegas NV
Thanks for all the replies, it was a pretty underwhelming number haha.
Re: Another guess my HP post [Re: moparmanjames] #1225838
05/03/12 01:11 AM
05/03/12 01:11 AM
Idaho
LaRoy Engines Offline
Idaho
Underwhelming? I think not. How many people on this planet can PROVE they are capable of making 722 HP?
Re: Another guess my HP post [Re: LaRoy Engines] #1225839
05/03/12 02:51 PM
05/03/12 02:51 PM
Las Vegas NV
Las Vegas NV
Yeah but in this day of huge stroker motors and forced induction, 700 hp is not as impressive as it used to be. Granted, mines naturally aspirated but there's a lot of guys getting 700hp from stroker small block combos.
It will be fun nevertheless.
Re: Another guess my HP post [Re: moparmanjames] #1225840
05/03/12 03:06 PM
05/03/12 03:06 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
You could have made a boatload more steam too, if you had more head/cam/manifold/etc.. Stroker smallblocks, even with iron W2s (fully ported) outflow the SRs you have. Killer smallblock heads go well over 400cfm of "good" air.
I think you have a nice tame combo there that will run like a champ.
Re: Another guess my HP post [Re: jim sciortino] #1225841
05/03/12 04:38 PM
05/03/12 04:38 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
A good 10.50 combo in Vegas :P
Re: Another guess my HP post [Re: jim sciortino] #1225842
05/03/12 04:52 PM
05/03/12 04:52 PM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
And be reliable and live for a while!!
Re: Another guess my HP post [Re: J_BODY] #1225843
05/03/12 07:05 PM
05/03/12 07:05 PM
Las Vegas NV
Las Vegas NV
Thanks J, I just hope it lives long and runs half as decent as your Stage 6 motor.
Re: Another guess my HP post [Re: Moparnut426] #1225844
05/03/12 07:08 PM
05/03/12 07:08 PM
Las Vegas NV
Las Vegas NV
Thank guys, reliability was high on my list, I didn't want to be spinning it up to 7000, just chug down the track without breaking any rockers.
