WideBand 02 Results #1225590
05/01/12 08:07 PM
05/01/12 08:07 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Finally got the Innovate Wideband 02 in AND working properly.
Took it out for its 1st drive.
Idle 13.5--14.5
Cruise 11.7--12.2 rich
Power 13.5 steady too lean.
So now the chase begins.
Max power is pretty easy to fix,cruise may be more of a challenge.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: WideBand 02 Results [Re: 6bblFLASH] #1225591
05/01/12 08:39 PM
05/01/12 08:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
it is still progress knowing the results!what is the carb list# and any mods to it?
Re: WideBand 02 Results [Re: 6bblFLASH] #1225592
05/01/12 09:01 PM
05/01/12 09:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont even waste my time using it for idle... get
it so it idles nice then take a reading... like you
said cruise is always the harder part
Re: WideBand 02 Results [Re: MR_P_BODY] #1225593
05/01/12 10:12 PM
05/01/12 10:12 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Is there anything else out there worth purchasing , other than the innovate lm-2 ????? thanks ,pat
Re: WideBand 02 Results [Re: pattyboy 572] #1225594
05/01/12 10:34 PM
05/01/12 10:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Pat,do you have a RoadRunner?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: WideBand 02 Results [Re: 6bblFLASH] #1225595
05/01/12 10:41 PM
05/01/12 10:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t focus too much on idle either as long as it`s crisp and clean and doesn`t load up I`m cool w/that...........cruise however is a bear w/my 1050 which varies a bit bet. 11.8-12.5 accordingly and wot is around 12.5-12.8.................
Re: WideBand 02 Results [Re: Thumperdart] #1225596
05/01/12 11:11 PM
05/01/12 11:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Even at WOT I still run for best MPH then take a
reading so its easier to get back to that if I change
something... cruise is always the hard point... is
it on the level... up a minor grade... it all plays in
Re: WideBand 02 Results [Re: 6bblFLASH] #1225597
05/01/12 11:23 PM
05/01/12 11:23 PM
Andrews,In. U.S.of A.
67_Satellite Online content
67_Satellite  Online Content
Bear in mind that if you have a "perfect" 14.7:1 a.f.r. at cruise, you'll probably have a few lean and rich cylinders somewhere. I got to the high 13's at cruise and called it good enough. I have my o2 sensor mounted 12" from the turbine outlet, so I know all the exhaust is thoroughly mixed by then.
Re: WideBand 02 Results [Re: hemi-itis] #1225598
05/01/12 11:41 PM
05/01/12 11:41 PM
new york usa
P
P
new york usa
yes al its me........
Re: WideBand 02 Results [Re: 6bblFLASH] #1225599
05/02/12 08:21 AM
05/02/12 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
drop the primary jetting one and add one to the 2ndary. I ran 74/86's in my S/C'd 440. Pretty much the same engine you have. Very mild 440 w/ 6psi of boost. No idea of my readings all I had was the cheapo A/F gague w/ the red yellow yellow green yellow yellow red lights. stayed in the green to 1st yellow al the time.
Coming soon!!!!
Re: WideBand 02 Results [Re: Mr.Yuck] #1225600
05/02/12 08:41 AM
05/02/12 08:41 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Sorry to Hijack but here's a lttle tip.
DO NOT leave the plastics protective covers on the end of your O2 sensors, while you turn the power on checking out your new ignition system. The sensor heaters will melt them and damage the sensors.
Dont ask me how I know
Re: WideBand 02 Results [Re: Tig] #1225601
05/02/12 08:58 AM
05/02/12 08:58 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
You have to approach it in the following order:
-Idle
-Transition
-Cruise
-Moderate powering up
-WOT
Each circuit plays into WOT (even if it's small). You do that one LAST!
Re: WideBand 02 Results [Re: 67_Satellite] #1225602
05/02/12 10:19 AM
05/02/12 10:19 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
If you are running 10% ethanol pump gas your ideal AFR is 14.1 to 1.
Re: WideBand 02 Results [Re: Dabee] #1225603
05/02/12 11:21 AM
05/02/12 11:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thanks for posting that chart. I recently decided to just suck it up and start putting the 10% ethanol in my car. The 100% gas is hard to find and around here they are asking as much at .25-.40 more per gallon for it. I have some jetting to do.
68 Barracuda Formula S 340
Re: WideBand 02 Results [Re: Dabee] #1225604
05/02/12 02:37 PM
05/02/12 02:37 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
While that may be technically true you can only use that info IF your wideband system is SET with a 14.1:1 stoich value. If your system is set to display gasoline stoich of 14.7:1 you can still use 14.7 as a stoich value when reading the numbers displayed regardless what fuel you're using.
Wideband systems measure oxygen presence and produce a variable numerical output value represented by the Greek letter Lambda. The value for Lambda at stoichiometry is 1.00. If the wideband system user sets the device to display s stoichiometry value of 14.7 (or any other number) the device simply multiplies Lambda by 14.7 (or whatever number is used). This does not change anything about how the device makes the measurement and the device does not care what fuel is being used.
Whoever created that chart was well-meaning and technically correct but has created a communication nightmare where now people can't disuss AFRs without stating what stoich value the reading was taken with (and requiring math to convert to ones familiar scale). It would be much better if everyone just used Lambda (1.00) or 14.7, regardless what fuel is being used. The wideband system doesn't know or care.
Re: WideBand 02 Results [Re: 6bblFLASH] #1225605
05/02/12 04:00 PM
05/02/12 04:00 PM
Idle 13.5--14.5
I'm going to assume when you say power you mean at W.O.T., if not what do you mean? Your idle AFR are good, I do run my pump gas motor leaner than that, 14.8 to 16.0 depending on outside air temps as far as cruise I like an duse real close to 13.8 to 15.0, WOT I shoot for 12.8 to 13.3, not the best for a boosted motor so I would shoot for 12.2 to maybe as lean as 12.8, depending on what the spark plugs look like( all eight plugs) It is way safer to start out rich and then slowly lean it down to where you like it The transition circuits are real fun to tune
Re: WideBand 02 Results [Re: Cab_Burge] #1225606
05/02/12 06:27 PM
05/02/12 06:27 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
pat this another option. small simple and has a display built in live.
Re: WideBand 02 Results [Re: dmking] #1225607
05/02/12 06:30 PM
05/02/12 06:30 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
Re: WideBand 02 Results [Re: @#$%&*!] #1225608
05/02/12 10:28 PM
05/02/12 10:28 PM
NC
440Jim Offline
440Jim  Offline
NC
The wideband <oxygen> system doesn't know or care.
That is the beauty of the wide band oxygen sensor system.
I have used my wide band oxygen sensor with race gasoline, alky (methanol) and E-85 ethanol. It measures Lambda, I typically display A/F based on 14.7 (gasoline) since those numbers are in my head. I don't bother converting to actual A/F for the various fuels; as long as you know what numbers to look for, it don't matter. And the absolute number isn't all that important anyway, just a range.
Re: WideBand 02 Results [Re: @#$%&*!] #1225609
05/02/12 11:26 PM
05/02/12 11:26 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Agree, that is why I have my wideband set to display the Lambda number.
