where can I get those lift off hood prop things? #1225426
05/01/12 02:16 PM
05/01/12 02:16 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
you know the things that hood the hood up at about roof level? these...
Coming soon!!!!
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225427
05/01/12 02:33 PM
05/01/12 02:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Build them. It's not that hard.
- Stu Harmon
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225428
05/01/12 02:43 PM
05/01/12 02:43 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
http://a12mopar.com/yabb/YaBB.pl?num=1273161148/11#11
A gentleman named Paul, over at the A12 Forum, makes them.
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: where can I get those lift off hood prop things? [Re: 68X426] #1225429
05/01/12 02:53 PM
05/01/12 02:53 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I think that's where that picture came from and thetalk was $350 a set, that's about 5x what I'd like to pay. I guess I could make them but if somebody had a set for under $100 I'd probably buy a set.
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225430
05/01/12 03:01 PM
05/01/12 03:01 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Not sure how fancy you want them, but I bet they could be made out pipe, with a few holes. A little rednecky, but I may do that myself.
Re: where can I get those lift off hood prop things? [Re: Dodgeguy101] #1225431
05/01/12 03:26 PM
05/01/12 03:26 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
not too worried about that it will be more for function than form.
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225432
05/01/12 03:47 PM
05/01/12 03:47 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Sets for around $200 in the "deals" section here on Moparts. You've either got to machine the tops to be narrow and fit through the hood-pin holes, or actually mount 4 hood pins onto poles, so I guess there is some cost to them either method.
Darren
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225433
05/01/12 04:00 PM
05/01/12 04:00 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
PVC pipe, bush the top down to fit thru the hole in the hood, bushing would hold the hood up and drill a hole thru top little pipe to hold the hood. Drill the lower pipe to put a pin thru to hold the upright thru the lower pin mounted on the car. Paint them black or whatever color. Make them for 20.00, any length you wanted. I should patent this, make a fortune.
Re: where can I get those lift off hood prop things? [Re: Dodgeguy101] #1225434
05/01/12 05:08 PM
05/01/12 05:08 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
probably could use small PVC pipe w/ threaded rod at the top. Drill a few holes for the hood pins, slam it w/ some cast Alum paint and done. Might do it this weekend
Re: where can I get those lift off hood prop things? [Re: Dodgeguy101] #1225435
05/01/12 05:11 PM
05/01/12 05:11 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Yes, you should patent that idea... Although I doubt if you would sell many to guys interested in supporting a $1000 hood about 18" above a several-thousand dollar paint job on a nice car. As I said before, I think there is a reason that they aren't cheaply-made, I don't know how much wind your PVC idea would resist.
Darren
Re: where can I get those lift off hood prop things? [Re: Ludington1] #1225436
05/01/12 05:20 PM
05/01/12 05:20 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Darren
a lot especially if it was cored w/ wood.
Re: where can I get those lift off hood prop things? [Re: Mr.Yuck] #1225437
05/01/12 08:38 PM
05/01/12 08:38 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i made a set out of electrical conduit (home depot) and pipe connectors with 4 large bolts through the hood pin holes.
Re: where can I get those lift off hood prop things? [Re: mikemee1331] #1225438
05/01/12 09:13 PM
05/01/12 09:13 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I wouldn't use PVC. If you don't go the conduit route you can get aluminum rod from McMaster-Carr or MetalsDepot, shape the ends to look like hood pins, drill holes above and below where the hood goes and then install sleeves to go over the original pins.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: where can I get those lift off hood prop things? [Re: Ludington1] #1225439
05/01/12 10:12 PM
05/01/12 10:12 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Darren
I guess you didn't notice the 2 guys laughing..
Re: where can I get those lift off hood prop things? [Re: Dodgeguy101] #1225440
05/01/12 10:26 PM
05/01/12 10:26 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Theres a vinyl top on that A12, so I don't see a big deal about putting the hood on the roof. I also think those prop rods are just plain stupid, in my opinion anyways.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: where can I get those lift off hood prop things? [Re: DARTH V8Я] #1225441
05/02/12 08:11 AM
05/02/12 08:11 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
my roof is painted, more for "storage" at the track than anything. A good gust of wind and it will flip over, flop around or fall. This will keep the hood up and out of the way and I still can work on the engine if need be between rounds. I wouldn't be using it for "display" purposes.
