timing gears #1225279
05/01/12 07:30 AM
05/01/12 07:30 AM
Home of the Bluegrass
MoparJunkie Offline OP
When lining timing marks dot to dot... Is that not on exhaust stroke? If both marks are at 12 That is compression right???
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: timing gears [Re: MoparJunkie] #1225280
05/01/12 07:50 AM
05/01/12 07:50 AM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
That is correct.
Re: timing gears [Re: MoparJunkie] #1225281
05/01/12 02:34 PM
05/01/12 02:34 PM
When the crank gear dot is at 12 o:clock and the cam gear dot is at 6 o:clock your at the start of the intake stroke and at the end of the exhaust stroke on number one cylinder so you are in the overalp of both valves When both gears dots are at 12 o:clock your at TDC of number one piston on the firing (power) stroke or at the end of the compression stroke
