rack and pinion and backing up
#1224742
04/30/12 11:16 AM
04/30/12 11:16 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my tires toe in when i'm backing up. I have read something about this on here a long time ago. what causes this to happen?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: rack and pinion and backing up
[Re: sixpackgut]
#1224743
04/30/12 11:21 AM
04/30/12 11:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Couple of questions.. whats the front end alignment and is there a spacer from the tie rod to the steering arm
[Re: sixpackgut]
#1224745
04/30/12 12:11 PM
04/30/12 12:11 PM
MR_P_BODY
Are you still running stock upper and lower arms and are they rubber mounted... with a 1/4" of toe in are you covering up a possible toe out condition
[Re: sixpackgut]
#1224747
04/30/12 12:39 PM
04/30/12 12:39 PM
MR_P_BODY
i have junky uppers that i got off ebay. dont like them. i cut some of the bushing out and spaced it backwards to get as much caster as i could. the manual for pintos calls for 1/8 to 3/8th toe in so thats where i got it at. it feels good going down the road
You have a point or multiple points moving... on my rack set ups all the points are heim joints and dont move... also I dont put any spacers on the tie rod at the steering arm... they flex... plus a lot of caster tends to do it when backing up... I have 10* caster on the race car with no issues... I have 6* on the Rampage but its not on the road yet... both of these are strut cars
[Re: MR_P_BODY]
#1224748
04/30/12 12:45 PM
04/30/12 12:45 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Had the same issue when i first installed, never had alignment performed.(full cap system)..tube up and lowers ,coil over,rack n pinion....after 4 wheel alignment ,never had a problem again...i was told my caster was really out
[Re: pattyboy 572]
#1224749
04/30/12 01:13 PM
04/30/12 01:13 PM
sixpackgut
Charleston
OK, I will work on it. Thanks
