Had the same issue when i first installed, never had alignment performed.(full cap system)..tube up and lowers ,coil over,rack n pinion....after 4 wheel alignment ,never had a problem again...i was told my caster was really out
OK, I will work on it. Thanks
Gen 3 power 6.22@110, 9.85@135
Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
