rack and pinion and backing up #1224742
04/30/12 11:16 AM
04/30/12 11:16 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
my tires toe in when i'm backing up. I have read something about this on here a long time ago. what causes this to happen?
Re: rack and pinion and backing up [Re: sixpackgut] #1224743
04/30/12 11:21 AM
04/30/12 11:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Couple of questions.. whats the front end alignment
and is there a spacer from the tie rod to the steering
arm
Re: rack and pinion and backing up [Re: MR_P_BODY] #1224744
04/30/12 12:00 PM
04/30/12 12:00 PM
Charleston
Charleston
arm
i have not had a machine alighnment. it has about 7* of caster. 0 camber. and 1/4inch toe.
and there was a spacer on the arms already and i cut them off because it was changing toe to much. my rack is maybe to high because i have it in the k frame
Re: rack and pinion and backing up [Re: sixpackgut] #1224745
04/30/12 12:11 PM
04/30/12 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you still running stock upper and lower arms
and are they rubber mounted... with a 1/4" of toe in
are you covering up a possible toe out condition
Re: rack and pinion and backing up [Re: MR_P_BODY] #1224746
04/30/12 12:30 PM
04/30/12 12:30 PM
Charleston
Charleston
i have junky uppers that i got off ebay. dont like them. i cut some of the bushing out and spaced it backwards to get as much caster as i could. the manual for pintos calls for 1/8 to 3/8th toe in so thats where i got it at. it feels good going down the road
Re: rack and pinion and backing up [Re: sixpackgut] #1224747
04/30/12 12:39 PM
04/30/12 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have a point or multiple points moving... on my
rack set ups all the points are heim joints and dont
move... also I dont put any spacers on the tie rod
at the steering arm... they flex... plus a lot of
caster tends to do it when backing up... I have 10*
caster on the race car with no issues... I have 6*
on the Rampage but its not on the road yet... both
of these are strut cars
Re: rack and pinion and backing up [Re: MR_P_BODY] #1224748
04/30/12 12:45 PM
04/30/12 12:45 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Had the same issue when i first installed, never had alignment performed.(full cap system)..tube up and lowers ,coil over,rack n pinion....after 4 wheel alignment ,never had a problem again...i was told my caster was really out
Re: rack and pinion and backing up [Re: pattyboy 572] #1224749
04/30/12 01:13 PM
04/30/12 01:13 PM
Charleston
Charleston
OK, I will work on it. Thanks
