Went to Dragway 42 today and ...FIXED!!! #1224569
04/29/12 10:55 PM
04/29/12 10:55 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
The first pass went [Email]11.60@115[/Email] 1.64 60ft. Then on the second pass engine felt a little flat and when I pulled up to get my time slip the engine sounded like it was missing.
Get back to the trailer and it was definitely missing.
So we loaded up and pulled the valve covers at home and found that #1 exhaust and #4 intake rocker arm adjuster was backed way off.
These are Harland Sharp rockers. Has anyone else had this problem?
The bottom side of the rocker where the adjuster goes though has some thread damage from the push rod.
Re: Went to Dragway 42 today and got a new best, but... [Re: Todd] #1224570
04/29/12 11:04 PM
04/29/12 11:04 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Had a set of HS rockers on another smallblock once and had the same thing happen, took the adjuster out and run a tap thru and cleaned the threads and put the adjuster back in, I found I had not tightened the adjuster's that loosened up enough, snugged them just a little more and had no more problems.
Re: Went to Dragway 42 today and got a new best, but... [Re: dartman366] #1224571
04/30/12 09:39 AM
04/30/12 09:39 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
The bottom 2 threads got taken out by the push rod.
What is the torque on the adjusters and the hold downs?
Re: Went to Dragway 42 today and got a new best, but... [Re: Todd] #1224572
04/30/12 02:47 PM
04/30/12 02:47 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I know T@D calls for a torque value of 5 to 20 inch pounds, the problem is pulling the aluminum threads in the rocker body so I would call HS and have them give you an answer, looks like you still have 95% of the thread still there, I would tap them and run them.
Re: Went to Dragway 42 today and got a new best, but... [Re: dartman366] #1224573
04/30/12 03:01 PM
04/30/12 03:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yep I would concur that it is just a case of not enough torque on the adjuster nut. Plenty of meat left there I would not hesitate to run it. I could show you want we did just running it on jackstands in the pits this weekend. Much uglier than what you ahve there.
Re: Went to Dragway 42 today and got a new best, but... [Re: Al_Alguire] #1224574
04/30/12 06:42 PM
04/30/12 06:42 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks, I guess I got lucky. Does 20ft. lbs. right for the jam nut on the adjuster?
Re: Went to Dragway 42 today and got new best but...see pic [Re: Todd] #1224575
04/30/12 07:18 PM
04/30/12 07:18 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
YEP Yep Yep... Had identical problem with Harland Sharpe Rockers. I think they went thru a bad batch of adjustors and we had issues until we replaced ALL of the adjustors and lock nuts. Alhough my cousin just went thru the same issue on one of his intake rockers this weekend, I STILL believe they are the best rocker arms for a Mopar. Just my opinion.
Good luck
Old Geezer Racing
Re: Went to Dragway 42 today and got new best but...see pic [Re: SCATPACK 1] #1224576
04/30/12 11:26 PM
04/30/12 11:26 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Switch to T&D rockers and you'll never have that problem again. It solved mine.
Re: Went to Dragway 42 today and got new best but...see pic [Re: mloboda] #1224577
05/01/12 12:38 AM
05/01/12 12:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry to hear about the rockers but congrats on the new best. Ron
Re: Went to Dragway 42 today and got new best but...see pic [Re: 383man] #1224578
05/01/12 01:20 AM
05/01/12 01:20 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
You need to be very carefull choosing a tap to clean this up. Get a very good one, not el-cheapo tap. I found this out the hard way. Actually, you would be better off taking a good new grade 8 3/8x24 bolt and cutting a slot up to about the 4th thread and clean out the rocker arn with it. I tried to fix a rocker at the track one time and borrowed a cheap tap and it cut the threads so loose that the adj bolt just wobbled around in the rocker.
Just my 2 cents worth.
Brian Dunnigan
Re: Went to Dragway 42 today and got new best but...see pic [Re: '72CudaRacer] #1224579
05/01/12 02:02 AM
05/01/12 02:02 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Brian Dunnigan
good point
Re: Went to Dragway 42 today and got new best but...see pic [Re: dartman366] #1224580
05/01/12 07:24 AM
05/01/12 07:24 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
I have a thread chase kit. Have also cleaned up treads with a notched bolt.
Thanks.
Re: Went to Dragway 42 today and got new best but...see pic [Re: Todd] #1224581
05/01/12 09:31 AM
05/01/12 09:31 AM
an8sec70cuda Offline
Like everyone else said, only time I've had that happen w/ my Harland Sharps was when I didn't get the adjuster tight enough. I ran a tap through it, put it back together, and haven't had any trouble since.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Went to Dragway 42 today and got new best but...see pic [Re: an8sec70cuda] #1224582
05/01/12 10:47 PM
05/01/12 10:47 PM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
Thanks for everyone's advice. Got the threads cleaned up and reassembled everything. Fired it up and we're back in business.
Thanks again everyone!!!
Now it's off to Magnolia for their test and tune this weekend.
