Page 4 of 5 1 2 3 4 5
Re: 10:1 Mild Stroker 416s - output? #1222
08/12/03 09:26 AM
08/12/03 09:26 AM
CT - just outside Hartford
Crazy73 Offline OP
Crazy73  Offline OP
Pete, going to a roller is going to cost you $1,000. Even going to a solid flat tappet will be an extra $80 for pushrods... If you plan to keep the power brakes, I wouldnt recommend anything bigger than say 240 @ .050 with a hydraulic and 245ish with a solid. Thats the ragid edge. And nothing tighter than 108 or so on the LSA either.
IMO, with a street type application (6000 rpm or so), a good newer design hydraulic cam is going to make within 10-15 horsepower of a solid cam of similar rpm range. An apples to apples comparison years ago with my car showed a 12.19 @ 114 with the 3844 Hughes hydro and a 12.08 with the 4550 solid..
Ok, the $1k is close to what I remembered when I decided to buy the Ebrocks. It was either the Ebrocks or the roller cam, and I opted for the heads with more potential. It was the right choice for my purposes.
I don't have power brakes, so that's not an issue. Front disc/rear drum. Does that influence a reccomendation at all?
The lower I can shift, the better
Pete
-1968 Barracuda 4spd 383-6pk
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1223
08/12/03 09:39 AM
08/12/03 09:39 AM
I edited my above post to show you the new hydraulic cam by Hughes. Take a look at what they have.
As far as the power brakes thing goes, and for my recommendation, no it doesn't change much. There are ALOT of guys that are much better at this than me. I'm just thinking about your current converter, gearing, and the fact that you drive your car so much. All this talk about how the difference between a 360 and a 408 is night and day, well I can tell you this. 340's do not make anywhere near the torque that a 360 does. Now go from 340 to a 414 and you are in for some serious attitude change there buddy. I can only imagine what it would be like to air out such a car/engine combo with 3.55 gears on the freeway.
Re: 10:1 Mild Stroker 416s - output? #1224
08/12/03 02:07 PM
08/12/03 02:07 PM
Crazy73 Offline OP
Crazy73  Offline OP
Right, I don't want to redo the whole car, just use what I have and make the most of it. The engine will be redone simply because I dont know it is properly balanced, the pistons are cast (ugh!), it takes a bit of oil (no smoke) and I want to make sure it is done right. Who knows, maybe this 340 has the 4 middle rods installed with the chamfer/squirters on the wrong sides like my old one did
BTW, the 3.55s on the highway are fun now - cant imagine what they would be like with more torque and hp
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1225
08/12/03 03:11 PM
08/12/03 03:11 PM
once you get in to the 240 @ .050 / .510" mark with some good flowing heads / exhaust / proper air-fuel, you will be near 500 HP and over 500 ft. lbs. of torque. 3.55's are a great gear ratio for this combo. And even better if you stuff a Keisler 5 speed in there down the road.
Re: 10:1 Mild Stroker 416s - output? #1226
08/12/03 08:52 PM
08/12/03 08:52 PM
Crazy73 Offline OP
Crazy73  Offline OP
I will probably need to beef up my 727 then? (Rated for 450hp) or drive it till it pops?
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1227
08/12/03 10:13 PM
08/12/03 10:13 PM
Drive it 'til it pops and then put a stick in it
Re: 10:1 Mild Stroker 416s - output? #1228
08/12/03 11:05 PM
08/12/03 11:05 PM
Crazy73 Offline OP
Crazy73  Offline OP
Are the stroker cranks drilled for a pilot bushing?
I know where a nice complete A-body v8 4spd/console/d-shaft/axle is sitting locally, so that wouldnt be a problem.
Course, the keisler 5spd would be oh so much nicer on the highway!
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1229
08/12/03 11:48 PM
08/12/03 11:48 PM
I put the roller bushing right in to my crank... No problem.. 5 speed is a big + but I'd take a 3 speed over an automatic any day.
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1230
08/17/03 12:15 AM
08/17/03 12:15 AM
Crazy73 Offline OP
Crazy73  Offline OP
Thanks guys!
I printed out all the replies, it's about 40 pages
(and when did we get all these new smilies? I have been away since Wed)
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1231
09/05/03 04:04 AM
09/05/03 04:04 AM
btt
Re: 10:1 Mild Stroker 416s - output? #1232
09/05/03 05:32 AM
09/05/03 05:32 AM
808CUDA Offline
808CUDA  Offline
This is a TON of great info. from all you guy's! THANKS!
I am in beginning stages of building a 4" stroker out of my 340 for my '70 Cuda.
I just called Mancini Racing and they tell me for street duty I will NOT need H-beam rods and Forged crank.
Are they just lining me up for their overstocked I-beamed/cast crank combo's or are they true?
He asked me if I plan to do track duty, i told him an occasional blast down the quarter, say once every 2 months on street tires.
How do I drive? I get on it HARD here and there, rolling burnouts once in awhile.
So do I need the H-beam rods? Or do I need at least a forged crank?
He suggested the same as you all did about balancing, external w/ a good balancer.
How about the cam? I know the duration in teh 240 range, but solid or hydraulic?
My 'Cuda I drive daily 8 miles to work, 4 speed (soon Keisler 5 speed) and has manual brakes, no power steering.
What rocker ratio?
What carb to go with?
I want deep 11's, so what specific cam should I go with?
Many thanks from Hawaii!!!
Gil
P.S. Edelbrock heads, TTI headers, Air gap intake are on the way.
Re: 10:1 Mild Stroker 416s - output? [Re: 808CUDA] #1233
09/05/03 10:04 AM
09/05/03 10:04 AM
Crazy73 Offline OP
Crazy73  Offline OP
The H-Beam rods require less notching of the block for rod clearance. If you use the I-Beams you need to notch it more. There are sets of H-Beams on eBay for $319.99 which is VERY cheap. - So it's up to you. Personally I would get the H-Beams.
Cast crank should be fine if you are staying low RPM - i.e. not pushing 7,000 all day long.
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1234
09/07/03 06:02 AM
09/07/03 06:02 AM
808CUDA Offline
808CUDA  Offline
Thanks Crazy73!
Any other opinions?
Thanks,
Gil
Re: 10:1 Mild Stroker 416s - output? [Re: 808CUDA] #1235
09/07/03 09:21 AM
09/07/03 09:21 AM
I'm running a cast crank, my machinist says no problem, its a nice piece. I bought Scat H beams for 380 delivered. They were on the money, needing no further machine work, like Eagles usually do. I think they are the same rod (H beam), but the Scats are finished in the US. I am buying a solid roller set up (cam lifters, springs, pushrods) from Bullet Racing Cams, 800 for all, a very good price IMO. if you want to make big power, i feel a single plane is necesary, this isn't a 340 anymore, I am using a Strip Dom, the only single plane with the mounts for a/c. p/b, and plenty extra places for fittings. I'd go with a Demon carb or something like it, the driveablility is much better than stock Holleys. Other than that, go with the best parts you can afford, to avoid doing it again.
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1236
09/07/03 11:11 AM
09/07/03 11:11 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
wow...fascinating reading....
all i can/will add is this there is no substsitute for cubic inches..the more you have the less you have to spin a given motor to realize a certain power level....big motor=less rpm=less maintenance=less getting into thy wallet
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 10:1 Mild Stroker 416s - output? [Re: patrick] #1237
09/07/03 11:39 AM
09/07/03 11:39 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Hey if you build the stroker you will be able to run 12 with 3.73 or 3.55 and not much converter. When I say 4.30s are not great for 50 or any miles of highway I know Ive done the Yugo passin you becouse youre spining youre mill 35 to 3800 rpm at freeway speeds.STROKERS MAKE TORQUE torque moves that ugly "street or highway gear better".
10 to 1 is a pump gas motor easily...
Big cubes in small package is sweet.
If you have the parts you say you have a stroker does not cost as much as many would like to believe..A stroker only needs pistons rods and crank, evey thing else you would need for a non stroker aplication also.Machine work same as non stroker other than the 8 small notches that are easily done by hand at home.Strokers work the nay sayers must not have one or they want one and are scared youre going to get the last one..
Re: 10:1 Mild Stroker 416s - output? [Re: dezduster] #1238
09/07/03 07:13 PM
09/07/03 07:13 PM
808CUDA Offline
808CUDA  Offline
Thanks again for the input!
I will definitelytry to spend where it is needed. Just needed to get a vote of confidence on the cast crank.
Thanks again!
Gil
Re: 10:1 Mild Stroker 416s - output? [Re: 808CUDA] #1239
09/11/03 08:07 PM
09/11/03 08:07 PM
Crazy73 Offline OP
Crazy73  Offline OP
Wish me luck, guys!
I will start making calls tomorrow
Pete
Re: 10:1 Mild Stroker 416s - output? [Re: Crazy73] #1240
04/26/04 07:39 PM
04/26/04 07:39 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
just brining a great thread back from the dead.
Anymore thoughts or ideas ?
Re: 10:1 Mild Stroker 416s - output? [Re: AdamR] #1241
04/26/04 07:48 PM
04/26/04 07:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
from what i understand,the eagle "i beam"DOESNT require notching of the bottom of the bore,the eagle h beam DOES....
btw..if you are lookig at going low 11's...dont bother with the i beams..get the h beams...crank wise,the cast crank should be fine....but for another 500 bucks,you will never have to worry......just my opinion,but do it right the first time and you will never have to worry.........ask me how i know........
1.41 best 60 foot
6.60 at 103.90 1/8
