Help with fuel smell #1223877
04/28/12 10:45 PM
04/28/12 10:45 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I have the worst fuel smell coming from the two vents on my cell.. I have two 8 AN lines coming from the vents to a bulkhead connectors mounted on the floor of my trunk... What can I do to stop the fuel smell... it's so strong I can't park the car in the garage... Show me what you guys have done?
Re: Help with fuel smell [Re: W9 Dart] #1223878
04/29/12 12:19 AM
04/29/12 12:19 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i have the same issue, but not as bad urs. i have 1 vent on my cell. i am going to try a harley beather vent. it looks like a small k&n air filter with a hose nipple on it.
Re: Help with fuel smell [Re: W9 Dart] #1223879
04/29/12 12:40 AM
04/29/12 12:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you park in the garage you have to put a charcoal
canister on the vent.. thats the only thing that
works and allows it to still vent... and you may need
to blow the canister out once in a while if it loads
up bad
Re: Help with fuel smell [Re: MR_P_BODY] #1223880
04/29/12 09:12 AM
04/29/12 09:12 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
up bad
Anyone have a link? All the ones I've seen on google have vacuum hoses or attach to a wiring harness. Isn't it just a can with a nipple on the top and bottom and it's filled with charcoal? Or is there more to the design?
Re: Help with fuel smell [Re: W9 Dart] #1223881
04/29/12 10:06 AM
04/29/12 10:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
up bad
The ones with the vac hose purge out the gas smell
when the engine is running... if you dont want to
go that way just get a early canister (in the 70s)
but like I said you may end up purging it with air
Re: Help with fuel smell [Re: MR_P_BODY] #1223882
04/29/12 11:29 AM
04/29/12 11:29 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I wonder if I could also just use one vent verses two like Aeromotive suggested?
Re: Help with fuel smell [Re: W9 Dart] #1223883
04/29/12 11:34 AM
04/29/12 11:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most people run 1 vent... you just need enough area
in the line to do the job... if the pump is causing
a lot of turbulence in the tank then it needs a larger
area in the line
Re: Help with fuel smell [Re: MR_P_BODY] #1223884
04/29/12 12:26 PM
04/29/12 12:26 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I'm open for suggestions b/c as of now I can't park my car in the garage... smell is out of this world.
Re: Help with fuel smell [Re: W9 Dart] #1223885
04/29/12 12:43 PM
04/29/12 12:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Cap the vent line with a popppet check valve with a very light spring, so it would relieve pressure at 1-2 psi or so. That would keep your fuel fresher and away from moisture in the air when your car is parked inside.
It's the only for sure way/safe way, but you got to remember to remove it when using the car.
A poppet valve is just bypass valve used in fuel injection, small and compact.
Re: Help with fuel smell [Re: Challenger 1] #1223886
04/29/12 01:33 PM
04/29/12 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem with any check valve is when it opens
it still bleeds off the fumes into the garage... in
the emission game we went to charcoal canisters to
eliminate all of the vapors... when we do the emissions
test the car is basically in a big baggie and we cant
have more than X grams of emissions(very small amount)
from the whole car
Re: Help with fuel smell [Re: MR_P_BODY] #1223887
04/29/12 01:46 PM
04/29/12 01:46 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
Could I make a canister out of PVC? One end with a fitting to take my am vent hose, the other end has drilled holes for air to escape .... I fill the canister with a bag of charcoal?
Re: Help with fuel smell [Re: W9 Dart] #1223888
04/29/12 02:06 PM
04/29/12 02:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure you can make one... thats how we started out...
but you can buy one pretty easy and have what you want...
if you do make one get small graduals... it gives
you more surface area to pick up vapor
Re: Help with fuel smell [Re: MR_P_BODY] #1223889
04/29/12 02:13 PM
04/29/12 02:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
It would cut down the emmissions to point of being more than acceptale, it would only vent when the temps climb and only vent monentary, most times you not even notice.
Re: Help with fuel smell [Re: MR_P_BODY] #1223890
04/29/12 02:15 PM
04/29/12 02:15 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I haven't found any with only one inlet and one outlet...That's why I said make my own... I'm all about buying one though if I can..lol
