Suregrip vs. non suregrip - visual inspection
#1223781
04/28/12 08:28 PM
04/28/12 08:28 PM
Posts: 339 California
moparbroz
California
What should I be looking for to determine I am viewing a suregrip unit as opposed to a non-suregrip? I am going to look at a center chunk outside of the housing on Monday. Thanks.
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection
[Re: moparbroz]
#1223787
04/28/12 10:25 PM
04/28/12 10:25 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Unless a 489 case has had a crush sleeve eliminator installed, the yoke can't be swapped without messing up the pinion pre-load. Chances are, it will still have the crush sleeve.
A 489 case would have a come with a cone type SG if originally equipped. Sure Grips will interchange between cases though, so it is possible to rebuild with a clutch-type.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1223788
04/28/12 10:50 PM
04/28/12 10:50 PM
moparbroz
California
Thanks. I am so glad I asked. Quote:
Hebrews 11:1
[Re: moparbroz]
#1223789
04/28/12 10:53 PM
04/28/12 10:53 PM
471Magnum
Space Station #5
FYI... They do make a 7290/7260 conversion U-joint, so the small yoke isn't necessarily a show stopper.
-Jim
[Re: 471Magnum]
#1223790
04/28/12 11:48 PM
04/28/12 11:48 PM
moparbroz
California
Well...AWESOME! I really want this unit as it is close and has the 323 gearing. I am guessing Dr, Diff has the conversion kit? Quote:
Hebrews 11:1
[Re: 471Magnum]
#1223793
04/29/12 01:50 AM
04/29/12 01:50 AM
moparbroz
California
Thank you! http://www.summitracing.com/parts/MOG-347/Quote:
Dr Diff is great, but no need to go that far. Should be able to get one through any parts store. Moog/Precision 347
Hebrews 11:1
[Re: OzHemi]
#1223795
04/29/12 02:17 AM
04/29/12 02:17 AM
moparbroz
California
Yep. In Orange. Thanks! Quote:
Don't know where in CA you are, but if you are anywhere around Orange County, Powertrain Industries here in G.G. should have them on the shelf.
(I have got them there in the past)
Hebrews 11:1
