Suregrip vs. non suregrip - visual inspection #1223781
04/28/12 08:28 PM
04/28/12 08:28 PM
California
moparbroz Offline OP
California
What should I be looking for to determine I am viewing a suregrip unit as opposed to a non-suregrip? I am going to look at a center chunk outside of the housing on Monday. Thanks.
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223782
04/28/12 08:33 PM
04/28/12 08:33 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
cone type
Re: Suregrip vs. non suregrip - visual inspection [Re: jamesc] #1223783
04/28/12 08:34 PM
04/28/12 08:34 PM
jamesc Offline
jamesc  Offline
clutch type
Re: Suregrip vs. non suregrip - visual inspection [Re: jamesc] #1223784
04/28/12 08:35 PM
04/28/12 08:35 PM
jamesc Offline
jamesc  Offline
open diff
Re: Suregrip vs. non suregrip - visual inspection [Re: jamesc] #1223785
04/28/12 10:12 PM
04/28/12 10:12 PM
California
California
489 case. Would that be "cone." Thanks.
cone type
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223786
04/28/12 10:15 PM
04/28/12 10:15 PM
California
California
And I should have also mentioned that the unit I am lokking at has a small yoke attached. Easy to swap out to the large yoke?
cone type
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223787
04/28/12 10:25 PM
04/28/12 10:25 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Unless a 489 case has had a crush sleeve eliminator installed, the yoke can't be swapped without messing up the pinion pre-load. Chances are, it will still have the crush sleeve.
A 489 case would have a come with a cone type SG if originally equipped. Sure Grips will interchange between cases though, so it is possible to rebuild with a clutch-type.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Suregrip vs. non suregrip - visual inspection [Re: 471Magnum] #1223788
04/28/12 10:50 PM
04/28/12 10:50 PM
California
California
Thanks. I am so glad I asked.
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223789
04/28/12 10:53 PM
04/28/12 10:53 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
FYI... They do make a 7290/7260 conversion U-joint, so the small yoke isn't necessarily a show stopper.
-Jim
Re: Suregrip vs. non suregrip - visual inspection [Re: 471Magnum] #1223790
04/28/12 11:48 PM
04/28/12 11:48 PM
California
California
Well...AWESOME! I really want this unit as it is close and has the 323 gearing. I am guessing Dr, Diff has the conversion kit?
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223791
04/29/12 12:51 AM
04/29/12 12:51 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
cone styles has large springs inside
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223792
04/29/12 01:17 AM
04/29/12 01:17 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Dr Diff is great, but no need to go that far. Should be able to get one through any parts store. Moog/Precision 347
Re: Suregrip vs. non suregrip - visual inspection [Re: 471Magnum] #1223793
04/29/12 01:50 AM
04/29/12 01:50 AM
California
California
Thank you!
http://www.summitracing.com/parts/MOG-347/
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223794
04/29/12 01:59 AM
04/29/12 01:59 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Don't know where in CA you are, but if you are anywhere around Orange County, Powertrain Industries here in G.G. should have them on the shelf.
(I have got them there in the past)
Re: Suregrip vs. non suregrip - visual inspection [Re: OzHemi] #1223795
04/29/12 02:17 AM
04/29/12 02:17 AM
California
California
Yep. In Orange. Thanks!
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223796
04/29/12 02:38 AM
04/29/12 02:38 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Cass (DrDiff) is good people of course...but I've used these local guys to build a few driveshafts for me now, and always got real good service from them.
The driveshaft in my Torana is from them even.
Plus them being only like 10 minutes away makes it handy too.
Re: Suregrip vs. non suregrip - visual inspection [Re: OzHemi] #1223797
04/29/12 01:39 PM
04/29/12 01:39 PM
California
California
You answered my next question. "Good source for a drive shaft." I live by the 55 and 22 freeways so very close to them too. Thanks much!
Hebrews 11:1
Re: Suregrip vs. non suregrip - visual inspection [Re: moparbroz] #1223798
04/29/12 01:53 PM
04/29/12 01:53 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No problem...they are good to deal and not bad turn around times either.
And if you have never been there...they are just up the street from Hillco, big nut and bolt store. (thier prices have gone up abit from what they used to be but I guess that is happening alot of places) but handy if you are looking for things. You've got McFadden-dale to sorta over your way..but always handy to have different places to try for stuff.
(I'm just between Magnolia and Brookhurst off Lampson so real close to them for me.)
Re: Suregrip vs. non suregrip - visual inspection [Re: OzHemi] #1223799
04/29/12 03:33 PM
04/29/12 03:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
what's the going rate for a driveshaft from powertrain?
Re: Suregrip vs. non suregrip - visual inspection [Re: RobX4406] #1223800
04/29/12 05:55 PM
04/29/12 05:55 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I can't remember off hand what I paid for my last one, would have to dig out the paperwoork from it.
