basic ignition question #1223600
04/28/12 04:20 PM
04/28/12 04:20 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
In a recent mopar muscle article they said the ballast resistor isnt needed on electonic ignition and you could take it out of the picture. There are no points to burn out and the coil will handle it esecially if you get a aftermarket one. Has anyone done this? your thoughts? It would be nice not haveing to worry about the resistor. Engine would benefit from hotter spark all the time also.
Is there a good how to site on converting points over to electronic without buying the MP kit?? I already have the pieces just need to know how to wire it up.
68 fish
Re: basic ignition question [Re: RonaldV] #1223601
04/28/12 04:26 PM
04/28/12 04:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have the harness ? Also the coil is what dictates a ballast or not , GM's had a coil lead that was a resistance wire .
The wiring diagram to wire up the MP electronic is in the tech archive.
what box do you have ?
Re: basic ignition question [Re: RonaldV] #1223602
04/28/12 04:33 PM
04/28/12 04:33 PM
CHRGR69 Offline
CHRGR69  Offline
68 fish
Check out my post https://board.moparts.org/ubbthreads/show...e=0#Post7182484
Seems like we are looking for the same thing...no ballast!
Grandma always said I had "hands of gold"!
Re: basic ignition question [Re: RonaldV] #1223603
04/28/12 06:20 PM
04/28/12 06:20 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I've used the mopar electronic ignitions for over 20 years. I usually use stock coils. I've allways used a jumper wire to eliminate the ballast. I've never had a problem. My local speed shop has been setting up mopar ignitions since they came out this way. I prefer the chrome box and blue constant output regulator.
Re: basic ignition question [Re: JohnRR] #1223604
05/25/12 07:13 PM
05/25/12 07:13 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
ive got a orange ECU new that I would use. I would be using pieces from an old salvaged wire harness. I read a mopar muscle mag. article that said you could take out the resistor on electronic ignition without any problems. Seems like the thing to do if its not needed. But, if so why did the factory keep the resistor in the system when they went to electronic ignition??
Fish
Re: basic ignition question [Re: RonaldV] #1223605
05/28/12 01:45 AM
05/28/12 01:45 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
so the coil doesnt burn up
Re: basic ignition question [Re: 05dakota] #1223606
05/28/12 04:51 AM
05/28/12 04:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've burnt up a coil by bypassing the ballast. The ballast resistor is there to limit current flow through the coil. Different coils will require a differently rated ballast resistor, with some not requiring one at all. The aftermarket spark boxes like msd and similar all have current limiting circuits in them so you don't run a ballast with those.
Re: basic ignition question [Re: DaytonaTurbo] #1223607
05/28/12 09:21 AM
05/28/12 09:21 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
with an orange box ECU you should still use a ballast. with an over-the-counter autozone coil you should also still use a ballast.
Re: basic ignition question [Re: mikemee1331] #1223608
05/28/12 09:43 AM
05/28/12 09:43 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..well you can run without an oil filter and air cleaner too, but you wouldn't.
i found a spark plug wire pulled off (the boot was still on)
and the engine still ran fine.
you have plenty with 9v at the coil.
the more things you run maxed out the more problems you will have.
