Sway bar problem, with pics #122357
09/17/08 09:25 PM
09/17/08 09:25 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
I was under the front of my 70 Superbee tonight doing a little work and noticed that the passenger side sway bar washer was rubbing on the control arm. Upon further inspection I noticed that the front sway bar brackets were angled different. The drivers side was angled forward where the passenger side was angled back. It appears that by it being angled back it is pushing the bars attachment bolt back to far which is making it hit the control arm. Can someone with a 70 B-body look at the direction that their front brackets angle to confirm this?
Re: Sway bar problem, with pics [Re: BADBEE] #122358
09/17/08 09:32 PM
09/17/08 09:32 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Looks like someone put the pass side bracket on backwards.
Re: Sway bar problem, with pics [Re: Skeptic] #122359
09/17/08 09:36 PM
09/17/08 09:36 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Or it took a hit.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Sway bar problem, with pics [Re: BADBEE] #122360
09/17/08 09:58 PM
09/17/08 09:58 PM
70340 Offline
70340  Offline
the sway bar bolts to the link (long bolt) then the link bolts to the lower control arm with the long spacer between. You have the sway bar bolted directly to the control arm with no space between. This has also bent the frame bushing brackets.
Re: Sway bar problem, with pics [Re: 70340] #122361
09/17/08 10:08 PM
09/17/08 10:08 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Well its been that way for a long time, I bought the car in 1979 and I have never had it off. Do you have a pic or a manual pic of how it should be assembled?
Re: Sway bar problem, with pics [Re: BADBEE] #122362
09/17/08 10:12 PM
09/17/08 10:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Those U clamps are bent. They should not "lean" forward or back I believe
Re: Sway bar problem, with pics [Re: buildanother] #122363
09/17/08 10:17 PM
09/17/08 10:17 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Those brackets are bent backward try to fix em or replace and get new links and bushings. Check for other damage too.
Re: Sway bar problem, with pics [Re: BADBEE] #122364
09/17/08 10:25 PM
09/17/08 10:25 PM
70340 Offline
70340  Offline
cuda challenger.com has a suspension section that can get you a similar assembly. Basically the link separates the bar from the control arm.
Re: Sway bar problem, with pics [Re: Y3 70 BEE] #122365
09/17/08 10:26 PM
09/17/08 10:26 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Well thats what is weird, one side angles forward and the other back. Looks to me like the passenger side should be switched around to lean forward and that would move it away from interfering as it is now. Can someone check theirs on their car to verify if they should be angled or not?
Re: Sway bar problem, with pics [Re: 70340] #122366
09/17/08 10:29 PM
09/17/08 10:29 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
70340, I think you are interpreting the pics wrong, here are some pics that I think show that they are hooked up correctly,
Re: Sway bar problem, with pics [Re: BADBEE] #122367
09/17/08 10:31 PM
09/17/08 10:31 PM
very simple there bent
Re: Sway bar problem, with pics [Re: buildanother] #122368
09/17/08 10:33 PM
09/17/08 10:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They both look damaged to me.
Re: Sway bar problem, with pics #122369
09/17/08 10:38 PM
09/17/08 10:38 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
OK. I'll buy that. Probably took a hit on the passenger side at some point and bent them in opposite directions. I was going to rebuild the front end this winter any way so I will get some new loops when I redo the front end.
Thanks guys.
Re: Sway bar problem, with pics [Re: BADBEE] #122370
09/17/08 10:43 PM
09/17/08 10:43 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Hey Jeff.
Looks to me like the sway bar is bent on the pass side also.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Sway bar problem, with pics [Re: moparmarks] #122371
09/17/08 10:58 PM
09/17/08 10:58 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Thanks Mark, I'll check it out once its off. Are you going to Monster Mopar this weekend? If so maybe I will see you there.
Re: Sway bar problem, with pics [Re: BADBEE] #122372
09/18/08 12:16 AM
09/18/08 12:16 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The brackets on the LCA's look like they are home made.
Re: Sway bar problem, with pics [Re: Snoopy] #122373
09/18/08 12:49 AM
09/18/08 12:49 AM
Snoopy Offline
Snoopy  Offline
Re: Sway bar problem, with pics [Re: Snoopy] #122374
09/18/08 01:10 AM
09/18/08 01:10 AM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
I dont think so,
they look just like what you have pictured when
you view them under the car.
My pics make it a little hard to see their shape, but they are definatly factory pieces.
Re: Sway bar problem, with pics [Re: BADBEE] #122375
09/18/08 01:20 AM
09/18/08 01:20 AM
moparmarks Offline
moparmarks  Offline
Nope not going to make it this year, just too much to do here.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Sway bar problem, with pics [Re: moparmarks] #122376
09/18/08 08:51 AM
09/18/08 08:51 AM
California
70SportSatellite Offline
super street
super street
California
the brackets holding the sway bar to the "K" frame are bent. Also, the sway bar appears to be installed upside down. IIRC the ends should be "frowning" when viewed from the side.
