Brake question on 69 Charger..... #1223106
04/27/12 03:11 PM
04/27/12 03:11 PM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
Last night I bench bled and installed a reman master cylinder on my RT (discs & drums). The pedal "dangles" (swings freely) and activates the rear brake light switch...so, I unplugged it. I haven't started the car yet and am curious if this will cure the pedal pressure I am lacking? Then I will bleed all the brakes. Am I on the right path? Suggestions? Thanks. TC
Re: Brake question on 69 Charger..... [Re: tcs69rt] #1223107
04/27/12 03:25 PM
04/27/12 03:25 PM
Andrewh Offline
Andrewh  Offline
I am guessing it is power based on your question about starting the car?
would have thought manual since it is an RT.
but regardless, you probably pulled the pedal back and moved the switch, or you need a spring to pull the pedal all the way back to engage the switch.
a power car will not pump up the pedal when you start the car.
Re: Brake question on 69 Charger..... [Re: Andrewh] #1223108
04/27/12 06:12 PM
04/27/12 06:12 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
If you bench bled it then it dangling sounds like a problem...Are you sure when you put the master back in that the pushrod was in the booster and it was making contact with the hydraulic piston in the master? You should encounter some resistance. Not to be smart or anything...but after you hooked it up to the booster...you didnt pump the brakes did you? You would have spit out fluid and sucked in air if the lines weren't installed.
AFAIK, there is a spring pulling the brake pedal back in to the raised position.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Brake question on 69 Charger..... [Re: Pyper70] #1223109
04/28/12 02:54 AM
04/28/12 02:54 AM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
I hooked the lines up to avoid a mess and did have some resistance while bolting it on with the piston end properly in the back of the mc. I am curious about that spring now as I did shine a light up there and was wondering if I had to re-adjust anything? Will inspect the spring in the morning, Thanks all! TC
Re: Brake question on 69 Charger..... [Re: tcs69rt] #1223110
04/28/12 03:14 AM
04/28/12 03:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The spring is in the master cyl and you won't see it, but it should return the pedal whether power brakes or not.
Re: Brake question on 69 Charger..... [Re: buildanother] #1223111
04/28/12 07:15 AM
04/28/12 07:15 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Did you change the push rod length? Provided the master is returning properly, it sounds like the push rod is too short.
Re: Brake question on 69 Charger..... [Re: bobs66440] #1223112
04/30/12 11:56 AM
04/30/12 11:56 AM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
I did not change the pushrod. I noticed the acorn nut looking tip. Should I extend it if possible? Thanks. TC
Re: Brake question on 69 Charger..... [Re: tcs69rt] #1223113
04/30/12 12:00 PM
04/30/12 12:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you still have to bleed the system reguardless...
Coming soon!!!!
Re: Brake question on 69 Charger..... [Re: Mr.Yuck] #1223114
04/30/12 03:57 PM
04/30/12 03:57 PM
yes you want to extend the acorn nut so the nub is just shy of contacting the bottom of the M/C piston recess. Your new M/C may very well have a deeper recess than the one it replaced
Re: Brake question on 69 Charger..... [Re: Mr.Yuck] #1223115
05/01/12 11:18 AM
05/01/12 11:18 AM
Colorado
tcs69rt Offline OP
tcs69rt  Offline OP
Colorado
I won't drive it without bleeding the system. Thanks. TC
