Re: Brake question on 69 Charger.....
[Re: Andrewh]
#1223108
04/27/12 06:12 PM
04/27/12 06:12 PM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
If you bench bled it then it dangling sounds like a problem...Are you sure when you put the master back in that the pushrod was in the booster and it was making contact with the hydraulic piston in the master? You should encounter some resistance. Not to be smart or anything...but after you hooked it up to the booster...you didnt pump the brakes did you? You would have spit out fluid and sucked in air if the lines weren't installed.
AFAIK, there is a spring pulling the brake pedal back in to the raised position.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Mr.Yuck]
#1223114
04/30/12 03:57 PM
04/30/12 03:57 PM
RapidRobert
yes you want to extend the acorn nut so the nub is just shy of contacting the bottom of the M/C piston recess. Your new M/C may very well have a deeper recess than the one it replaced
