ShoGun water pump system users? !!! UPDATE!!
#1222506
04/26/12 09:05 AM
04/26/12 09:05 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Anyone here use these... The lines sure are small, but this setup is defintaly light weight. If I was running alky with this car, no question it would work.. But will it keep my race car cool between rounds, in the Kentucky heat & Humidity?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: ShoGun water pump system users?
[Re: StripeHOG]
#1222512
04/26/12 02:21 PM
04/26/12 02:21 PM
you can get a spare pump here... make sure to keep a couple spare impellers on hand and use some kind of cooling system lubricant...
http://www.starwatersystems.com/ProductBenefit.aspx?ProductID=199
That looks like the pump that I got at Harbor Freight to replace my leaking Borba pump on a Saturday morning. It is a little noisey but I haven't had an overheating problem yet.
[Re: ]
#1222513
04/26/12 02:35 PM
04/26/12 02:35 PM
Here are some pctures of my Shogun pump and why I wasn't impressed with it. I don't understand why the holes are so small for the imput and output, when compared to the 3/8 line size going to it. Then on to a split manifold after that(more volume). T
[Re: ]
#1222514
04/26/12 02:59 PM
04/26/12 02:59 PM
The reason I didn't like the pump and didn't use it was because the lines were a pain to install. You can see the holes for the lines were drilled verticle to the two button head screws on the top and bottom of the pump. I guess the reason being, you could then drill both verticle holes without moving the drill head. If the holes were drilled at a few degrees the lines would be easier to install. I think they should be drilled perpendicular to the pump head. This is the problem it causes when your intalling the lines. Maybe someone out there can explain why you would design a race part like this.
[Re: J_BODY]
#1222518
04/27/12 12:38 AM
04/27/12 12:38 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
the shogun pump blows. I use a booster pumpoff a school bus. Part# CP-20-BBWA
Joe
Without Data, you’re just another guy with an opinion.
[Re: J_BODY]
#1222521
04/28/12 11:33 AM
04/28/12 11:33 AM
You can't tell the centerline from a picture I lifted from the Shogun site. I still don't understand why they don't just drill a few degrees off center so they will clear. The added clearence would make it easier to work on when your hanging over a fender. I guess having made my own cooling system and worried about things like clearences When you maufature a product I think you would make it as adaptable as possible.
[Re: ]
#1222522
04/28/12 01:11 PM
04/28/12 01:11 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Anyone, besides Bob (eh100), made their own manifolds? If so, do you have any pictures?
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR]
#1222523
04/28/12 01:47 PM
04/28/12 01:47 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
AndyF i believe makes some.
[Re: MRMOPAR]
#1222524
04/28/12 02:18 PM
04/28/12 02:18 PM
Posts: 31,016 Oregon
AndyF
