Narrow down a pair of wheels. #1221924
04/24/12 10:15 PM
04/24/12 10:15 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
I have a pair of CCW Classics that I want to narrow down.
Normally, this is as easy as calling up CCW and ordering a new inner barrel. however, the set of wheels I have were made before 1997, because they changed the design some in 1997 and their new parts won't work. so, my options are to A) order up a whole new set of rims of the new design at $2600, or cut down my fronts.
I know of Weldcraft up in Michigan, they have good reviews across the automotive forum world. but I want to shop around anyway. maybe find a local business I can support without having to pay 2-way shipping.
Who do you guys trust to cut a wheel in half, then weld it back together?
**Photobucket sucks**
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221925
04/24/12 10:27 PM
04/24/12 10:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
All you need is a shop with a lathe big enough to chuck in the rim or the rim on a axle, and a welder. Two cuts per rim , just have to make sure the two pieces mate up after the cut. I've made rims wider but never narrower , same process.
Re: Narrow down a pair of wheels. [Re: rowin4] #1221926
04/25/12 09:55 AM
04/25/12 09:55 AM
Central NC
gch Offline
gch  Offline
Central NC
Weldcraft did a local guys front saleen wheels and they did an excellent job.
Re: Narrow down a pair of wheels. [Re: gch] #1221927
04/25/12 05:46 PM
04/25/12 05:46 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I built a jig awhile back to do this, when I get home I will post some pics. It is essentially a table with 4 guides that center the wheel and a cross bar that is tightened down onto the top wheel half. You level the bottom table and the rest centers and levels off of that. I have only used it on one rim but the runout was better than a production aluminum wheel I compared it to and it balanced out with minimal weight
Re: Narrow down a pair of wheels. [Re: SLOW67] #1221928
04/25/12 05:57 PM
04/25/12 05:57 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
sounds promising/easier than I initially thought. However, this will NOT be a job I do myself. First off, I only have a wire feed mig set up for mild steel, and these wheels are aluminum.
Second, I don't have a lathe or anything to squarely cut the wheel with.
Third...I'd rather let someone who's done this before do it!
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221929
04/25/12 08:45 PM
04/25/12 08:45 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I just had some 20" outers narrowed down to 6" wide and had some 18" outers made into 5" wide at a local shop. Price was $175 per outer including polishing.
Just as an example for you....thier work was top notch as well.
Depending on the bolt pattern, you can also get 1 piece outers that use a bolt in center you know as well.. (so it makes a 2 piece wheel with a 3 piece center basically) You might find one of those that is the right back spacing and width for you perhaps ?
I know another place who just started doing 2 piece outers and the 1 piece outer for 3 piece centers, but not sure what bolt pattern they are..
Come to think of it, the guy I use to CNC cut centers for me had some odd ball bolt pattern 1 piece outers for the 3 piece center laying around too.
Re: Narrow down a pair of wheels. [Re: OzHemi] #1221930
04/26/12 11:02 AM
04/26/12 11:02 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
Interesting. I wonder what his cost is. my target is $200 a wheel to get what I want.
CCW is not willing to help out at all, they want big money to "custom make 2 pieces" I found a guy on a VW forum who builds/repairs name brand wheels, he said his supplier is the same as CCWs. They would make the older style rim shells with the 20-bolt pattern, but they need a minimum order of 30 pieces.
and since CCW isn't interested in ordering/stocking parts for their older wheels, I'm SOL on that route.
I hate the idea of cutting these wheels to get them narrower, but it is appearing to be my only option, short of selling them off and starting over. I'd be looking at $2600 to order new rims, then probably another grand for tires. Or, wait forever for another set to come up on a forum somewhere that works for me.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221931
04/26/12 11:43 AM
04/26/12 11:43 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
What size inners are you looking for...I can check around a few of the people I deal with and see if there are any laying around.
(Just thought of another company I bought outers from that do 3 piece as well, but thier's would be the newer stuff)
I buy alot of outers, but just 2 piece wheel sort of stuff so never really paid much attention to the 3 piece wheel components the same companies had around much.
Re: Narrow down a pair of wheels. [Re: OzHemi] #1221932
04/26/12 04:02 PM
04/26/12 04:02 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
depending on how they are measured (to the tire bead, or to the rim's lip) these are between 9.5 and 10" wide on the inners, 11.5 overall from bead to bead or 12.5 from lip to lip. looking to knock that down by 2" all on the inner side.
the center sections I have use a 20-bolt pattern, I believe the same size as the 16s that CCW still makes, they just don't offer the 17" shells that fit these center pieces.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221933
04/26/12 08:46 PM
04/26/12 08:46 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
So you're looking for an 8" wide inner half for a 17" ? (20 bolt as you said of course too)
I'll ask around and see if I can come up with anything..have a picture of the wheel as well out of curiosity ?
Re: Narrow down a pair of wheels. [Re: OzHemi] #1221934
04/26/12 09:22 PM
04/26/12 09:22 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
mine is the 20 bolt (duh!) but these are both CCW Classics, 17" diameter rim. the smaller tire is a 315/35/17, my buddies is a 345/?/17 drag radial.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221935
04/26/12 09:25 PM
04/26/12 09:25 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I meant to post this picture earlier...here's the inner...
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221936
04/26/12 09:39 PM
04/26/12 09:39 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Okey dokey....like I said, I don't do a ton of 3 piece stuff but I'll put the feelers out with all the different wheel component companies I deal with and see if anything can be found.
Re: Narrow down a pair of wheels. [Re: OzHemi] #1221937
04/26/12 09:42 PM
04/26/12 09:42 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Much obliged! the cheaper the better! like I said, not looking to spend a mint on custom one off parts. Weldcraft already quoted me $200 ea to cut them down and weld them back together. so that's pretty much my bottom line
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221938
04/26/12 09:45 PM
04/26/12 09:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Well...it's $175 here to narrow and repolish them, so that is a little cheaper...of course you'd have to get them here and back.
Re: Narrow down a pair of wheels. [Re: OzHemi] #1221939
04/26/12 11:58 PM
04/26/12 11:58 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
What about just narrow them? I only want the rear half narrowed, and the face I plan to paint anyway.
I don't know that I'd save anything after shipping though.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221940
04/27/12 01:12 AM
04/27/12 01:12 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Probably only about 10 bucks difference I'd guess?
Shipping would eat up the difference anyways I suppose.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221941
04/27/12 05:02 AM
04/27/12 05:02 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
How much do you want them narrowed? around 2 inches?
I would personally go the weldcraft route. Lots of happy campers.
But have you called around to any fabrication shops in sspecific?
I have a lot around here and a place like that is likely going to have the equipment to easily handle a section and reweld.
Re: Narrow down a pair of wheels. [Re: 70Cuda383] #1221942
04/28/12 07:00 PM
04/28/12 07:00 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Well no luck so far my end sourcing a new (or used) pair of them.
Here is what one of my suppliers said about them.
Jeff, as far as I know none of the aftermarket rim half makers do that tall drop from the center to the rim. I believe it's unique to CCW and or BBS. Back in the day when 17s first came out in the mid 80s is when that started. I've had guys come to us wanting us to spin the halves, no one wanted to pony up for the tooling..
His company spins new outers actually, and builds complete wheels as well (drag race stuff, along with a limited run of road racing wheels which is what I run on the Torana)
Will holler if the other couple of places I've got feelers out at come up with anything as well...
