8-3/4" to Dana60 driveshaft length change? #1221442
04/24/12 03:26 AM
04/24/12 03:26 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I finally ordered up a Strange S60 (PRSL10)diff to replace my stock 8-3/4" diff. I would like to replace the stock driveshaft at the same time with one with the 1350 U-joints and new trans slip yoke.
Anyone know the difference in driveshaft length between the 8-3/4" and Dana60? or the actual driveshaft length for a '71 B-body Charger with a Dana60 and 727 transmission?
Re: 8-3/4" to Dana60 driveshaft length change? [Re: 451Mopar] #1221443
04/24/12 07:39 AM
04/24/12 07:39 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
I did the same swap last year. Seems to be a trend of just measure it when you get it in. Many told me to shorten it by as little as 1" some were clear up to 1 1/2". Well my car is a back half car w/ladder bar rear. I had to make no changes. I wished I hadn't made so many changes when I added the Dana years ago to my other Duster. Started from scratch there. Just measure & make sure it's right. Sorry thats the best info I can give you. Thanks, Ken
Re: 8-3/4" to Dana60 driveshaft length change? [Re: 1974 474 Duster] #1221444
04/24/12 08:09 AM
04/24/12 08:09 AM
gregsdart Offline
gregsdart  Offline
I made the switch once without shortening the drive shaft. If you have leaf springs, put the car on jack stands and let the springs and rear hang loose. If you can get the drive shaft in with a little room to spare, you should be good to go. If you come up with not enough room, you can probably find a way to move the rear axle back a touch with a spacer between the body and front spring hangers, or on a ladder/fourlink just screw out the rod ends IF you have plenty of engagement left.
Be sure your motor tranny combo can't move rearward under load if you are going to cut it close.
Re: 8-3/4" to Dana60 driveshaft length change? [Re: 451Mopar] #1221445
04/24/12 08:52 AM
04/24/12 08:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would measure my own set up... too many things can
change your reading.... according to the trans book
I use(Munroe is the author) he says 3/4" from the yoke
being bottomed out in the trail shaft(bottom it then
pull it out 3/4") and that should be the measurement
(at curb height)... that should be enough to get
it out and not bottom out
Re: 8-3/4" to Dana60 driveshaft length change? [Re: 451Mopar] #1221446
04/24/12 11:41 AM
04/24/12 11:41 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I am in the middle of doing the exact same thing. It looks like I will have to shorten my driveshaft about an inch. I would say my driveshaft was on the short side with the 8-3/4 in the car though.
-Kenny
Strange S60 update [Re: 451Mopar] #1221447
11/04/12 03:55 AM
11/04/12 03:55 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Installing the axle was pretty easy except for stripping the axle retainer nuts? The Strange S60 axle came with really small 7/16" head nuts for the 3/8" studs, and I used the factory torque spec of 30 ft/lbs and stripped a nut/stud. I'm not sure if those nuts that came with the axle were supposed to be used, or if they were just for shipping? The instructions that came with the axle did not mention anything about them or a torque spec. Antone run into this problem?
I ended up just buying a complete replacement set of studs and nuts from Mancinni. Installed them, torqued to 30 ft/lbs and no problem.
I made a quick driveshaft measurement and it looks like the driveshaft needs to be about 1-1/2" shorter, but it was getting dark so I will re-measure with better accuracy in the morning.
Re: 8-3/4" to Dana60 driveshaft length change? [Re: StrokerAspen] #1221448
11/04/12 10:04 AM
11/04/12 10:04 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
On my 68` B-body it was exactly 1-in difference
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 8-3/4" to Dana60 driveshaft length change? [Re: 6bblFLASH] #1221449
11/04/12 10:06 AM
11/04/12 10:06 AM
tboomer Offline
tboomer  Offline
Same on my 64..
Re: 8-3/4" to Dana60 driveshaft length change? [Re: tboomer] #1221450
11/04/12 11:13 AM
11/04/12 11:13 AM
Toronto
mshred Offline
mshred  Offline
Toronto
My driveshaft didn't need any changes going from the 8-3/4 to the Dana...In fact, it actually fit a little better with the Dana (I think it was too long in the 8-3/4)
Re: 8-3/4" to Dana60 driveshaft length change? [Re: tboomer] #1221451
11/04/12 12:14 PM
11/04/12 12:14 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Same on my 64..
Hmmmm and this may be a good reason to get your own measurements and then order. on my 64 it was 1.25" now that may not seem like much of a difference but could be
Russ
Re: 8-3/4" to Dana60 driveshaft length change? [Re: max_maniac] #1221452
11/04/12 12:24 PM
11/04/12 12:24 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Best advice is to measure it. You just spent a lot of money on the rearend, might as well put a decent driveshaft at the exact correct length in it too. When I put a Dana 60 in my Charger I had Dynotech build a driveshaft for mine. They have instructions on how to measure on their order form if I remember correctly.
Re: 8-3/4" to Dana60 driveshaft length change? [Re: Blusmbl] #1221453
11/04/12 05:25 PM
11/04/12 05:25 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I did the same change on a 69 Road Runner and on a 70 Challenger. Did not have to change driveshafts on either swap. But, as said, no 2 are the same, you better measure. Don't just take advise, check for yourself! Jeff
