Gen 3 Core engines #1220999
04/23/12 10:05 AM
04/23/12 10:05 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I was hoping to get a database of sorts started on Gen 3 engines.
I wanted it to include what core engines are available and they're basic specs (Bore size, deck height, Crank stroke, rod length etc).
There has been a lot of talk and interest about these engines lately for a Drag Application and thought it might be nice to have the information there and easily accessible.
Would someone like to get the ball rolling? I can edit my original post and add information as we move along.
5.7L HEMI (345 cu in)
Vehicle/s:
Year/s:
Bore: 3.917" (99.5mm)
Stroke: 3.579" (90.9mm)
Valve System pushrod, 16-valve, hydraulic roller lifters
Block Construction cast iron, deep skirt, cross-bolted main caps
Centerline of crank to head deck face 9.3 inches
Centerline of crank to centerline of cam 7.4 inches
Centerline of crank to oil pan rail 2.6 inches
Overall block maximum deck width at deck face 18.3 inches
Overall block height from
oil pan rail to top of water outlet 15.4 inches
Overall engine length 21.1 inches
Compression Ratio 9.6:1
Combustion chamber volume 84.9cc
Intake valve angle 18 degrees
Intake valve head diameter 50.8mm, 2.00 inches
Exhaust valve angle 16y.5 degrees
Exhaust valve head diameter 39.4mm, 1.55 inches
Oil Capacity 7 qt., 6.6L
Weight (includes induction, wiring harness,
auto-trans flexplate and exhaust manifolds,
but not accessories) 485 lbs
Ignition Two spark plugs per cylinder
6.1L SRT-8 HEMI (369.7 cu in)
Vehicle/s:
Year/s:
Bore: 4.055" (103.00mm)
Rod Length:
Deck Height:
Camshaft:
Intake Valve:
Exhaust Valve:
6.4L "392" HEMI (391.2 cu in)
Vehicle/s:
Year/s:
Bore: 4.091" (103.90mm)
Stroke: 3.721" (94.5mm)
Rod Length:
Deck Height:
Camshaft:
Intake Valve:
Exhaust Valve:
Crate 392 (391.2 cu in)
Vehicle/s: N/A
Year/s:
Bore: 4.055"
Stroke: 3.795"
Rod Length:
Deck Height:
Camshaft:
Intake Valve:
Exhaust Valve:
7.0L "426" HEMI (426 cu in )
Vehicle/s:
Year/s:
Bore: 4.125"
Stroke: 3.980"
Rod Length:
Deck Height:
Camshaft:
Intake Valve:
Exhaust Valve:
7.2L "440" HEMI
Vehicle/s:
Year/s:
Bore: ?
Stroke:?
Rod Length:
Deck Height:
Camshaft:
Intake Valve:
Exhaust Valve:
6.9 (421 cu in ) = 4.065 bore x 4.050 stroke
6.27 (382.64 cu in) = 4.125 bore x 3.579 stroke
6.65 (405.73 cu in) = 4.125 bore x 3.795 stroke
***Notes***
• Core engines that do not have VCT/VVT (2003-2008)
• The tone ring changed in 2009 also
• The tone rings are interchangeable, make sure you change your crank sensor too if you do that.
• I believe some engines had an english thread for the oil filter?
• The newer ones (2008?) are 22mm x 1.5
• Toner finger is interchangeable except 03-08 5.7 HEMI (3 Bolt, standard is 4 bolt)
• The good news is that if you have a 6.1 or 6.4 crankshaft and want it in a 5.7 block you can purchase the proper ring from Wiseco part # TR- 32. You only need this if you r using fuel injection and production ECM.
Let me know if there are any errors as I update the information
Alan Jones
Re: Gen 3 Core engines [Re: LA360] #1221000
04/23/12 10:19 AM
04/23/12 10:19 AM
NC
440Jim Offline
440Jim  Offline
NC
This is info I have gathered from other people's posts.
I haven't verified any.
Basics:
7.2L "440" HEMI
7.0L "426" HEMI
6.4L "392" HEMI
6.1L SRT-8 HEMI
5.7L HEMI
5.7 (345.0 cu in) = 3.917 bore x 3.579 stroke
6.1 (369.7 cu in) = 4.055 bore x 3.579 stroke (6.059 L = 103.0mm x 90.9mm)
6.4 (391.2 cu in) = 4.091 bore x 3.721 stroke (6.424 L = 103.9mm x 94.5mm)
Crate 392.1 cu in = 4.055 bore x 3.795 stroke
7.0 (426 cu in ) = 4.125 bore x 3.980 stroke
core engines that do not have VCT/VVT (2003-2008)
I believe some engines had an english thread for the oil filter? The newer ones (2008?) are 22mm x 1.5
Re: Gen 3 Core engines [Re: 440Jim] #1221001
04/23/12 11:55 AM
04/23/12 11:55 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My the toner finger are interchangeable except.the 2003 to 08 5.7. They have a three BOLT where the rest have 4 bolt. I do not know about the 09 and up 5.7.
We need a sticky for the G3.
Re: Gen 3 Core engines [Re: MattW] #1221002
04/23/12 07:00 PM
04/23/12 07:00 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
I think this thread is a great idea! I'm interested now in swapping a gen 3 Hemi into my Duster but am unsure what to look for in a donor engine or if I should even bother finding a core since I intend to build a stroker.
Re: Gen 3 Core engines [Re: Pat7272] #1221003
04/23/12 07:24 PM
04/23/12 07:24 PM
LA360 Offline OP
LA360  Offline OP
What does the VCT/VVT sensor look like? For guys running a carb, can a spacer or something be made to replace it?
Alan Jones
Re: Gen 3 Core engines [Re: Pat7272] #1221004
04/23/12 08:35 PM
04/23/12 08:35 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Any 5.7 will do. If your going stroker just need a good block.
Two different front covers car and truck. Both interchange but put the alternator in a different place.
Then you have the heads and intakes. All interchange but the early version 03-08 have smaller port intake and exhaust.
Then the 09 and up 5.7, all 6.1 and 6.4 share the same intake and exhaust openings.
Factory torque to yeild bolts are cheap along with the cylinder head gaskets.
I THINK the rule is to use the gasket for the block you are using.
If your using the EFI the cheapest way is to convert it to the GM LS ECU and program that. I am looking into this.
Re: Gen 3 Core engines [Re: LA360] #1221005
04/23/12 08:40 PM
04/23/12 08:40 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
If running a carb use the comp cam locking kit. Don't know the name but it basically locks the VVT. If you are using this with the locking kit you MAY have to change the Toner ring to early version. Don't know if the stand along ignition system will function with the Later toner ring.
Re: Gen 3 Core engines [Re: MattW] #1221006
04/24/12 03:21 PM
04/24/12 03:21 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Will you tell us a little more about this?
Re: Gen 3 Core engines [Re: Pat7272] #1221007
04/24/12 06:28 PM
04/24/12 06:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Little info I found out is that the total package is 2500.00.
Google Nutter Racing.
I want to try to make my own toner ring and camshaft ring .
Get the.computer and build my own harness.
May just buy the whole kit.
Re: Gen 3 Core engines [Re: MattW] #1221008
04/25/12 08:16 AM
04/25/12 08:16 AM
NY usa
540challenger Offline
NY usa
When i was getting a quote from arrlington for his oem computer, harness and pedal to keep the drive by-wire sete up it was around the 2500 price. So given the mopar stuff is the same cost as the chevy i think i will stick to a mopar set-up.
Re: Gen 3 Core engines [Re: 540challenger] #1221009
04/25/12 01:02 PM
04/25/12 01:02 PM
dogdays Offline
dogdays  Offline
It's a TONE RING.
Toner is used in copy machines or on skin for that smooth appearance.
R.
PS: I would sure like to see a G3 Hemi between the framerails of my '64Dog!
Re: Gen 3 Core engines [Re: 540challenger] #1221010
04/25/12 01:08 PM
04/25/12 01:08 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nothing wrong with the mopar ecu.
The LS is cheaper more plentiful and fully programmable.
Re: Gen 3 Core engines [Re: MattW] #1221011
04/25/12 08:30 PM
04/25/12 08:30 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
They seem to be saying on Nutter Racing's website that the advantage of the LS Delphi computer over an aftermarket engine controller is the diagnostic aspect. I dont need my car to throw codes at me so I think I'll stick with an aftermarket ECU.
Its a cool idea though!
Re: Gen 3 Core engines [Re: Pat7272] #1221012
04/26/12 02:44 PM
04/26/12 02:44 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'm not going all out with the engine just like the fact that I can tune it cheaply with the LS.
I don't even know if it works or not. Just because it is in print doesn't mean much.
I do like the fact that you can purchase an ECU for the LS on Rockauto where tha Mopar ECU is give them yours to rebuild.
For all out racing the stand along system is probably your best bet.
Im just trying to do it the cheapest I can.
Re: Gen 3 Core engines [Re: dogdays] #1221013
04/26/12 02:51 PM
04/26/12 02:51 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
It's a TONE RING.
R.
Actually it is called a RELUCTOR ring.
Re: Gen 3 Core engines [Re: LA360] #2359004
08/24/17 09:09 AM
08/24/17 09:09 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Bump anyone want to add some info?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Gen 3 Core engines [Re: LA360] #2359161
08/24/17 03:02 PM
08/24/17 03:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You don't need a kit to lock out the VCT, the kit is an expensive gimmick, just open the cover and slide a nut in or something to prevent any movement of the mechanisim and bolt the cover back on.
