Holley Power Valve #1220189
04/21/12 11:05 PM
04/21/12 11:05 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
Would a 2.5 PV cause a rich mixture at idle or light cruise when a 5.0 PV (vacuum 10.5) is what should be used?
Re: Holley Power Valve [Re: donsdart] #1220190
04/21/12 11:48 PM
04/21/12 11:48 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
nope. unless the diaphram is ruptured.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Holley Power Valve [Re: donsdart] #1220191
04/22/12 01:51 AM
04/22/12 01:51 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the 2.5 mean it wont open until the vacuum drops below 2.5 inches....
Tony
70 AARCuda Vitamin C
Re: Holley Power Valve [Re: DARTH V8Я] #1220192
04/22/12 08:48 AM
04/22/12 08:48 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Is there an easy way to check if it is ruptured or is a fixture needed?
Re: Holley Power Valve [Re: rbstroker] #1220193
04/22/12 10:59 AM
04/22/12 10:59 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
If you have a mighty-vac hand vacuum pump there is an adapter that will fit the power valve. Make sure it seals to the PV. If not,pucker up. You can suck on it but it's NOT tasty. There is a fixture available but it's not cheap.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Holley Power Valve [Re: runinonmt] #1220194
04/22/12 02:50 PM
04/22/12 02:50 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
I have a mighty vac and will pull the old PV out and test. I remember the old gas taste NOT GOOD! Thanks for your input.
Don
Re: Holley Power Valve [Re: donsdart] #1220195
04/22/12 04:22 PM
04/22/12 04:22 PM
turn the idle mixtrue screws in to lightly seated & if it still idles that would point to a ruptured PV
