fuel cell vent? #1219821
04/21/12 03:22 PM
04/21/12 03:22 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
was under my car today. semll gas by vent. has anyone tried a pcv valve on the hose?? i figure any pressure in the cell would open to releive any pressure. don't know if the spring would prevent that from happening. i found a stink bug in the cell, must have crawled up the vent anyone have any input. thanks for ur time.
Re: fuel cell vent? [Re: rickraw] #1219822
04/21/12 03:27 PM
04/21/12 03:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I put a rollover valve on my fuel cell in the duster last year. I've heard of guys putting a fuel filter at the end of the vent line to prevent dirt from entering the cell.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: fuel cell vent? [Re: pittsburghracer] #1219823
04/21/12 04:04 PM
04/21/12 04:04 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
i have a rollover valve. maybe i'll try a filter. just wanted to cut down some of the gas smell in my garage. thanks.
Re: fuel cell vent? [Re: rickraw] #1219824
04/21/12 06:50 PM
04/21/12 06:50 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
mine always smells too...thats vapor..good thing the garage has vents...
Re: fuel cell vent? [Re: rickraw] #1219825
04/21/12 07:03 PM
04/21/12 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get a charcoal filter from some old car... a regular
filter wont change the smell... just plug in the charcoal
filter when its in the garage
Re: fuel cell vent? [Re: rickraw] #1219826
04/21/12 07:07 PM
04/21/12 07:07 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I use a small k&n filter on the end of the vent hose. You might check to see you have a check valve on your vent to prevent spillage incase of a roll over. But the venting of fumes is a normal thing.
Re: fuel cell vent? [Re: pittsburghracer] #1219827
04/21/12 08:43 PM
04/21/12 08:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used a k&n keychain I got from a racing event and it perfectly fits over 1/2" alum. line which I inserted in the end of my #8 earls braided line.
Re: fuel cell vent? [Re: DavidDean] #1219828
04/21/12 09:05 PM
04/21/12 09:05 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I have a K&N filter on my roll over valve, when parked in the garage I pull the filter and pop on a AN plug, other wise I get the .."I smell gas" routine.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: fuel cell vent? [Re: Adobedude] #1219829
04/21/12 09:18 PM
04/21/12 09:18 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
i thank every one for their input. guess no one ever tried a pcv valve as i posted. i think i'll try one & see how it works. i'll repost this topic & let everyone know if it works. maybe everyone will have a stink free garage.
Re: fuel cell vent? [Re: rickraw] #1219830
04/21/12 09:31 PM
04/21/12 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing that will work is a charcoal filter...
thats why they are on cars(for emissions)... you have
to let the tank vent
Re: fuel cell vent? [Re: MR_P_BODY] #1219831
04/22/12 08:28 AM
04/22/12 08:28 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I put a pvc valve on the end of my vent tube and I don't have a problem with it. I tried a few by sucking air through them to find the lightest one. Did it get rid of the smell of gas? Don't know. You still smell gas in the garage, although not real bad. Do you have a carb on your car? If you do, do you plug the vent tubes when you park it to stop the smell of gas? Carburated cars smell after gas. The systems are not control vented like a fuel-injected system therefore you smell gas. Just walk around an old car in a parking lot or any where. You smell gas.
