Dumb question - Were all OEM forged 440 cranks... #1219154
04/20/12 04:55 PM
04/20/12 04:55 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
... drilled for accepting a manual transmission input shaft?
If not, what dimension in the pilot hole of the crank indicates it's manual-trans compatible? Thanks.
Re: Dumb question - Were all OEM forged 440 cranks... [Re: BradH] #1219155
04/20/12 07:11 PM
04/20/12 07:11 PM
dogdays Offline
dogdays  Offline
Here's a guess, based on years of accumulating knowledge.....They were all drilled but not every single one was broached to the final diameter.
R.
Re: Dumb question - Were all OEM forged 440 cranks... [Re: dogdays] #1219156
04/21/12 07:59 AM
04/21/12 07:59 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Based on what I've seen over the years no. Almost every B/RB I've had apart that had an automatic behind it was not drilled.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Dumb question - Were all OEM forged 440 cranks... [Re: dogdays] #1219157
04/21/12 09:07 AM
04/21/12 09:07 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
R.
2 different outer diameter pilot bushings where available for mopar cranks. One for a 4spd crank and one for a auto crank to be used in front of a 4spd. That one has the smaller outer diameter. Napa did have them. I don't know if they are still available. Brewer's or Passion may have them. I also have some undrilled cast cranks.
Re: Dumb question - Were all OEM forged 440 cranks... [Re: Mike P] #1219158
04/21/12 11:15 AM
04/21/12 11:15 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I'm going with you on this one.
My understanding is that the crank was drilled after installation if it was to be mated with a manual transmission. Urban legend?
Re: Dumb question - Were all OEM forged 440 cranks... [Re: Commando1] #1219159
04/21/12 01:39 PM
04/21/12 01:39 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
I have never seen one that is not drilled, just not all are finished to fit the bushing
Re: Dumb question - Were all OEM forged 440 cranks... [Re: HotRodDave] #1219160
04/21/12 02:56 PM
04/21/12 02:56 PM
Some of the early (1966 to 1968) 440 automatic cranks where like the 383 cranks, not drilled deep enough to use either bushings, NAPA adapter or stock. Just like the 413 and 426 street wedges where
Re: Dumb question - Were all OEM forged 440 cranks... [Re: Cab_Burge] #1219161
04/22/12 11:10 AM
04/22/12 11:10 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
both of the above . easy enough to work around , trim the input shaft and use a later bushing that goes in the convertor register or if the crank is out of the engine at least have it drilled deeper and use the later bushing in the convertor register.
Re: Dumb question - Were all OEM forged 440 cranks... [Re: JohnRR] #1219162
04/22/12 12:45 PM
04/22/12 12:45 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I've only seen 1 out of 30 440's that wasn't drilled,it was just spot drilled.
