How much HP to expect? SB #1219096
04/20/12 02:49 PM
04/20/12 02:49 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
360 .030 over tq plate honed, moly rings
hydraulic flat tappet 231@.050 .583 lift single pattern
2.02 mild port job 5 angle valve job R/T heads 270@.550
M1 single plane
900 CFM CS T-quad
1 5/8 hooker headers
11.3 compression
What kind of crank HP/TQ to expect and what kind of ET from a well set up #3200 race weight A-body?
Re: How much HP to expect? SB [Re: HotRodDave] #1219097
04/20/12 02:54 PM
04/20/12 02:54 PM
Guitar Jones Offline
I'm thinking it "could" come close to 500 HP, depends on a lot of factors but 480 should be easily within reach.
Re: How much HP to expect? SB [Re: HotRodDave] #1219098
04/20/12 03:10 PM
04/20/12 03:10 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Maybe 450 hp at the crank - I dont know whos bench flowed the heads at 270, but thats really aggressive for a mild port job right?
I'm at 400 hp at the crank with a stock set of 1.88 587 castings, 9.8:1 and .474 lift 232 dur cam
Re: How much HP to expect? SB [Re: DJVCuda] #1219099
04/20/12 03:45 PM
04/20/12 03:45 PM
Kalispell Mt.
Kalispell Mt.
It was a local guy, that is only about 12 cfm more than Ryan J got from a stock set
Re: How much HP to expect? SB [Re: HotRodDave] #1219100
04/20/12 03:50 PM
04/20/12 03:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ET is going to depend on the chasis...converter, gearing and tires..
Tony
70 AARCuda Vitamin C
Re: How much HP to expect? SB [Re: 70AARcuda] #1219101
04/20/12 04:19 PM
04/20/12 04:19 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
That's a lot of lift for a juice f/t. Could make 460 ish with really strong torque above ~3600
Be fun in a lighter car with 3.91-up gears and a 9 1/2" vert
WIZE
In Car:
Re: How much HP to expect? SB [Re: HotRodDave] #1219102
04/20/12 04:49 PM
04/20/12 04:49 PM
NY usa
540challenger Offline
NY usa
i am going to low-ball it and say 430hp at the crank. The 1 5/8 tubes are going to kill your HP IMO
Re: How much HP to expect? SB [Re: 540challenger] #1219103
04/20/12 05:05 PM
04/20/12 05:05 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Do you plan on putting it on the dyno? If so I'm interested in the results. I'm using a set of Brian@IMM RHS heads, m1 single plane, Solid cam with around the same lift as you in a stock stroke 360. I just have to get around to getting the correct thickness head gaskets and a few other little things and then it can be put together.
Re: How much HP to expect? SB [Re: 72swgnr] #1219104
04/20/12 05:24 PM
04/20/12 05:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Dave, seems that your leaving a lot on the table with the cam & small tubes
Re: How much HP to expect? SB [Re: emarine01] #1219105
04/20/12 05:40 PM
04/20/12 05:40 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
True about the 1 5/8" but ( as in my own case ) they FIT and they're cheap :-). My 414 runs 1 5/8 because I know they fit my unique chassis...and FAST cars run 9's and low 10's on manifolds and 2 1/2 " pipes
WIZE
In Car:
Re: How much HP to expect? SB [Re: Streetwize] #1219106
04/20/12 06:05 PM
04/20/12 06:05 PM
Kalispell Mt.
Kalispell Mt.
I already have the cam and headers so they will be sticking around. I have all the stuff for the short block and the heads. The only thing I do not have is an intake, bearings, and a few gaskets.
I will be driving it on the street also so I probably would not make the cam any bigger if I could and If I had a choice about the headers I would probably use 340 manifolds instead. The only other exhaust option I have is 273 manifolds.
Re: How much HP to expect? SB [Re: HotRodDave] #1219107
04/20/12 07:08 PM
04/20/12 07:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Who cut the cam? That's a bunch of lift for the 231 at .050 duration. It's more like a hyd roller set up with a 1.6 rocker.
Re: How much HP to expect? SB [Re: RobX4406] #1219108
04/20/12 11:45 PM
04/20/12 11:45 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I have the same cr, but with 244@ .050 cranking psi is at 205. Your going to need hi octain, 440 hp
Re: How much HP to expect? SB [Re: ademon] #1219109
04/21/12 12:13 AM
04/21/12 12:13 AM
Kalispell Mt.
Kalispell Mt.
Engle cam specifically for mopar lifters with 1.7 rockers.
I originally had it ground for a bigger engine with a tad less compression, then I had to sell my stroker short block. I hope it is not too lumpy for this combo
Re: How much HP to expect? SB [Re: HotRodDave] #1219110
04/21/12 12:23 AM
04/21/12 12:23 AM
RobX4406 Offline
RobX4406  Offline
1.7's will get it there!
Re: How much HP to expect? SB [Re: HotRodDave] #1219111
04/21/12 12:42 AM
04/21/12 12:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the LSA on that cam
Re: How much HP to expect? SB [Re: MR_P_BODY] #1219112
04/21/12 12:52 AM
04/21/12 12:52 AM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
450 hp
Re: How much HP to expect? SB [Re: HotRodDave] #1219113
04/21/12 02:05 AM
04/21/12 02:05 AM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
That is an iron head, correct? It may need more than pump gas. I'm afraid you might have problems with that cam. Hydro high rate of lift cams sometimes don't like high ratio rockers.
Re: How much HP to expect? SB [Re: forphorty] #1219114
04/21/12 10:39 AM
04/21/12 10:39 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Are you going with a M1 single plane because of the Carburetor?
Alan Jones
Re: How much HP to expect? SB [Re: HotRodDave] #1219115
04/21/12 10:44 AM
04/21/12 10:44 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
420 at the rear wheels
