Inexpensive header coatings? #1218710
04/19/12 04:51 PM
04/19/12 04:51 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
I have a pair of headers that I got with a car, they are an old pair of Hedmans that are kinda crusty. I was going to send them off to Jet-Hot to be coated, but they quoted me over $300. I can buy a new, ceramic coated pair for $257. Doesn't have to be show quality, just looking for something that will hold up and keep the rust at bay. Thoughts? Thanks
Re: Inexpensive header coatings? [Re: Montclaire] #1218711
04/19/12 05:31 PM
04/19/12 05:31 PM
Scranton, PA
Scranton, PA
I should say that I've tried the rattle can route over the years, I need someplace that will dip and bake them.
Re: Inexpensive header coatings? [Re: Montclaire] #1218712
04/19/12 05:32 PM
04/19/12 05:32 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
eastwood has tech coating. i think it's 25.00 for a 4 ounce can, 1300 deg. i got 2 cans to do my small block headers. i cured mine in my modified over. can be cured on the car.
Re: Inexpensive header coatings? [Re: rickraw] #1218713
04/19/12 05:36 PM
04/19/12 05:36 PM
an8sec70cuda Offline
How has it lasted? I got some stuff from eastwood several years back that was black. It was in a can and you painted it on. It wasn't any better than the rattle can crap from the parts store.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Inexpensive header coatings? [Re: an8sec70cuda] #1218714
04/19/12 05:41 PM
04/19/12 05:41 PM
Scranton, PA
Scranton, PA
Yeah, the "cure on car" method is a joke. I had bought good paint, too, but it had to be baked within so many hours. So it was spray, spray, throw the motor in the car, and let it run. Of course, that meant open headers. Wound up going half deaf and vibrating all of the trophys off the body shop shelf. That didn't go over too well. They looked just as bad two months later.
Re: Inexpensive header coatings? [Re: an8sec70cuda] #1218715
04/19/12 05:42 PM
04/19/12 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to use the BBQ spray paint... a couple times
a year I would have to spray the outside of the first
bend... thats the hot spot.... now days I have
QC Coatings do all my headers with ceramic (black
or Silver)
Re: Inexpensive header coatings? [Re: Montclaire] #1218716
04/19/12 05:44 PM
04/19/12 05:44 PM
If someone near you does powdercoating, you may want to check w/ them. I think they have a type of coating they can do that will work on headers. Just what I've been told, but I have zero experience w/ it.
CHIP
Re: Inexpensive header coatings? [Re: an8sec70cuda] #1218717
04/19/12 05:48 PM
04/19/12 05:48 PM
Scranton, PA
Scranton, PA
What does QC charge per pair?
Re: Inexpensive header coatings? [Re: an8sec70cuda] #1218718
04/19/12 05:51 PM
04/19/12 05:51 PM
Ambridge, Pa.
Ambridge, Pa.
i used the silver matte finish. it has lasted longer that a set of tti's i use to have. prep is the key for a good finish. i beleive u need a 240 grit finish. no glass beading. i modified a old electric oven, 1 header fits in nicely. cured 1 hr @ 800 deg. finish never came off. for what it cost for jet hot, u can do ur own headers many times & it still would be cheaper.
Re: Inexpensive header coatings? [Re: Montclaire] #1218719
04/19/12 05:53 PM
04/19/12 05:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
About $250 for most headers
Re: Inexpensive header coatings? [Re: MR_P_BODY] #1218720
04/19/12 05:56 PM
04/19/12 05:56 PM
Scranton, PA
Scranton, PA
Yeah, I can buy new for $250
Re: Inexpensive header coatings? [Re: Montclaire] #1218721
04/19/12 06:01 PM
04/19/12 06:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your not buying new headers that are ceramic coated
for $250
Re: Inexpensive header coatings? [Re: Montclaire] #1218722
04/19/12 07:22 PM
04/19/12 07:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i used tech like coatings cerma krome.thay are dull after 20yrs but not rusted.
Re: Inexpensive header coatings? [Re: MR_P_BODY] #1218723
04/19/12 08:32 PM
04/19/12 08:32 PM
for $250
I'm thinking the same thing. New and painted maybe, but not new and ceramic coated. If they are really $275 for coated ones, then I'd seriously question the quality.
CHIP
Re: Inexpensive header coatings? [Re: an8sec70cuda] #1218724
04/19/12 08:41 PM
04/19/12 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
for $250
Without a doubt.... even a plain set of headers for
$275 I would REALLY wonder
Re: Inexpensive header coatings? [Re: MR_P_BODY] #1218725
04/19/12 09:06 PM
04/19/12 09:06 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I've had good luck with the spray bomb method...Used VHT the first year I put my car together, without any heat processing and the paint flaked right off (And stunk too)..Second time around I wire wheeled the headers until they were bare metal, heated em up till they were glowing hot with a torch (you can feel the heat coming out the opposite side) and while they were hot, sprayed about 2-3 coats of the paint on. That finish lasted perfectly fine, required no breaking in with heat on initial firing of the engine, and is cheap and looks good too
Re: Inexpensive header coatings? [Re: mshred] #1218726
04/19/12 10:55 PM
04/19/12 10:55 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
The spray on coatings are a joke. I've stripped headers and refinished them only to have them like junk after a year or so.
This time I tried POR-15 Black Velvet header coating and its amazing. I wiped them down with rubbing alcohol and painted them with a brush right on the car. I thinned the Black Velvet with a little bit of paint thinner and brushed it on. It looks a little streaky at first but once you start the engine it bakes right on. If you ever need to touch it up just grab the can and brush a little more on. Make sure you wear gloves because it doesnt come off your skin. I've done 2 sets of headers so far and used maybe 1/2 of the can.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Inexpensive header coatings? [Re: 69dart] #1218727
04/19/12 11:08 PM
04/19/12 11:08 PM
Scranton, PA
Scranton, PA
I'm guessing you don't need a top coat with that? Sounds like it might be a good solution.
Re: Inexpensive header coatings? [Re: Montclaire] #1218728
04/20/12 12:46 AM
04/20/12 12:46 AM
I sandblast the crap out of them to get good bite and then BBQ black them. Very easy to touch up if need be and doesn't wear off.
Re: Inexpensive header coatings? #1218729
04/20/12 01:11 AM
04/20/12 01:11 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
VHT, no problems after several years.
