69 GTX Engine Bay, Whats Wrong With it ? #1216634
04/15/12 10:49 PM
04/15/12 10:49 PM
blewbyu Offline OP
blewbyu  Offline OP
I am looking at purchasing this 69 GTX and i would have thought that a GTX would have a 3speed wiper motor being it was a high end package car. Is it possible that it came with a 2 speed wiper motor? Here is a picture of the engine bay what do you think about the picture, does everything look correct? It looks like a 2 speed motor.
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216635
04/15/12 10:56 PM
04/15/12 10:56 PM
california
Mr D21 Offline
Mr D21  Offline
california
the coil wire is too long,,,
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216636
04/15/12 11:35 PM
04/15/12 11:35 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
3 speed wipers were an option not standard.
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216637
04/16/12 12:59 AM
04/16/12 12:59 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It is very possible for a GTX not to have 3 speed wipers. A lot of cars without the airgrabber came wirh two speed wipers. The PCV valve and ballast resistor are not correct but that's nothing. Is it A4 platinum metallic? The A/C is a nice option with tinted glass all around. It has the factory tach. Can you post the fender tag?
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216638
04/16/12 09:02 AM
04/16/12 09:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Can you post a smaller low res picture , that will make it easier to spot what is not correct.
As said 3 speed is an option , it also has the wrong master cylinder cover.
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: JohnRR] #1216639
04/16/12 10:50 AM
04/16/12 10:50 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
and if it's a disc brake car it's the wrong master cylinder................
My '69 GTX came with a 2-speed wiper system
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: A12] #1216640
04/16/12 10:56 AM
04/16/12 10:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Which brings up a question since this is the first '68 or '69 B-body that I've owned with disc brakes "could you get non-power disc brakes?" My GTX has power disc brakes; (front discs of course)
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: A12] #1216641
04/16/12 11:00 AM
04/16/12 11:00 AM
DTW
drmopar Offline
drmopar  Offline
DTW
The master may be correct, the cap for sure is wrong. The B body mopars had to have power assist to get disc brakes. The A bodies past 1970 could get disc without power assist. And yes, J25 was optional on B body mopars, but standard on N96 equipped cars.
RM27H9G 4 speed F8/tan guts
RS27L9G auto B5/black guts
WM23H9G auto F5/green guts
2021 Challenger 392 Indigo/black guts
2019 Charger Daytona R/T F8 on black
2018 Ram Sport Hemi 4x4
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: drmopar] #1216642
04/16/12 11:07 AM
04/16/12 11:07 AM
SE Pa.
LimeliteAero Offline
SE Pa.
the master cylinder is probably a Wagner, Ive got one around here with the same lid.
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216643
04/16/12 11:11 AM
04/16/12 11:11 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ballast resistor, pcv valve, master cylinder cover,ignitiona coil should be green lettering
missing a voltage regulator?
a/c compressor pulley and power steering pump assy should be gloss black
Steering wheel center cap looks awfully dark ( maybe a 68 cap ? )
Shifter knob is chrome - should be woodgrain ( maybe an early car thing ?)
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216644
04/16/12 05:41 PM
04/16/12 05:41 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
Shouldn't the engine be turquoise with A/C?
[oo]======[oo]
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: Scatransit] #1216645
04/16/12 05:57 PM
04/16/12 05:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I thought 440 HP were orange regardless of A/C or not???? Thought that was a 383 HP thing???
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: A12] #1216646
04/16/12 07:06 PM
04/16/12 07:06 PM
JohnRR Offline
JohnRR  Offline
383 thing , a turquoise 440 in 69 would be the 350HP version .
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: JohnRR] #1216647
04/16/12 07:13 PM
04/16/12 07:13 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Nice looking car. A few wrong finishes and minor details, that wouldn't stop me from buying it.
Sheldon
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: RUNCHARGER] #1216648
04/16/12 10:31 PM
04/16/12 10:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sheldon
and with A/C in Florida it's a no brainer IMO
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: A12] #1216649
04/16/12 11:26 PM
04/16/12 11:26 PM
Warrenton, VA
Warrenton, VA
The GTX was only available with the 375 HP 440 or a Hemi
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: blewbyu] #1216650
04/18/12 12:22 AM
04/18/12 12:22 AM
North Central USA (MN-WI area)
MuscleMopars Offline
What's wrong with it?
It's not in your garage. Or is it?
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: drmopar] #1216651
04/18/12 12:35 AM
04/18/12 12:35 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
A bodies prior to 70 also had non-power discs. I had a 68 383 with non-power discs.
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: MuscleMopars] #1216652
04/18/12 09:29 PM
04/18/12 09:29 PM
blewbyu Offline OP
blewbyu  Offline OP
You obvious know me pretty well Eric, Right now its priced alittle on the high side or it would be parked next to my A4 A12 Superbee as I'm typing
Re: 69 GTX Engine Bay, Whats Wrong With it ? [Re: gtx6970] #1216653
04/18/12 10:15 PM
04/18/12 10:15 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
friend of mine has a EARLY August'68 build charger and it has the chrome knob on the stick, and also 1968 doors! the factory drilled new holes for the lock knobs, but the old(1968) one are there also. it's got lots of carry-over, 1968 parts on it. pretty cool to look it over!
